Replacing S90
Started Apr 7, 2016 | Discussions
rolandx1 Forum Member • Posts: 51
Replacing S90
I'm looking for a new camera to replace my S90 that has served me faithfully for the last seven years. If I stay with Canon which Powershot would you recommend? I'm very interested in the G7 Mark II. I realize it's somewhat bigger than the S90, but it seems like a lot more camera.
 rolandx1's gear list:rolandx1's gear list
Canon PowerShot A570 IS Canon PowerShot S90 Canon G7 X II Canon PowerShot SX70
Canon PowerShot S90 Panasonic Lumix DMC-G7
YWG Senior Member • Posts: 1,364
Re: Replacing S90
I have a S90 since 2010. Given the G7x II isn't out yet, I won't speak to that. However, I did own a G7x for a year which has the same lens and sensor.
The autofocus on the S90 is really sluggish. The G7x is much faster and has a touch screen to move the AF point around. It makes for a much more fluid and rapid shooting experience. The G7x MKII is supposed to have faster AF speed.
Touchscreen has functionality in reviewing photos and other controls.
The G7x has a fold out screen which is nice for shooting low, selfies and even overhead. G7x 2 design has improved on the fold.
Separate exposure compensation dial is handy.
wider lens at 24 mm and going to 100mm equivalent. The lens is much faster over the focal range which is good for low light. I wouldn't call it excitingly sharp however and photos can have a smudgy look to them.
electronic level.
Neutral Density filter, I forget if the S90 has one. I don't recall.
Connectivity with other devices for sharing of photos and use of remote
Burst in jpeg is superior to S90. The G7x mkii can do fairly impressive burst fps in RAW unlike the mki.
Video is superior on the G7x.
1" Sensor is larger than the one in the S90 yielding cleaner photos at higher ISOs. The sensor is much higher resolution too.
The G7x isn't that much different in the frontal area. It is noticeably thicker which does reduce the portability. The S90 slips easier into a pocket which makes me think the G9x might be a good upgrade instead if portability is a major criteria. Anyhow, the G7x was always thick enough that it had to ride in my coat pocket or hip case less comfortably than the s90.
G7x2 has usb charging. That could be handy out and about when you don't have the charger or want to reduce the accessories floating around in the travel bag.
The G7x/G7x2 wipe the floor with the S90. Coming from the other end of DSLR land however, I never found the combination of the lens and sensor to completely blow me away.
The new G7X mkii is quite expensive. Something like th G15/G16 might be an attractive option at a lower price.
 YWG's gear list:YWG's gear list
Olympus Stylus 1s Canon PowerShot G5 X Olympus E-M1 Olympus E-M1 II
John McCormack
John McCormack Veteran Member • Posts: 7,101
Re: Replacing S90
I'm also waiting for the G7 X ii, as it should be somewhat better all around than the G7 X; the Digic 7 processor should make the MK ii very speedy. Check out this list of improvements over the G7 X: 25 Improvements of the updated Canon G7X mark II - Asklens
If cost is an issue the original G7 X should work fine and is definitely an improvement over the S90.
nancy100 New Member • Posts: 20
Re: Replacing S90
I've been using an S90, too. I spent the last few weeks agonizing over G7X and G9X. The G7X (and the upcoming new model) seem to be more camera, but in the end, I went with the G9X. I knew I'd be unhappy with anything larger than my S90, and I also didn't want to spend the extra $. But neither of those are photography criteria.
OP rolandx1 Forum Member • Posts: 51
Re: Replacing S90
Is the G9X that much smaller? What are the main features you give up going with the G9X over the G7X? I like a smaller camera because I'm more likely to carry it with me. However this will likely be my only camera for the next 5-10 years and I'd like to get the most features I can. The price difference isn't enough to sway me either way.
Re: Replacing S90
You can do a side by side comparison on this site. From the menu at the top, select Cameras/Side-by-side camera comparison.
As for feature comparison, there are several threads here. Just do a search on both G7X and G9X (both with and without a space before the X) and see what you come up with.
John McCormack
Re: Replacing S90
Check out this comparison site also: http://cameradecision.com/compare/Canon-PowerShot-G7-X-vs-Canon-PowerShot-G9-X You give up lens speed for the smaller size of the G9 X.
Re: Replacing S90
Thanks. Both sites were just what I was looking for.
Rock and Rollei Senior Member • Posts: 2,903
Re: Replacing S90
It's taken me a long time to replace my S90 too - mind you, it took me a long time to replace my S70. I've been using EOS M/M3 instead, and they're fantastic cameras, but not quite pocketable like the S90. But I've been spoiled for IQ with them. G9X is properly small, but has a reasonable size sensor - great little cam. Without my EOS M3, I would've gone G7X II, I think.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Re: Replacing S90
Well I preordered the G7 Mark II. However I found a used SX50 HS for under $300. Would this make a good complement to the G7 when I wanted longer reach at the cost of portability (pocket camera) , or do they overlap too much.
Smaug01
Smaug01 Veteran Member • Posts: 6,966
G9X is what I replaced my S90 with
I tried some other cameras in between. I talked myself into the Olympus XZ-1, which was a fantastic camera. By far the best lens in this class. But I was fooling myself. The larger size meant that it wouldn't fit in just any pocket. For example, it isn't a pants pocket camera. It can be forced, but it's just big enough not to be comfortable.
So do yourself a favor, give up a bit of performance in favor of portability. If you don't, you'll find you're still relying on your phone more than you'd like.
-Jeremy
 Smaug01's gear list:Smaug01's gear list
Panasonic Lumix DMC-TS30 Ricoh GR III Olympus OM-D E-M10 III Nikon Z5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +25 more
Smaug01
One other point of comparison
I took the S90 with me as my only camera on a trip to Europe one time. After having taken the SD600 Elph the previous year, and finding the tripod was an absolute requirement, (so I could shoot at ISO 80 and have not much noise), I did the same with the S90, and the images were SLR caliber.
Now, with the G9X, I feel like I don't even need the tripod, as it has the much larger sensor and optical image stabilization. I just brace myself the best I can, and it just DELIVERS.
Here are a couple low light indoor shots with my G9X. The venue was Rainforest Cafe; I think those are all over the US, right? Look at the shutter speeds. They were all hand-held, but braced against tables, columns, etc. The OIS really works well.
forgot to give this one a bit of - exposure compensation...
Here are a couple outdoor shots, run through a film simulating preset in DxO FilmPack, which "ate" the EXIF data:
It's an awesome little camera. Just take care not to drop it. It is quite easy to drop when you don't use the wrist strap.
-Jeremy
