9-27mm NX Mini lens won't find focus
Started Apr 6, 2016 | Discussions
Kinger
Kinger Contributing Member • Posts: 549
Anyone have this happen? Just back from a Hawaii adventure and this was my compact setup. Towards the end of the trip the 9-27 started struggling finding focus and then failed to find focus all together. It was a tough trip for cameras. That one failed me and my trusty compact Panasonic waterproof flooded. Fortunately both happened towards the end of the trip. My NX1 was the only one that did not fail me!
Trying to file an online warranty claim and I keep getting an error. Not impressed with the warranty process so far.
Frustrated since this has gotten such little use.
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
Samsung NX mini Samsung NX1
Kinger
OP Kinger Contributing Member • Posts: 549
Re: 9-27mm NX Mini lens won't find focus
I figured out what is wrong with the lens. It seems the internal focal length indicator is out of position/calibration. The lens goes on prior to being fully extended. This lens functions similar to how the compact nx20-50mm functions where you have to extend it prior to use. So I think because this is giving a false signal to what focal length it is at it is therefore limiting the focus range to the incorrect focal length. So it is unable to obtain proper focus. I am reporting this back in case anyone else runs into it. Hope this is not a common quality issue.
Krazyheaven Regular Member • Posts: 411
Forgive me for not being able to offer any help but I reading this I found myself cheering the nx1 for overcoming a challenge that no other camera could meet.
brunorhm New Member • Posts: 1
Hi!, You figure out how to resolve it? My Samsung NX mini seems to have the exactly same problem, only focus on 27mm,  Really sad, the camera have 14 months, its like new.
nadatron New Member • Posts: 1
Can I ask how you resolved this issue? I am currently facing the exact same problem. My lens is only finding focus at 27mm
Kinger
Unfortunately no resolution. I ended up selling off the camera and the lens(declared as not working). Very disappointing.
ppgflyer New Member • Posts: 1
I came across your post when looking for a solution to the same issue that my son was having with his Samsung NX mini.
I managed to fix the issue, hopefully it will remain fixed.
It requires small Phillips head screwdriver and some tweezers. If you have an optivisor (headband magnifier) that would help, but it's not absolutely necessary.
On the back of the lens, remove the inner ring, the screws holding the contacts and the outer ring. This will give you access to the pcb header that the contact assembly ribbon cable is plugged in to.
On the opposite side to where the cable enters the header, on the pcb connector is a small brown clip, it is used to lock the cable in to the header. Lift up on the edge farthest away from the cable, it should just hinge up. You can now easily remove the contact assembly ribbon cable.
Carefully clean the contacts with a alcohol swab and wipe dry. Now the tricky part, lift the edge of the main PCB where the ribbon cable came from and carefully insert the end of the ribbon cable back into the header,  then push the part that hinged up back flat locking the cable back in place.
Re-assemble your lens and hopefully it will work properly.
I hope this is of help to you and any others that have the same issue with this camera lens.
Greg.
sillycornlotty
sillycornlotty Regular Member • Posts: 268
Greg.
Im expenicing the same problem with my NX mini. Will give a try tonight to fix it tonight, hope it works.
I bought this camera a year ago for my girlfriend and she rarely uses it, dont know why that kind of problem would occur despite of low usage.
 sillycornlotty's gear list:sillycornlotty's gear list
Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Nikon 1 Nikkor VR 6.7-13mm f/3.5-5.6 Nikon 1 Nikkor 32mm f/1.2 Samsung NX-M 17mm F1.8 OIS Samsung NX mini +4 more
ajcairns New Member • Posts: 1
Thanks for the great tip. Got my NX mini working properly again
Mythrakis New Member • Posts: 1
I really appreciate your detailed post on how to fix this NX Mini issue. I also encountered the issue where it says "rotate the zoom ring to unlock the lens." at any zoom. It was first only an issue at the 9-13 range. Then within a couple days I couldn't get it to take a picture at all anymore.
I tried your fix, which is a big heart-wrenching at first, as I haven't opened this relatively new baby yet. I didn't have alcohol but just wiped the contact assembly ribbon cable with an ear swab and reinserted it, which solved the issue. I am very thankful that I found this thread before sending it in for repair.
kugig New Member • Posts: 1
Hello,
I solved the problem for my camera. The problem is that one of the pins between the camera and the lens wont come out.
When you look at the camera when the lens is not mounted you can see these golden pins. In my case some of the pins wont snap out. The solution is: Before you mount the lens have a look at all pins. If one pin is stuck you need to release it manually with the finger nails or a screw driver.
Since I made this I never had any issues again.
Regards
BennyG9 New Member • Posts: 1
I didn't fully understand what you were saying the first attempt I took. I came back to it and I found I was being dumb and not following your well put description.
I did it again and so far IT WORKS!!!
You have no idea how thankful I am to you!!!! I just spent the last 6 hours feeling beaten and broken with no shred of help from anywhere on the internet. My options were becoming, trying to find a camera fix shop near me(of which I do not have the time or money for) or buying a whole new camera despite not having the funds for this especially.
You are a god sent!!!!
Thank you!!!!!
I honestly cannot explain how much this means to me! I created a whole account on this website just to thank you because you really are awesome!!!
Thank you again!!!
-Ben
noncho
noncho Regular Member • Posts: 348
Greg.
I almost forgot that I have NX mini with such problem, until I read this one and tried.
It just works, thank you for sharing this solution!
Noncho
www.NonchoILiev.com
 noncho's gear list:noncho's gear list
Canon EOS-1D X Samsung NX1 Samsung NX500 Canon EF 85mm F1.2L II USM Samsung NX 30mm F2 Pancake +11 more
jbuckler88 New Member • Posts: 1
AHHH I have been waiting for 2 years for someone to figure this out!! Id almost given up but it was such an expensive camera I couldnt let go. THANK YOU SO MUCH. Im literally going to post this link to all of the other blogs of people trying to solve this problem.
this is with the cable already disconnected, once you open your own lens you'll be able to compare to this to see what to do to yours!
M_digicapt Veteran Member • Posts: 3,289
Thanks for posting the pictures! For future reference... Where does the cable go? In the white plastic conector on the left or the bottom one?
DPR-Kat New Member • Posts: 1
kugig wrote:
Hello,
Regards
I only registered to say thank you to kugig for this solution - did the job for me, too!
I carefully pulled the small golden pins on the camera's body out one by one, with tweezers. Couldn't identify which of them might have been the problem, as optically and haptically, no pin seemed to be stuck - but the NX does focus again, now! Very happy. I am also grateful for the other solution offered and would have tried that next, but somewhat glad I don't have to disassemble that far in my case...
ge0rg Forum Member • Posts: 51
Great to see the description here and the images. I just got an NX mini that exhibits a similar behavior: the lens claims to be locked at <11mm and at 27mm, so both ends of the zoom spectrum are unworkable.
I've disassembled the first level of the lens and cleaned all three ribbon cables with alcohol, and it briefly worked at 27mm (in between, it had various combinations of "unlock" and not being able to focus), but now it's back to the original situation.
Does anyone know which of the two ribbon cables going "down" is for the AF motor, and which is for the zoom ring decoder? Are there instructions on further disassembling the lens somewhere?
 ge0rg's gear list:ge0rg's gear list
Samsung NX300 Samsung NX mini Samsung NX500
So I tried it again, disassembled the lens and apparently damaged the wider cable going down from the PCB.
Samsung NX mini 9-27mm lens "layered view"
Now the diaphragm remains always closed, when I start the camera, it makes a mechanic buzz sound (probably trying to open it), but the image remains dark. RIP lens, I suppose...
Diaphragm is always closed.
