DIY find fresnel focal length??
Started Apr 6, 2016 | Discussions
CardBoardBoxProcessor Regular Member • Posts: 328
I used my better beamer and it was great.  So I want  to  make  my own for  my sigma 150-600mm S to make up for its poor appeature of 6.3 at 600mm.
Questions:
do I want  the focal length to be adjusted for the bulb itself or the front of the flash?
How do I figure out my fresnel's focal length t?
My theory is that  I open a window and perfect the image on a wall.  Where ever distant objects are most clear is infinity focus. Is that correct?. Refer to image.
ibiza123 Regular Member • Posts: 280
Re: DIY find fresnel focal length??
Questions:
You could also focus the Sun light on the sheet of paper and find the distance between  the lens and the paper while the image of the Sun is smallest. But be careful not to burn the house!
 ibiza123's gear list:ibiza123's gear list
Fujifilm FinePix HS10 Sony Cyber-shot DSC-HX90V Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic 20mm F1.7 II
OP CardBoardBoxProcessor Regular Member • Posts: 328
Any other tips?
And bulb or front?
AustinMN Contributing Member • Posts: 674
To accurately determine FL for a fresnel, I would use the moon.  The sun is too hot and will start a fire.  Make sure the paper or other stock is parallel to the moon (a perpendicular line would point directly at the moon).  The fresnel needs to be parallel to the focus paper as well.
For your other question, I'm really not sure if you want to focus the front of the flash or the bulb.  If you use the front of the flash, then you probably don't want to focus it sharply.  If you do, thou will just end up projecting the pattern of the front of the flash with it's lines and patterns onto the subject.
I'm not interested in image quality. I'm interested in quality images.
I sometimes post from the office. Company policy requires that I disclose my real name: Tom Cooper
I give out a lot more "Likes" than praise. If I praise one of your photos, consider it a rare event.
 AustinMN's gear list:AustinMN's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS +9 more
Hmm. What flash power I want?  I've got  the  newer Yongnuo. Does it have  the  out put to bird?
Made the thing  tips for getting it perfectly aimed at what  the  lens is aimed at
Aussibum Forum Member • Posts: 55
Questions:
Your method is absolutely correct. I use the same method.
