How much of an upgrade is 100-400 over panasonic 100-300 or olympus 75-300 ii ? Is it worth it?
Started Apr 5, 2016 | Discussions
Lassoni Contributing Member • Posts: 512
I'm curious if it's worth upgrading to. The olympus is good only 75-200mm ? Going further it becomes soft
Has anyone made any comparison yet with 2-3 of these lenses?
 Lassoni's gear list:Lassoni's gear list
Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 100-400mm F4.0-6.3 ASPH +8 more
Robiro Veteran Member • Posts: 6,813
Re: How much of an upgrade is 100-400 over panasonic 100-300 or olympus 75-300 ii ? Is it worth it?
That is a €1699 question!
I saw a comparison recently in which the old 100-300mm was producing better results than the new 100-400mm!
https://www.mu-43.com/threads/pana-leica-100-400mm-f-4-6-3-first-impressions.83425/page-9
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
Dave Lively Senior Member • Posts: 1,938
Not enough people have used the 100-400 to really know at this point. Unlike the Olympus 300mm the results are not all good.
The samples I have seen so far suggest the 100-400 looks really good at 400mm when close to the subject but gets softer as the distance to the subject increases.  A few people posted comparisons with other long lens in the thread at mu-43.  Since the other lenses produced better results the softness cannot be due to poor technique, atmospherics, vibration, etc.
I really like the combination of small size, low weight and 400mm focal length this lens provides on paper.  But for $1800 I am going to have to see more test results before I buy one.  There is a chance some of the early lenses have a problem that will be corrected but I am not counting on that.  Since 90% or more of the pictures I take with this lens will be up close I might still buy one if they are great up close, just a little soft wide open at 400mm and long range but are fine stopped down to f7.1 or f8.0.  You shouldn't have to work around weak areas in a lens this expensive but the optically great with no excuses Olympus 300mm/1.4 TC makes the 100-400 look inexpensive.
djbrom
djbrom Senior Member • Posts: 1,324
You may want to read the whole thread....
It would seem that he ended up returning the lens as it didn't produce results that others were getting.
Here is test between the two http://www.mirrorlessons.com/2016/03/10/panasonic-100-400mm-vs-100-300mm/
It's still very early days bit it's clear that it's not as sharp as the much more expensive oly prim 300mm.  Others on this forum are producing images of good quality from the lens.  But have a squiz at the above and have a flick through the forums and you will see some images from it.  Best to wait till more than a half dozen people own it to form a solid opinion as the long super tele is harder to use.
 djbrom's gear list:djbrom's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +11 more
Even in his test, at 100mm the old 100-300mm is better than 100-400mm.
josbiker
josbiker Senior Member • Posts: 1,088
What a waist of words again and again! Watch out for trolls!
Be patient and look at real test and look at the better photographs not photo snappers!
 josbiker's gear list:josbiker's gear list
Panasonic S1 Panasonic S Pro 70-200mm F4 OIS Panasonic S 24-105mm F4 Macro OIS Canon Pixma Pro-100
LMNCT Veteran Member • Posts: 4,908
Success with the 100-300 is a matter of handling and knowing what ff to set.  It can produce some very sharp images.  Those images can be printed at large sizes and still look good.  No doubt, the new lens is also a case of 'knowing how' and as more people get and use the lens, it will become 'better and better'.  It is pretty easy to produce a sharp image with a single focal length prime, but not always as simple with a long zoom.  If Panasonic ever gets around to supplying the sellers with the procduct (200-400), I will let you know what I think of the performance at 400.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
kbouk
kbouk Regular Member • Posts: 402
Lassoni wrote:
I'm curious if it's worth upgrading to. The olympus is good only 75-200mm ? .....
I have the same question especially for the mzuiko 75-300 II , I have a very good copy and up to 200-230mm is very good (close enough to my Zuiko 50-200 SWD +1.4X) and good at 300mm, no complains according to the buying price (500€) but I want a better m43 performer to the extreme tele 250-300mm and even further on 350-400mm focal length.
I'm not asking for the IQ of the new mzuiko 300mm/4, I will be happy if it performs as my Zuiko 50-200 SWD +1.4X (or my old Panaleica 4/3 14-150mm),  I think it's wrong to make comparisons with a prime pro lens much more expensive.
Cheers
Costas
 kbouk's gear list:kbouk's gear list
Leica Digilux 3 Olympus E-M1 Panasonic Lumix DC-S1R OM-1 Olympus Zuiko Digital 25mm 1:2.8 Pancake +14 more
DepletedZPM New Member • Posts: 13
On walks with my wife, she carries a compact Nikon S9700 with 25-750mm FL equivalent re. 35mm, while I have an Olympus E-M1 usually with the 75-300mm II. I also have the Panasonic 100-300mm which I use when the bigger aperture is helpful, but I usually prefer the Oly because I get much better autofocus performance from it.
The difference in quality between the S9700 and the E-M1 is obvious, especially when the daylight fades. But there are numerous occasions when we're snapping a distant bird and my wife gets some surprisingly decent pictures, while I get precious few pixels of the subject after cropping. So I'm convinced that 800mm FL equivalent will be very useful to me.
I'm also pretty sure that there's lots of room for improvement over the optics of the 75-300 and 100-300 lenses. It will be interesting to see what DXOmark says about the 100-400.
 DepletedZPM's gear list:DepletedZPM's gear list
Fujifilm FinePix HS30EXR Canon PowerShot G7 X Canon PowerShot SX720 HS Olympus E-M1 Panasonic Lumix DMC-GX8 +12 more
That was a real controlled test done by a better photographer.
Plus, I want to buy this lens.
Skeeterbytes Forum Pro • Posts: 23,182
It's early and most of the 100-400 samples I see are from more advanced photographers, but the new lens appears to not need stopping down, which the others clearly require to give pleasing results. This makes it stops ahead even before considering the much greater reach. It also seems to have better contrast, but that's a tricky comparison when evaluating long lenses where atmospheric conditions play a role.
The hybrid IS and focus response will be testable and the new lens should win that handily, albeit tilted to newer Panny cameras.
In sum, a better lens as befits its newness and price.
Rick
bradevans
bradevans Senior Member • Posts: 1,029
These are from pre production copy and I would expect even better from this guy (Chris pepper) in the coming weeks based on a production version
no exif given but the bird looks pretty sharp (imo)
http://northof49photography.com/blog/2016/3/2/hands-on-review-with-the-new-lumixleica-100-400-lens
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
Nice work! (Not so nice weather.) Thanks for the link.
Rick
