Nailing (auto-)focus with the Panasonic 100-300?
Started Apr 3, 2016 | Discussions
OP (unknown member) Regular Member • Posts: 348
Re: Nailing (auto-)focus with the Panasonic 100-300?
LMNCT wrote:
One more thought about attaining auto focus and sharp results at the 300 end. Remember to support the lens from below with your left hand. It may sound simple, but it makes a big difference. If you are using the LCD and holding the camera out to compose and focus, you may not have adequate support.
Agreed.
When I use the Panasonic 100-300, it rests with the zoom ring on the open palm of my left hand (forming the center of rotation and balance there), with the index finger extended towards the front of the lens - somewhat akin to a rifle shooter position. In my experience, and for my current hand-holding capabilities, this seems to offer the most stable platform.
Tony Rogers Senior Member • Posts: 2,201
I think the problem here is the nature of CDAF auto-focus combined with the relatively slow focus performance of the 100-300 lens.
CDAF works by checking the contrast in the focus area, moving the lens a bit, and checking again. If it has moved in the right direction, the image will be sharper (more contrast). This repeats until the AF converges on the best focus.
The critical part of this process working is the converges part. i.e. the camera keeps moving in the same direction until it goes too far and then backs up a bit. This is fine if the samples in the focus area are of exactly the same part of the subject (like an eye for example) each time the AF checks for contrast. This is fairly easy to achieve with a static subject and a lens that moves reasonably quickly to focus and IS probably helps as well.
However, when the subject is moving, it is very, very difficult to ensure that the same part of the subject is under the focus box each time the image is sampled. This could lead the AF to assume it has found the best focus because the image gets less contrasty between two steps when actually, the bit of the image being sampled is different and either has different contrast or is at a different distance.
There is not much that you can do about this with any particular lens other than use a smaller focus box and try to track the subject more accurately. Lenses that focus faster and resolve more fine detail work better.
The "answer" is PDAF but this too isn't perfect on the E-M1, especially with older, slower lenses.
 Tony Rogers's gear list:Tony Rogers's gear list
Sony a1 Sony 1.4x Teleconverter (2016) Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 200-600 F5.6-6.3 +1 more
LMNCT wrote:
My cure on the GX1 was to focus manually and that worked quite well.
The focus ring on my 100-300 is so stubborn and sticky and cranky - how are (were?) you able to operate that?
I'd love to shoot "S-AF + manual", because turning the focus ring will enable manual focus assist magnification automatically. For that to work, it seems as if I need to keep the shutter button half-pressed with the right hand while using thumb and index finger of the left hand to pinch and operate the focus ring. I seem to be lacking the right technique here. (And, e.g., a monopod firmly stuck into the ground to provide leverage against the left-handed turning of the ring)
Danielvr wrote:
The computed DOF of the 100/6.7 shot should have been 90cm (online calculator and EXIF data agree). _If_ focus as claimed by the camera had _really_ been on the shoulder, then a whole lot more of the arm, the helmet, and the face would have been in focus.
The sharpnesss standard underlying 'depth of field' is rather arbitrary
... and contains a perceptual component derived by Zeiss some fourty years ago, taking into account display (i.e.printing) technology of the times as well viewing distance of the output.
My challenge in that first 100/6.7 photo is that I do not see _anything_ in "proper" focus, although the camera claims in the EXIF data that focus is on the shoulder (S-AF focus priority release). At 1/1000 exposure time and with three axis IBIS (Olympus E-PL7, overrides OIS) and a mostly static subject (Danny McAskill was standing still on the bike at the time), I would tend to rule out subject movement or equipment movement in this specific case (in the general case, sure, those would be major factors)
Maybe you shoot start by establishing the sharpness of your lens by shooting something static at similar distance, aperture, etc, using a tripod and electronic shutter. Then you'll know what kind of sharpness is possible.
My copy of the Panasonic 100-300 has decent sharpness. It is not an Olympus 300/4 or a Panasonic-Leica 100-400, but even at the far, far (bad, bad) 300mm end it can produce the sharpness of the second photo (300/5.6 at 1/750). If I am not mistaken, that specific photo is not even the best the lens can produce at that focal length - it is good enough for me, though, because down-sampling to sizes I use removes the softness. At 100mm the Panasonic tends to be much easier to shoot and has significantly better optical quality.
From there, you can figure out how to achieve it in practice.
That's what I am trying to get to right now
Danielvr Veteran Member • Posts: 6,863
I agree, it looks simply out of focus. However I doubt if the above is a correct interpretation of the EXIF data. It tells what your chosen AF area was, but probably not if the camera actually reached focus there (for that, see Focus Distance - but that value won't be very helpful if you don't know your actual distance to the subject). Or are you confident that the camera confirmed focus (and you didn't have Release Priority on)?
Well, I think you'll need to do some actual experimenting with focus point size, autofocussing twice (or prefocussing), continuous-AF, et cetera to find the method that works best. With my 50-200mm Fourthirds lens, C-AF and focussing twice often helped with this kind of event photography, but that was using phase detect AF which isn't really comparable.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
LMNCT Veteran Member • Posts: 4,908
You must have a different batch than I do.  My focus ring is not sticky and I find it very easy to use.  Now that the lens spends most of it's time on either the GX8 or GH4 (sometimes, the GM5), I find that auto focus works a lot better.  I also use the pinpoint (cross hairs) focus target.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
bradevans
bradevans Senior Member • Posts: 1,029
on the 100-300 the more you squeeze the focus ring the stiffer/sticker it becomes. While by no means an "answer", i try to squeeze as little as possible.
Focus ring might be an option but i dont think it will solve the stickiness.
I've *considered* trying to get some corn starch or graphite inside the ring, but havent actually done so.
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
Adrian Harris wrote:
I understand your frustration and am beginning to wonder if this is where M43 cameras fail badly?
It's not really frustration - just awareness of some limitations (within my budget) that I am trying to stretch.
Comparatively speaking, m43 with contrast-detect AF (only) is in a bit of a difficult situation:
* Small sensor cameras with similar reach have much larger DOF by default, possibly masking problems there (200mm FF = 100mm m43 = 44mm 1/1.7" sensor -> DOF = 4.2 meters instead of 0.90 meters)
* DSLRs have a dedicated focus system fully decoupled from the sensor and therefore can be optimized much better; similar arguments apply to on-sensor focus detection pixels on a number of mirrorless cameras. More hardware is thrown at the problem, and even a 200mm (equivalent) lens seems to be not that frequently used, let alone 600mm (equivalent).
Add the fact that the Panasonic 100-300 does not seem to be exactly the one lens to be optimized for focusing and contrast detection (in particular at the very long end, in my experience), and end up with a bit of a challenged packaged.
I am confident that a GX8 with a Panasonic-Leica 100-400 will perform wonderfully at a price of EUR 2700. I am trying to shoot at a price point of about EUR 600 (E-PL7 + 100-300; lucky purchases).
Just a couple of days ago I read an account from someone who said that her new 100-400mm became much smoother after she'd used it in the rain, and the extended part of the lens had gotten wet (after which she retracted it, probably pulling a tiny bit of moisture into the lens). I don't recall if she was talking about the zoom ring or the focus ring, but it might be worth a try. I'd hesitate to use graphite (let alone starch!) because that would probably affect the sealing.
bradevans
The 100-300 is not weather sealed; that still might not justify trying any powder based lubricant.
I read that thread as well but didnt really know what to make of it. Moisture would dry out, and perhaps leave some residue; hard to see why that should help despite the fact that it did.
The 100-300 is one of the oldest M43 lens out there. Besides its focus accuracy, the burst speed / (re)focus speed is not very good (i cant recall the reasons but it relates to the lens, not the body, not the photographer).
The 100-400 should be better on speed based on this , specifically this line:
High speed digital signal exchange at 240 fps
The image sharpness one can reasonably infer from other people's image but the ease of use, focus speed, focus accuracy are much harder till you have one in your hands. (And even then it may be body specific as the GX8 would give the "dual IS" while others wont).
I know, but I think that you'll find a seal around the extending part of the barrel even so (I have no 100-300 to verify this, but it seems to me that it would be too vulnerable without one there).
Do you happen to recall where it was? I meant to revisit that thread because of some excellent images from the 100-400mm. I'm a bit of Zuikoholic myself, but to be honest I think the Panaleica renders textures much nicer, more 'analog', than the 300mm f4 does. Its colors are beautiful as well.
Egregius V
Egregius V Contributing Member • Posts: 538
The 100-400 zoom that got smoother after getting wet: here
 Egregius V's gear list:Egregius V's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +17 more
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
shoffmeister wrote:
Snip
2) The Panasonic 100-300 focus ring is not exactly helpful for me; this removes the S-AF + M option and also the pure manual focus option (which I would me happy to use!). Auto-magnification otherwise could be a pleasure to use
I have the EPL5 and the EP5 and setting the camera to S-AF + M works with the lenses' focus ring. I get a magnified image when I turn the ring.
Also, on my lens, the focus ring is silky smooth.
On my EP5, I have a "Magnify" button. I have programmed this to magnify the live view by using the x2 teleconverter. I find the x2 better to focus and compose than the x5.
If the camera is set to raw, I still get the x2 teleconverter view but the camera does not save a jpeg, only the raw.
I get quite sharp images from this lens at 300mm using a tripod or monopod but Not hand held.
Allan
Thanks much!
Just look at those bird photos she took from her windowsill.. beautifully rendered textures, excellent colors and incredible pop. I know this is the wrong thread, but anyone looking for 100-400mm bird samples should check them out:
https://www.mu-43.com/threads/pana-leica-100-400mm-f-4-6-3-first-impressions.83425/page-9#post-881469
gary0319
gary0319 Forum Pro • Posts: 10,540
I suspect the actual culprit here is that the part of the bikers jersey that you were trying to focus on (the shoulder) has almost no contrast, just gray and some darker gray. Since the focusing of the camera is reliant on the contrast of the selected focus area there just is not enough contrast there for it to work properly. I have the same problem with foliage. Couple that with the slow focusing motors of the 100-300 and it can be frustrating.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
bradevans
From this thread: it seems the interplay of burst rate and diapraghm.  IIRC, the two slower burst rates (on Panny bodies) *do* autofocus between shots, the two fastest do not
Are you shooting using C-AF or S-AF?
The 100-300mm problem occurs when shooting at rates over 2-4 fps using C-AF. The type of diaphragm used in the older Panasonic lenses cannot open and close fast enough for high speed C-AF.
My 100-300mm could only shoot at 2-3 fps in C-AF mode which is why I changed it for the Olympus 75-300mm.
Hope that helps.  For me the 'focus hunting' at the long end is the biggest drawback - but I'm usually shooting airplanes, not birds.
jalywol
jalywol Forum Pro • Posts: 12,301
The 100-300mm takes some getting used to
shoffmeister wrote:
How can I _reliably_ nail auto-focus with the Panasonic 100-300 or with any other long lens, on an Olympus E-PL7?
The first shot is definitely out of focus, but the second, what I am seeing is motion blur.
There are some tips about working with the 100-300mm that you may find helpful:
First, it really does take some time to get used to holding this lens steady. You have to be well braced when you are holding this camera/lens combo, and you do need to hold the lens with your left hand (preferably while bracing your left elbow on your body). It took me several months of actively using the lens before I got consistent enough with my holding technique to get a reasonable keeper rate with it.
Careful and deliberate shutter release is also very helpful.
Speeds over 1/800 work best; over 1/1300 work even better. However, once you have developed a good holding technique for it, you can go much slower and still get keepers (although not as many as at a faster speed, of course).
This lens is also extremely sensitive to shutter shock. I would use full electronic shutter on it wherever possible, and for sure EFCS (or zero second anti shock on your Oly).
It's not great at 300mm, however, shots taken at 300mm, if in focus, will sharpen up very well in PP. A little lower than 300mm is better (285mm for example).
Close objects always seem to do better than far ones; I think that has to do with the glass more than the AF, personally.
I would try the different AF box sizes on your EPL7 and figure out which works best with this lens. I seem to recall the smallest one worked best for me on the EPM2 (and also on the GM5). Pinpoint is too small, though, for me.
These were taken on a GM5:
Straight out of camera JPGs with no additional processing at all. They were both hand held, but well braced.
The lens, if you can get into a well lit situation, does sharpen up well above base aperture (f7.1 and f8), too.
EFCS on below 1/500mm, full e-shutter above that.
-J
SteveY80 Senior Member • Posts: 2,087
LMNCT wrote:
The 100-300 is not "garbage". The trick to getting sharp results at the long end is to use an aperture like 7.1.
I've tried from f/5.6 to f/11 at 300mm and I don't get sharpness I'd consider acceptable at any aperture. It's fine from 100-200mm, acceptable up to 250mm or so when stopped down, but zoomed all the way to 300mm I think I'm justified in calling it garbage. Of course I'm just talking about my copy of the lens - it's possible I don't have a particularly good one.
 SteveY80's gear list:SteveY80's gear list
Nikon 1 J1 Fujifilm X-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Sony a77 II +1 more
kehoutek New Member • Posts: 15
I just acquired the p100-300 and was also surprised at OOF shots. I think, however as one poster said, at the long end of telephoto with a subject moving, and at slowish shutter speeds, you are more than likely going to get soft, unless you get lucky. I do think this lens can be sharp, however, as i caught this squirrel pausing for a moment and shot him. Out of 7 s-af frames at 300mm only when he paused did it nail the focus: (heavily cropped to 1100-1600 as well, his paws are a little OOF because he was busy with them but i think the rest of him is in focus)
not sure if exif will show but it's 100 iso at 5.6 1/400 at 300mm
 kehoutek's gear list:kehoutek's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Voigtlander Nokton 25mm F0.95 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +5 more
Telephoto lenses that still produce a sharp image under those circumstances are exceedingly rare.
