Nailing (auto-)focus with the Panasonic 100-300?
Started Apr 3, 2016 | Discussions
(unknown member) Regular Member • Posts: 348
How can I _reliably_ nail auto-focus with the Panasonic 100-300 or with any other long lens, on an Olympus E-PL7?
Take, for instance, the first photo below. The camera was configured for S-AF. The focus area is constrained to the middle of the sensor area. And the Olympus EXIF indicates that the camera set the focus point splat on the shoulder of that gentleman (Danny McAskill of Youtube fame, in case you care).
The ORF original's EXIF claims a depth of field of 5.65 - 6.36m (focus distance: 5.98m).
So ... what can I do to get focus in these cases?
My challenges are:
1) I am unable to verify focus in the (large, bright!) VF-4 electronic viewfinder; even the dpreview inline rendition of the photo will appear sharp, while the 100% rendition will tell the sad truth
2) The Panasonic 100-300 focus ring is not exactly helpful for me; this removes the S-AF + M option and also the pure manual focus option (which I would me happy to use!). Auto-magnification otherwise could be a pleasure to use
3) smaller aperture, for increased depth-of-field - well, yes, but then we get into higher ISO and the low light (not in this very specific case, granted), and the Panasonic 100-300 seems to positively hate small apertures
Just to demonstrate that the lens and camera are capable, I put in a second shot taken at 300/5.6 (a combination which people here claim as being totally non-workable). That makes it a depth-of-field of about 40cm at about 15m distance. Reproducing that or better, consistently, from an auto-focus point of view, that's what I would like to figure out.
Both shots are straight from ORF raw via Olympus Viewer 3.
If at all possible, please avoid telling me that the answer is the Panasonic 100-400 (at three times the cost of the 100-300).
Out of focus(?) at 100/6.7; 1/750
In focus at 300/5.6; 1/1000
Olympus E-PL7 Panasonic Leica 100-400mm F4.0-6.3 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
brick33308
brick33308 Veteran Member • Posts: 6,298
Re: Nailing (auto-)focus with the Panasonic 100-300?
neither of them are in focus
OP (unknown member) Regular Member • Posts: 348
What can I do to get better (auto)focus from my equipment?
SteveY80 Senior Member • Posts: 2,087
I don't think I've had much better results than that at 300mm f/5.6 with my GX7. The lens is just garbage at the long end in my opinion, certainly worse than my old Tamron 70-300mm on APS-C.
I haven't had a big problem with AF though, beyond the usual issues with tracking moving subjects using a contrast detect AF system. Does your 100-300 lock on accurately when aimed at a still subject?
Try putting it on a tripod, aim it at a well lit page of text, see if that's reliably focused upon.
 SteveY80's gear list:SteveY80's gear list
Nikon 1 J1 Fujifilm X-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Sony a77 II +1 more
Danielvr Veteran Member • Posts: 6,863
Not familiar with that combination, but you could try a smaller AF-point and focussing twice before firing the shutter (i.e. half-press till focus confirmed, half-press again, press).
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
gary0319
gary0319 Forum Pro • Posts: 10,540
It looks to me that both images are just soft, not out of focus. My P100-300 is sharpest at 286mm, but goes a bit soft after that. Also, I shoot it at f6.3, if I can.
If you are using the IBIS on the PL7, try using the OIS on the lens, it is almost as good as the 5 Axis on my E-M5 II, and most likely better than the IBIS on the PL7.
P100-300 on E-M5 II, focus point on bird in nest.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
Spectre38
Spectre38 Regular Member • Posts: 466
If you camera has a pinpoint focus point and touch screen you can typically touch the screen where you want focus and/or release the shutter by touch screen.
Additionally a more narrow aperature f8 or f11 usually does the trick, but 300mm is REALLY long. F7.1 is as far as you typically want to go to get good crisp images.
You may want to get as close as possible to reduce the focal length, so you have a wider DOF. The longer the focal length, the shallower the DOF.
At f7.1 its only 7' at 250mm at 100' and 10' at f11, so you really need to focus on a fixed point and wait for your subject to hit that point and fire off a burst with the mechanical shutter. Unfortunately, you want to be at at 1/400 or faster which can be a stretch at that aperature (pray for a sunny day).
Find a DOF calculator (photo tools app) and get familiar with the in focus ranges. As well as hyperfocals.
 Spectre38's gear list:Spectre38's gear list
Olympus PEN E-PL2 Panasonic Lumix DMC-G6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Sigma 30mm F2.8 DN | A Sigma 60mm F2.8 DN Art +4 more
Egregius V
Egregius V Contributing Member • Posts: 538
What I've read tells me that the 100-300, the 100-400, and the Oly. 75-300 can all have difficulty nailing focus with targets that aren't close to the lens. Not everyone's experience by any means, but also not necessarily user error. I have a lot of trouble nailing focus with my 75-300. Give it a very contrasty subject like paper full of text - or a reasonably contrasty target only a few feet away - and S-AF mode seems to nail focus easily enough. Otherwise, what works best for me is using MF assists like focus peaking and zoom after a half-press of the shutter with S-AF. Since you don't consider that an option, I suggest trying the touch-screen as Spectre38 said - or try a continuous AF mode to see if that helps. I find with my Olympus cameras and the long tele that C-AF can be more reliable than S-AF. It's not consistent, though.
You can play with aperture, face-detect settings, and focus box size, too. These have not made a difference for me personally, but YMMV. Good luck!
 Egregius V's gear list:Egregius V's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +17 more
Dabbler
Dabbler Senior Member • Posts: 2,038
I think the first shot focused on the parts nearest the camera, the forearm and the left hand. The lens can produce good results but it's not in the same league as Nikon or Canon pro lenses. I find I get good results if I shoot just short of 300mm and keep the shutter speed up. The lens wil hunt in continuous focus so BIF are most difficult. But good shots can be had. For the size of the lens it's an amazing focal length.
Michael
 Dabbler's gear list:Dabbler's gear list
Sony RX10 III Nikon D800 Sony a6000 Nikon 1 V3 Sony a7S +16 more
I am actually "OK" with the results of the 300mm shot, for focusing. That shot is not sharp, though, but that's that lens...
The (first) 100mm f/6.7 shot is my real problem, where the focus is definitely off from the intended point(s).
I am looking for ways to improve focusing.
Well, in this specific case (100@6.7), the subject was still - sometimes Danny McAskill just stands and balances on the bike. So, in this specific case, no, it did not lock accurately, from my point of view.
Generally speaking, though, the body/lens combination seems to be able to provide reasonable auto-focus in the 100-275 range (>275 somehow goes hunting ever so often, but will eventually lock somewhere, too)
The Olympus E-PL7 can be configured to a focus area, which I did. And, according to the EXIF information, the focus point was exactly where it was _allowed_ to be - on the shoulder.
(FWIW, Olympus bodies but focal length, pre-computed DOF information, and shot focal area information into the EXIF information of every photo)
The computed DOF of the 100/6.7 shot should have been 90cm (online calculator and EXIF data agree). _If_ focus as claimed by the camera had _really_ been on the shoulder, then a whole lot more of the arm, the helmet, and the face would have been in focus.
That behaviour irritates me. Shot focus point as indicated by camera is in a "good enough" spot. Subject is more or less static. DOF should be large enough to get "something" out. I would expect this to be focused much better, then.
Egregius V wrote:
what works best for me is using MF assists like focus peaking and zoom after a half-press of the shutter with S-AF. Since you don't consider that an option, ...
Well, I'd love to use manual (assist) focus on the Panasonic 100-300, but the focus ring, from my point of view, leaves a lot to be desired.
The haptics might well be different on more substantial bodies than on my Olympus E-PL7, but in my case, the focus ring of the Panasonic 100-300 is all but smooth, making fine adjustments next to impossible. Others have reported that, too, so it seems to be a design property of the product.
According to the EXIF, the focus point is on the shoulder. With a DOF of about 90cm, much, much more (30cm+ = helmet at least) should have been in (better) focus.
I am lacking the means to compare, but I am not unhappy with the Panasonic 100-300, at all.
At EUR 365 (USD 420) new and delivered for that lens (that's what I paid), with OIS, small size, light weight, incredible range, I do consider that a viable purchase option.
Yes, the Panasonic 100-300 could have larger apertures throughout the zoom range, could be sharper, could focus faster, could hunt less at the very long end, could shoot faster in drive mode, could be weather-sealed, could have better haptics (I hate the manual focus ring). Which, I think, serves to justify the existence of the brand new Panasonic 100-400, at a current price point of EUR 1700 or thereabouts.
mike_smith_uk Regular Member • Posts: 390
Shooting at 300mm is the equivalent of 20x magnification i.e. ts like handholding a small telescope .  Subject movement no matter how small is hard to counteract at these magnifications.  Unless your panning technique following the subject is perfect the subject will not be in a constant position in the frame.  What you are seeing is softness from subject movement.  IS only stabilises the camera from movement not the subject n the frame, it cannot magically track the subject and maintain sharpness.
Try using a monopod it helps keep panning action smoother than hand held panning.
mike_smith_uk wrote:
Shooting at 300mm
Thanks for your feedback - and I begin regretting having introduced the 300mm shot
My challenge is getting the point of focus right - as evidenced by that first, 100/6.7, shot. That shot is stable and at 1/1000, just plain and simply out of focus, misfocused by the AF system. I am looking for ways to address that.
bjorn43 Regular Member • Posts: 108
Don't put the Pana 100-400 in your list!
Have now shot over the 3000 long range shots and every time the focus was nailed, so fast that focussing and taking the shot just in the time by pressing the shutter.
Even little birds just with the head out of  the grass, I got direct in focus.
 bjorn43's gear list:bjorn43's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye +5 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
I understand your frustration and am beginning to wonder if this is where M43 cameras fail badly?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
The sharpnesss standard underlying 'depth of field' is rather arbitrary and for your EPL7 works out to a pointsource projection of four pixels in diameter. In other words, DoF may not be for pixel peepers. Plus, it assumes that focus was really nailed, which it most likely wasn't when you shoot a moving person through a handheld supertelephoto lens.
Maybe you shoot start by establishing the sharpness of your lens by shooting something static at similar distance, aperture, etc, using a tripod and electronic shutter. Then you'll know what kind of sharpness is possible. From there, you can figure out how to achieve it in practice.
LMNCT Veteran Member • Posts: 4,908
The 100-300 is not "garbage".  The trick to getting sharp results at the long end is to use an aperture like 7.1.  As for the auto focus problem, it depends a great deal on the body that you mount the lens on.  I had a Panasonic GX1 and had a hard time getting the auto focus to operate quickly.  It hunted like a beagle before settling down.  On my GX8 and GH4 the auto focus is fast and accurate.  I think that it depends a lot on the body.  My cure on the GX1 was to focus manually and that worked quite well.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
One more thought about attaining auto focus and sharp results at the 300 end.  Remember to support the lens from below with your left hand.  It may sound simple, but it makes a big difference.  If you are using the LCD and holding the camera out to compose and focus, you may not have adequate support.
