Olympus 14-150, 40-150 pro and 70-300. Comparison at 150mm
Apr 3, 2016
8
OK, So I've got three lenses which will all cover 150mm focal length. I thought I'd give them a controlled comparison. It may help others see what sort of image quality you get for your money when buying each.
The lenses are the Olympus 14-150 MkI, the Olympus 40-150 f2.8 pro and the Olympus 70-300. The camera was an Olympus EM1.
The test was shot using a map as the subject. This has fine detail and also grid lines which help line everything up and get the camera fully parallel to the subject.
All images were shot using magnified autofocus (smallest focus area), the same manual white balance, the same manual exposure, antishock shutter release, contrast and sharpness set to camera defaults of 0, noise reduction set to off and ISO set to Low (100). Lighting was by bounce flash to keep things consistent. The camera was mounted on a sturdy 3 series Gitzo tripod with Arca Swiss Head and with image stabilisation turned off.
All images are out of camera superfine jpegs and shading compensation (vignetting correction) was set to on.
Before showing the images there are a number of things that are striking from this test:-
1 - There is little practical difference at the centre of the frame between any of the lenses. if you are primarily only interested in the sharpness at the centre of the frame and do not need anything wider than f5.6 then the little 14-150 walkaround lens will serve very well at this focal length. But, if you need detail out to the edges then the 14-150 is a bit of a disaster.
2 - The 70-300 holds up extremely well at the edges of the frame (other than in the bottom right where my copy is clearly de-centred... perhaps I should have done this test when I first bought it rather than waiting for 2 years!!).
3 - The 40-150 pro is sharp all over at f5.6, putting in a superb performance. But what is more striking is how well it holds up at f2.8. There is some fall off at the left side of the image, but nothing that would really trouble anyone producing images to actually look at rather than pixel peep.
So here are the photos:-
Olympus 14-150 MkI. 150mm at f5.6
Olympus 40-150 pro. 150mm at f2.8
Olympus 40-150 pro. 150mm at f5.6
Olympus 70-300. 150mm at f5.7 (doesn't quite achieve f5.6 at 150mm)
