Travel with mFT. Advice on lens/body choice.
Started Mar 31, 2016 | Questions
gotoole Contributing Member • Posts: 524
This is really a 'first world problem@ but here goes-
I upgraded to mFT from FT early this year. As it happened, I bought an OMD-em10 ( mark 1) body only and an EPL6 kit, just to get the lenses. At the same time i was offered a GX1 secondhand at very good price ( €90) . Since then i have added the Oly 45mm 1.8 and a second-hand Panasonic 20mm 1.7.
I am plainning a motorcycle trip next month and i want to take a light travel kit. Originally, I was thinking of the em10 with the kit 14-42mm lens. However, with the lenses now available to me I am thinking that either the GX1 or Epl6 with the Panasonic 20mm would make a nice small travel kit. Bear in mind that space really is at a premium when traveling on a motorcycle.
Ideally I would take only one body and one lens. I am most familiar with the OMD-em10 but I can learn either body controls before travel. I have only just bought the 20mm a couple of days ago but I like what I see, sharp and bright, but the 14-42mm kit lens might give me more flexibility.
i would be interested in any advice. I would likely use the camera only when i stop for a day or two so probably street photography , architecture etc. would dominate but i would obviously have the odd landscape-panorama on the way as well.
Any suggestions or advice when space is so limited would be much appreciated.
Olympus OM-D E-M10 Olympus PEN E-PL6 Panasonic Lumix DMC-GX1
Robiro Veteran Member • Posts: 6,813
Re: Travel with mFT. Advice on lens/body choice.
Did you consider Panasonic 14-140mmII?
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Olympus 40-150mm F2.8 Pro Olympus 100-400mm F5.0-6.3 IS Panasonic 12-35mm F2.8 Sigma 30mm F1.4 for Micro Four Thirds
Felice62 Veteran Member • Posts: 5,079
given your statement I would consider Olympus 12-50, which gives you more margin on both ends.
Not a spectacular one but it'll get the job done.
Ride safe!
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Tough TG-3 Olympus Stylus Tough TG-850 iHS Panasonic ZS100 Olympus E-M5 II +36 more
OP gotoole Contributing Member • Posts: 524
Felice62 wrote:
I....
Ride safe!
Thanks Robiro and Felice62.
To be honest, i really don't want to buy more lenses , rather i want to pick from what I aleady have.
However, I will buy if I am getting a lens wjich is better than what i have already. Are these zooms  better than the kit lenses. ?  While i do like to shoot long, and have the old Oly 70-300mm , I don't think I would make use of long tele lens on a trip like this.
By the way, I intend heading to Gdansk, , maybe Kallinigrad, but i don't expect the destination will affect lens choice.
LMNCT Veteran Member • Posts: 4,908
GX1 with 20 1.7.  You may wish that you had something wider (like the 14-42 latest version).  The Olympus 45 1.8 weighs nearly nothing and it is small so you should be able to tuck it in somewhere.  Have a great trip.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic G85 +23 more
Andkar Regular Member • Posts: 441
I have bicycled across South East Asia and Central America and I skateboarded across the Australian outback from Darwin to Alice Springs.
I carry the 9-18, 20/1.7 and 45/1.8. I find it is the ultimate travel kit for my taste, and I am pretty sure it will fit on your motorbike.
If I hade to choose only one lens I would choose the 20/1.7
I don't think the 14-42 kit lenses are wide or long enough compared to the 20 and I would not carry one even if I didn't have the 9-18.
I hope you have a great trip!
ThePalindrome Regular Member • Posts: 477
I'm a light traveller and often have to select my gear, when I'm hiking, travelling or sailing. It's why I got the GM1.
From your gear the minimal choice would be the PL6 (newer than GX1, some stabilization, smaller than EM10) with the 20mm (small, fast, normal FOV). From there you can build depending on the space available and your desires.
Do you want to exchange space for features, then take the EM10.
Do you gain from having a fast (mild) tele, so it makes sense to spend the space there.
Or is the convenience of the zoom worth the space you have to expend for it?
Depends on how little space and important those capabilities really are.
 ThePalindrome's gear list:ThePalindrome's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus XZ-1 Olympus M.Zuiko Digital 45mm F1.8 +1 more
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Panasonic 12-32.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus E-M1 Olympus PEN E-PL2 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +13 more
Mebpenguin
Mebpenguin Contributing Member • Posts: 671
Em10 with 20 1.7. I'd try to squeeze the 45 in as well just to give you some flexibility. Use your phone for landscape shots.
 Mebpenguin's gear list:Mebpenguin's gear list
Panasonic G85 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-60mm F3.5-5.6 OIS Panasonic 100-300mm F4-5.6 II Sony Cyber-shot DSC-HX90V
Tom Axford Forum Pro • Posts: 10,097
For compact kit, I like the GM1 + 12-32 and the 35-100/4.0-5.6 for modest tele as well. Stunningly good image quality (particularly the 35-100) and the whole lot is quite remarkably small and light. These lenses also work as well on the larger bodies.
FaFik
FaFik Regular Member • Posts: 147
gotoole wrote:
Felice62 wrote:
I....
Ride safe!
For the narrow streets of Gdańsk old town you may need wide angle.
Maybe Panasonic 12-32? Slower, but even smaller than 20/1.7.
 FaFik's gear list:FaFik's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital 45mm F1.8 +5 more
Chas2 Veteran Member • Posts: 3,715
Re: Only you can decide. EM10 and 14-42 most flexible
Of course, only you can answer this question, based on the kind of photos you are interested in.
Space being at a premium, I would go with your instincts, the PL6 or the GX1 and the 20mm. It gives you a generalist lens and low light capability. But the EM10 is the most capable of the bodies you have, and is it really that much bigger? Maybe with the 14-42...but it covers most of your bases.
I like the 20 mm immensely and would not hesitate to always have it with me. When I go light, I take my GM1 and the 20mm. I might take the 12-32 (or the 14-42 in your case) if I knew low light situations would not predominate...but usually I take the 20 for indoor situations, and it doubles well as an outdoor lens.
The ultimate travel lens kit would be a Panasonic 14-140 Mk II superzoom and a small and light lens, either the 20/1.7 or the 17/1.8 or the 15/1.7
This graphic might help you decide, No PL6, but the PL6 is slight redesign of the PL5 shown.
http://camerasize.com/compact/#183.30,382.30,382.92,521.30,521.92,ha,t
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +12 more
baxters Veteran Member • Posts: 5,319
You already have the EPL6. Take that with the 20mm.  The 14-42 isn't that hard to pack.  You have to bring the charger and cord anyway, and they take  more space than the kit zoom. Maybe you have time to get a small 3rd party charger.
It's always fun to own more stuff when you're at home, but don't be looking to buy another camera or a lens, just for this trip. You already have two cameras.
I have more than two cameras. I would pack my GM1 with its 12-32 zoom and the 20mm.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
ramcewan Regular Member • Posts: 143
E-M10 w/both all three lenses, the 20mm is tiny, the E-M10's viewfinder may prove helpful in bright light and the 14-42 is good and gives you extra wideness for landscape but not going to do low light like the 20mm and 45mm.
 ramcewan's gear list:ramcewan's gear list
Olympus E-M1 Olympus PEN E-PM2 Olympus 7-14mm F2.8 Pro Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +4 more
Mark Thornton Veteran Member • Posts: 4,570
Where would you carry your kit
I sometimes take my GX1 and a lens in a winter jacket pocket. If necessary, another lens or two can be hidden in other pockets. I'm sure this would work with the e-pl6 too. The hump on the e-m10 may make this more awkward, but you can easily test it.
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 +8 more
aliasfox Senior Member • Posts: 1,375
Can't really go wrong with any of your kit, to be honest.
I'd probably pick the E-M10 body:
- The body itself is the same size as the E-PL6, just with the EVF permanently attached
- Better stabilization than the E-PL6
- Better dynamic range and low light than the GX1
As for lenses, I've walked around foreign cities with just a 17mm and a 45mm. The 17mm wasn't quite wide enough in the narrowest streets and smallest squares in Stockholm, but it also allowed for some interesting perspectives as I tried to squeeze everything I wanted into the frame. The 45mm was definitely useful when I wanted something longer - and with a 2x digital crop, you can get 90mm (180mm eFL) out of 8MP, which is plenty functional on the long end. The primes also let you shoot indoors and into evenings courtesy of the larger apertures.
The 20mm is a pretty close analogue to the 17mm, so I'd probably go with a 20mm/45mm kit. Just avoid under-exposing and pulling shadows too much on the 20mm and you should be fine (potential for low light, high ISO banding).
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
baxters wrote:
... You have to bring the charger and cord anyway, and they take more space than the kit zoom.
Wanted to point out a thread I just put up on how you can replace the cord on the Olympus charger with a small plug adapter which reduces size by a good amount.
http://www.dpreview.com/forums/thread/3985789#forum-post-57529850
jimrpdx
jimrpdx Veteran Member • Posts: 3,956
Michael M Fliegel wrote:
Panasonic 12-32.
This ^ on an ePM2-type body will serve you well. Add a small prime (sigma 30 or 60?) for longer shots and call it good!
Jim near Kelso: Friend of K and NX - - http://granitix.blogspot.com
former sonyalpha & micro43 user
 jimrpdx's gear list:jimrpdx's gear list
Pentax K-S2 Sony a7 II Olympus E-M1 Panasonic 12-60mm F3.5-5.6 OIS Panasonic 100-300mm F4-5.6 II +2 more
Chris Prinos Regular Member • Posts: 195
The digital crop may help w/ visualization, but the resolution hit is bigger than you suggest. A 2x crop will cut your resolution by a factor of 4x (so, 4 effective MP, not 8MP).
You're right. I avoid doing work that requires thinking in the morning (paperwork and emails instead), it looks like I should avoid writing posts that require thinking, as well.
I've seen other members of this forum swear by the digital teleconverter in-camera; I usually just crop in post processing to get the framing I want. Either way, a 45mm lens on a 16MP sensor should give a fair amount of working room for someone who likes working in short-telephoto.
