Do I in fact have no options BUT to keep the 20mm?
Started Mar 30, 2016 | Questions
TheClueless
TheClueless Senior Member • Posts: 2,140
I hate it's molassesness(sic).
But looking around, I don't feel a 17mm is a sufficient differentiator to the 15mm. 15-vs-20, yeah, definitely a home for both. 15-vs-17, I'm struggling for justification. And at the same time as a prime-first user, there's too big of a gap between the 15 and the 25.
So am I stuck with it as an inbetween to the 15mm and the 25mm?
 TheClueless's gear list:TheClueless's gear list
Leica Q2 Leica M10 Panasonic Lumix DC-G9 Sony a7R IV Sony Cyber-shot DSC-V1 +71 more
Bhima78 Senior Member • Posts: 2,850
If you like that focal length...
Then yes, stick with that lens. You could get the Sigma 19mm but you would be sacrificing aperture speed for AF speed.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
TheClueless
OP TheClueless Senior Member • Posts: 2,140
Re: If you like that focal length...
I figured as much. If I had something wider than a 15 and then had the 17-25 setup then I'd probably be happy, but I really like using the 15 and that's as wide as an everyday-shooting lens I want, so that's unlikely to be making an exit anytime soon.
Steve_
Steve_ Senior Member • Posts: 2,876
Re: Do I in fact have no options BUT to keep the 20mm?
I agree, on Oly bodies AF is pretty pokey. But I like it on the whole, being so compact and sharp.
Since you've got a Panasonic body, you probably should just tough it out. However slow you perceive it on your GX8, it's vastly slower on an Olympus body.
It was questions like these that led me to buy a 12-35, which I see you also have. I have the 17 Oly, and what annoys me about it is certainly not the focal length - it's the magic 35mm equivalent. But the IQ is worse than the 12-35, with color fringing and only average contrast and sharpness.
I sold my 20 when I bought a 25, as I never really liked the focal length despite the fact I really liked the optical performance and size. Growing up with 35mm SLRs, I like 14/17/25 combo, but these days I use the 12-35 as the primary shooter and usually only carry one prime in addition to the 7-14/12-35/35-100 trio. In that context, it's not so critical to have every prime made (although I have most of 'em nonetheless).
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G 14mm F2.5 ASPH +13 more
TheClueless
urk
Wow. Really? The 20 is at least OK imaging-wise. I'm pretty sure I had the 17 before but I don't remember it being that bad - mind you, I was never that enamoured of m4/3 anyway (and I'm still not totally convicingly sold) so maybe I just had low expectations.
I hate to sound like I have muscles of jello but I just feel often encumbered with the 12-35. It's less the all-up weight, it's more the balance of the system. I generally dislike long-ish lenses unless I have to use them - and even when shooting with the 12-35 I actually rarely go 35. I guess it's a Leica habit lol
Steve_
The 20 has always been one of the sharpest native m43 lenses. It's got a bit of purple fringing with back-lit subjects and suffers a bit in the corners for being a pancake, but most of its faults aren't terribly field-relevant and its excellent sharpness and contrast certainly are.
That's why the Oly 17 hasn't been a runaway hit. It's not got that killer prime sharpness people have come to expect in any prime these days, and it has pretty serious fringing issues (which are the primary cause of the average sharpness). It does have terrific build and AF, and competent optics. Just not stellar in the way of the 15 or 25mm Panasonics.
I hate to sound like I have muscles of jello but I just feel often encumbered with the 12-35. It's less the all-up weight, it's more the balance of the system. I generally dislike long-ish lenses - and when shooting with the 12-35 I actually rarely go 35. I guess it's a Leica habit lol
I shot with an APS-C Pentax DSLR with their DA*16-50/2.8 as the primary before going m43. In that context the 12-35 is still tiny. I resisted the urge to replace it with a 12-40 Oly for reasons of bulk, however - my bad back precipitated the switch to m43.
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
you do have the option with the sigma 19 2.8 as you got a modern camera that can handle using a higher iso. it is short. if you need something brighter you got that in another lens.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
(unknown member) Veteran Member • Posts: 9,509
If it HAS to be 20mm then it is your only native prime choice but Canon EF mount lenses adapted work well on many M43 bodies for AFS at least (they are lousy for AFC but so what......the 20 may well be worse).
tkbslc Forum Pro • Posts: 17,527
5
To be honest it seems a little odd that you would want to cover every tiny little step with primes.  15 and 20 are very close.  15 and 25 is almost too tight of a progression.
The goal of primes is not to try to get enough that you have a zoom lens.  You generally cover a few key focal lengths and not worry about tiny framing differences.
Ulric Veteran Member • Posts: 4,559
https://www.youtube.com/watch?v=Voy9PylOMY4&feature=youtu.be&t=4m26s
As for the "molassesness", I benchmarked my 20 against my 12-50 at 20 outdoors and indoors and the difference was <0.1 s. Just don't let it hunt.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
TheClueless
Ehhhhhh... I did say in a previous post elsewhere I'm not totally sold on m4/3, but one thing I'm defo not convinced by is the high-ISO performance of the m4/3rds sensors. If I'm using a prime I'd definitely like that stop (or more).
TheClueless
Not to me. There's definitely a worthwhile compositional difference, and I also just like using the 15 so comparisons / what else to get are drawn from that point.
The goal is to pick the lenses that will suit your intended framing the best. You do not - or at least I don't - have to walk out with your entire collection. There's over-duplication, but there's also having options.
Wellington100 Forum Pro • Posts: 11,807
Enjoy it for what it is, surely not every image requires a lens that snaps to focus in a tiny fraction of a second.
Doctors are bad for your lifestyle!
 Wellington100's gear list:Wellington100's gear list
Ricoh GR Panasonic Lumix DMC-GM1 Fujifilm X-T1 Panasonic Lumix DMC-GX85 Fujifilm FinePix S100fs +12 more
TheClueless
Well - it's a case of what I'm used to, having a relatively extremely slow lens like the 20 is jarring.
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Try wider.  Get the 12-32😀.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
TheClueless
I have a feeling we've met in another thread concerning the GM1 lol
jonnieb
jonnieb Contributing Member • Posts: 615
I would look at it differently. 20mm is perfect when you only want to take one lens, and 15 and 25 are perfect when you want to switch it up with two lenses.
General rule of thumb is primes at 2x multiple of focal lengths, so 15 + 25 work well. Unlikely you would need something in between.
Jonnieb
 jonnieb's gear list:jonnieb's gear list
Olympus PEN E-P5 Olympus PEN-F Olympus OM-D E-M1X Olympus E-M1 III Olympus Zuiko Digital ED 50mm 1:2.0 Macro +16 more
FrankS009
FrankS009 Veteran Member • Posts: 6,557
Everything old is new again. Whether the 20mm is slow focusing is a subject debated innumerable times in this forum, and 99% of the time the focusing of 20mm is fine. For me anyway.
The issue of focal length is another matter. It would be nice to have a 10.5mm, a 12mm, a 15mm, a 17.5mm, a 20mm, a 25mm, and a 30mm, but as Jonnieb says, the 2x times rule is a practical one. Am looking forward to learning about the new Panasonic 12mm. It might make a good combination with a 25mm. In the meantime, the 20mm is on my carry-everywhere body.
F.
"We shoot the things that move us in ways that will move others." David duChemin
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GF1
Henry Richardson Forum Pro • Posts: 21,959
For primes I have the P 14mm f2.5, P 20mm f1.7, O 25mm f1.8, and O 45mm f1.8.  I like the 20mm quite a lot, but bought the 25mm for travel since the 20mm occasionally can cause banding at higher ISO.  I still use the 20mm a lot while not traveling though when I am out and about during the day.
Anyway, the 14mm, 25mm, and 45mm are a pretty nice combo since the fl spacing is very similar and each is quite different.
Henry Richardson
http://www.bakubo.com
