Canon Powershot SX710 HS not connecting to MacBook Air
Started Mar 29, 2016 | Discussions
MstrMAH New Member • Posts: 2
Hi all,
I have recently purchased to Canon Powershot SX710 HS. At home, I was able to easily transfer Images  as well as movies as my camera connected to my laptop. I am now on holiday and have connected both the camera and the laptop to the same network but I keep getting the same message, 'Device not found.' I have tried and failed numerous times to upload my photos and videos onto the laptop but without success.
If you have any idea on what I should do, I would be glad to hear, as I need to free up some space on my camera for more photos and video.
Thanks!
Canon PowerShot SX710 Olympus Air
lorenzo Regular Member • Posts: 319
Re: Canon Powershot SX710 HS not connecting to MacBook Air
What about transferring the photos the old-fashioned way-- via the memory card, either directly placed in the Air (that is, if compatible card), or using a memory card reader, even if you have to buy one?!
Or, maybe even simpler, a USB cable attaching the camera to the Air?!
Those old-fashioned, direct methods have a lot going for them!
Good luck with it-- and enjoy your holiday!
Mark B.
Mark B. Forum Pro • Posts: 29,745
Card Reader...
MstrMAH wrote:
Hi all,
Thanks!
Really, if all you are trying to do is transfer photos pick up a card reader if you can.  Yes, I understand it's another piece of gear but they're very small (especially if you get an SD reader that plugs directly into the USB port w/o a cable), and will work universally on any computer.  It will also transfer faster than from the camera.
Mark
OP MstrMAH New Member • Posts: 2
Unfortunately, there is no SD card slot in the air and it seems that canon is intent on solely providing you with a Wi-Fi transferring camera as there was no USB cable that came with the camera.
I think it is just a matter of the camera already being used to transferring on one network. Which is a problem canon needs to fix.
Mark B.
So do as I suggested and get an external card reader.
