Should I Be Worried?
Started Mar 28, 2016 | Discussions
kreygscott
kreygscott Senior Member • Posts: 1,285
I noticed this space in my T1i while on a wedding shoot. It seems like there's a piece of rubber missing from this section as shown in the photos. Has anyone else experienced this and should this be something I need to worry about?
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
Yowie Wowie Senior Member • Posts: 1,166
Re: Should I Be Worried?
That hole (which the missing bit of rubber covered) is for the cable that goes from the AC adapter to the DC coupler (Canon ACK-E8).
It means that it is now easier for dirt/liquids/bugs to get into your battery compartment. Plug it up with something if that bothers you.
The actual Canon part number for the bit of rubber is CB3-4584 (or CB3-4584-000 000) if you want to replace it. T1i/500D parts manual. Page 8.
 Yowie Wowie's gear list:Yowie Wowie's gear list
Canon EOS 600D Canon EOS 70D Canon EF 50mm F1.8 II Canon EF 400mm f/5.6L USM Canon Extender EF 2x III +5 more
kreygscott
OP kreygscott Senior Member • Posts: 1,285
Thanks man. I think I'll just make a plug out of some rubber and seal it using some super glue.
I would use some kind of contact adhesive. Easier to remove, with greater shear strength. Super glue is messy, and useless for shear.
R2D2 Forum Pro • Posts: 26,551
+1 Super Glue has sheer strength, and not shear strength.
Good luck,
R2
kreygscott
Good luck,
R2
Okay so I took the decision to use both an adhesive and superglue. I have no intention of using a battery cable so I decided to just seal it. I used a light adhesive to lock it into place then placed a small drop of superglue on the inside to seal it. No mess whatsoever. And ... I also noticed this on my 350D which I also fixed.
The result on the T1i:
