Canon 24mm/2.8 IS USM vs. ???
Started Mar 26, 2016 | Discussions
maxx32 New Member • Posts: 21
I am thinking about a path of several discrete primes vs. a large zoom.   I am starting by considering the Canon 24mm/2.8 IS USM.
I have seen the test results and comments at Photozone and other sites.  Here, I have a question for those of you that might have this lens: how does it compare to other options for real-world use?
For example, I have the 24-105mm L.   Do you notice a difference @24mm?
Or I could consider the 16-35mm/4 L IS.  How would this compare @ 24mm?
The Canon 24-70mm/2.8?
Considering the sister lenses 28mm/2.8 IS and 35mm/2.0 IS, are one of these maybe a better option as a starting point?
I am particularly curious about contrast, as this is often not discussed in the reviews that I have read.
The goal here would be a smaller/lighter 6D+lens combo.   (I understand that I am giving up weather sealing and would have more lens swaps to manage)
Thanks!
 maxx32's gear list:maxx32's gear list
Canon EOS M Canon EOS 6D Canon EF 400mm f/5.6L USM Canon EF 70-200mm F4L USM Canon EF 24-105mm f/4L IS USM +1 more
Canon EF 24mm f/2.8 IS USM Canon EOS 6D
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: Canon 24mm/2.8 IS USM vs. ???
I can truly appreciate wanting to shoot lighter with a fixed lens, but it is a massive pain in the keister to carry around a bag of primes which more than offset the weight savings.
The high-end Canon primes compare favorably, even superior to, most fixed lenses. Contrast, resistance to flare and distortion are really excellent with the 16-35 f/4L IS, 24-70 f/2.8L II and 70-200 f/2.8L IS II. They generally aren't as fast or light as the primes, but I only use a couple of specialty primes anymore: the 100mm macro and 300 f/2.8.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
LuKa7482 Junior Member • Posts: 25
maxx32 wrote:
[cut]
[re-cut]
I do not own this specific lens, so I will only answer to one of your questions...
If you are looking for a lightweight kit, I'm not sure that the difference in FOV between the 30mm you already own and the 24mm is so worth it to carry around both. Let's be honest, I'm a compulsive owner of lenses, so I do not mean you shouldn't buy one!
But, if you'd like to carry around a limited number of lenses (otherwise the zoom becomes a better solution to stay light ;), only wide angles might not be enough in much situations. Considering the lenses you already own, I'd rather think to a longer portable lens before to build a twins wide combo. What about a 50mm STM (very light and cheap) or even better an 85mm (a bit heavier but more useful when you look for something longer than 30mm)?
In the other hand, if you are searching for a lightweight alternative to your 30mm, then probably the 24mm will perfectly do the job. In such a case, I'd recommend you to pair it with a 40mm, which stays in any of your pockets, offering you a very nice and portable kit.
I assume here you don't look for L lenses, as otherwise the weather sealing is present on a marvelous lens called EF 24mm f/1.4L II No IS but with an f/1.4 you'll often won't miss it...at least, I do not!
Hope those thoughts helped you somehow...
 LuKa7482's gear list:LuKa7482's gear list
Canon EOS 70D Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 200mm f/2.8L II USM +24 more
Phil Geusebroek Contributing Member • Posts: 622
I used to carry a very small bag with 24mm/50mm/100mm macro. Reasoning was that UW/normal/tele zooms would still need a lens change. I found that I loved getting to know and pre-visualize composition. I did change lenses a lot, and found that sometimes I got caught in a fixed position. The advantages of cost, extra sharpness, speed, and compactness were really nice.
Now I would go 24mm IS, 35mm IS, and 100mm IS if doing the trio.
The 35mm f1.4/135mm f2 combo is wonderful but IS is missed if you want f/8-16. On a tripod it doesn't matter.
Also, lately I've used the 24-105mm IS and 35mm f/2 IS as a pair. It's fantastic as you only change lenses when the lights go down.
arty H Senior Member • Posts: 1,546
The 35F2IS is a great general purpose lens on the 6D. It has excellent contrast, fast and accurate AF, superb flare resistance, and the benefits of F2. The Sigma lens is crop only, if my memory serves correctly, unless Sigma has come out with a full frame version of this lens.
I use the 35 on full frame for everything from people to architecture. It is a great focal length on full frame. I find the shorter focal lengths a bit too wide for people photos, but this all depends on your preferences.
OP maxx32 New Member • Posts: 21
Thanks for the feedback so far.
FYI...My focus is full-frame, having just picked up the 6D over the holidays.
I liked the balance/size/weight of the Sigma 30mm on the T3i/600D, and this is part of my interest in getting something similar on the 6D.   (I was also happy with the IQ of the 30mm, and think I may have a good copy).  I did just buy the 50/1.8STM to play around with, but so far I think I will want something wider.
Sorry for late answer...luckily you already made your choice. Didn't got you were moving to FF...
I own the quite old 20mm f/2.8 USM. It's a very nice lens if you like wide, which would give you a very close FOV to your 30mm. if you have a bigger budget, the 24mm f/1.4L II is an excellent lens: I hardly remove it from my camera since I got it, event though is slightly too wide for me (I prefer the FOV of the 28mm on my 70D, but the image quality and the f/1.4 make the deal more than worth it!).
I know I'm only talking about lenses without IS, but to be honest I never missed it on wide lenses.
Enjoy shooting.
