Thanks to the previous owner! (and my LCS too) [pana 14mm F2.5]
Started Mar 26, 2016 | Questions
Martian Flatcat
Martian Flatcat Regular Member • Posts: 457
Saw on their web site that my LCS got in a used Panasonic 14mm F2.5, so popped in on my way to work to check it out.  It's the v1 version of the lens, and it appears to be like new.  Seemed sharp on my camera, so I snapped it up!
Questions:
1. I see in older threads the statement that the v1 and v2 vary only in cosmetics.  Is that correct?
2. Anything I should watch out for using it on my E-M10ii? it's my first non-Oly lens.
3. How much distortion does the GWC1 wide converter add?  I'd like to get one and use the combo for astro if possible.
Thanks in advance for any advice given.
Also thanks to the previous owner of this lens for taking such good care of it and then trading it in.
--Flatcat
 Martian Flatcat's gear list:Martian Flatcat's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G 14mm F2.5 ASPH +7 more
Olympus OM-D E-M10 II Panasonic Lumix G 14mm F2.5 II ASPH
addlightness Veteran Member • Posts: 3,641
Re: Thanks to the previous owner! (and my LCS too) [pana 14mm F2.5]
I bought my 14mf2.5 used too.  It's on my GM1 most of the time because together they form a stealth P&S street camera.  I also own a EM10.
As for wide converter, I bought a FujiFilm (see attached photo) which is 0.75x.  I believe the GWC1 is 0.76x.  In any case, from most reviews, they are comparable with a slight advantage towards the GWC1.  I also read the Sony wide converter works too - search dpreview.
Either one would give you a ~21mm equiv on top of the 'native' 28mm equiv.  I really like the combo.
GM1 + 14mmf2.5 + FujiFilm 0.75x converter = 10.5mmf2.5
Photo taken with above combo:
Levi's Stadium - GM1 + 14mm + FujiFilm converter
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
maggiemole Senior Member • Posts: 1,988
It doesn't add much distortion at all, even at short range. For astro, you'd never see it. I'm planning to use the combination in a week or two for some Milky Way shots, and will compare them to the 7.5mm fisheye - which will have some distortion for sure, but I don't expect it to be very noticeable. First I have to find the Milky Way .....
Maggie
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
baxters Veteran Member • Posts: 5,319
With and without GWC1.
In the USA, I note that the GWC1 is no longer carried by the big online retailers, so it's only available at prices much higher than what it cost new. That's a shame. It works well.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
captura Forum Pro • Posts: 27,478
I have the v. 1 of the 14/2.5 and it is awesome...a superior copy I guess. Use it on my E-M10 and E-PM1.  I also have the wide adapter, and absolutely no problems there, either.
But for better quality yet, I prefer to use my .75X Sony wide adapter which was made for the crappy 16/2.8 NEX lens. The adapter is much more solid, larger and of very high optical quality. It just snaps onto the front of the 14/2.5.  Believe it or not!
 captura's gear list:captura's gear list
Sony Alpha NEX-7 Canon EOS Rebel SL1 Sony a7 Olympus OM-D E-M10 Canon EF 85mm F1.8 USM +3 more
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
f2.5 14mm -- it's a lovely lens. nt
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
