Sigma 30mm F1.4 DN is Horribly HUGE :(
Started Mar 25, 2016 | Discussions
Jorginho Forum Pro • Posts: 15,370
Made for APS-c -> no buy from me.
No text.
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
Robstar63 Regular Member • Posts: 212
Re: Sigma 30mm F1.4 DN is Horribly HUGE :(
I pre ordered the Sigma but on opening up decided to return it - it is far bigger than the Panasonic Leica and heavier
it is far bigger than the Sigma 30mm f2.8 (which is to be expected)
as for compromised design the Pana Leica was designed from the outset for M43 and I have read a huge number of posts on forums where it is highly praised for its rendering and bokeh - which indicates that it is far from a compromised design ( any more than any similar product will be a compromise due to size and cost issues)
whereas the Sigma was designed with APSC in mind and has been adapted for use with M43 -
which of the two is compromised !
 Robstar63's gear list:Robstar63's gear list
OM-1 Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Panasonic Leica 200mm F2.8 +1 more
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
5
Isn't it great how mFT has spoiled us on small, quality optics😀.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
Fredrik Glckner Veteran Member • Posts: 3,894
dennis tennis wrote:
well, it is made for APS-C sensor. If it is too big for you, don't buy it.
I would guess that the main reason for its size is not that it is made for APS-C, but rather that it (probably) doesn't need any in-camera geometric distortion correction (like the other Sigma prime lenses).
The Lumix/Leica 25mm f/1.4 requires distortion correction in post processing, which is a design compromise that allows them to make it much smaller and cheaper:
http://m43photo.blogspot.com/2013/10/lumix-leica-dg-summilux-25mm-f14-review_27.html (scroll down halfway)
gear1box Senior Member • Posts: 1,536
Fredrik --
Hmmm. Not so much. Our friends at Zeiss are perfectly willing to throw elements, weight, and cost into the optical formula to remove optical flaws. Here's what Photozone has to say about one of their 25mm lenses:
"The Zeiss Distagon 25mm f/2.8 produces a moderate degree (~1.7%) of barrel distortion. This is about average for a prime lens in this class."
A much better suspect for size of this lens is the exit pupil required to hit a 28mm APSC sensor image circle vs 21mm needed for m4/3.  The engineers in my office claim that, all else equal, mass and cost of an optical system vary with the cube of the diameter of the physical aperture (largest lens element).
 gary ray
Semi-professional in early 1970s; just a putzer since then. interests: historical sites, virginia, motorcycle racing. A nikon user more by habit than choice; still, nikon seems to work well for me.
 gear1box's gear list:gear1box's gear list
Nikon D810 Nikon D500 Panasonic Lumix DC-GX9 Samyang 14mm F2.8 ED AS IF UMC Nikon 85mm F1.8G +9 more
captura Forum Pro • Posts: 27,478
Agree, and that's what I said.
Glass optical quality factors aside, this should pretty much guarantee better results in the end.
 captura's gear list:captura's gear list
Sony Alpha NEX-7 Canon EOS Rebel SL1 Sony a7 Olympus OM-D E-M10 Canon EF 85mm F1.8 USM +3 more
Re: Sigma 30mm F1.4 DN is Horribly HUGE :( RIGHT FIRST TIME, PETER
LeitzKameraAktion wrote:
I have the original f2.8 version of the Sigma 30mm, and like it very much. I only wish it was a stop or two faster...
I have it too, and it is OK but the lens barrel binds when rotated. They corrected that with the newer 'ART' version.
So, the new Sigma 30mm f1.4 DN looked like the answer to my prayers. But you're right - it is 'horribly huge'; quite a bit bigger than the Pana/Leica and Oly 25mm lenses which I already own.
I didn't say that.
I was definitely considering buying one - but now I think I'll pass...
If, as I expect, the image quality turns out to be very much better, I will be buying one.
cerich wrote:
me too...then have the 2.8 collect dust
You could sell that one.
But I might use my 2.8 version for times when it's smaller size is convenient. And take the 1.4 out for times when more accurate/ low light shooting is desired.
inlawbiker Senior Member • Posts: 2,066
Re: That is too big
I had high hopes for this lens, too bad it's so big. If it's as good as the Sigma 50mm "Art" then it'd be fine. Since it's a "C" instead of an Art lens I kind of doubt that's the case.
 inlawbiker's gear list:inlawbiker's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
peppermonkey Veteran Member • Posts: 5,204
If it's significantly and noticeably ...
Better than the PanLeica 25mm 1.4 (and the others), and it's cheap enough, I would consider it, otherwise it's too large to be of any use to me.
007peter wrote:
"Horribly Huge" is an exaggeration, but after being spoiled by M43 tiny prime (switch from canon), I have lost my appetite for "Normal Size" lens.
Here is a comparison of Panasonic 25mm f/1.4 vs Olympus 25mm f/1.8, vs Sigma 30mm f/1.4 DN
http://camerasize.com/compact/#621.411,621.352,621.548,ha,t
on Panasonic G7 body
Hubert
My non-digital gear: Agfa Isolette, Ricohflex VII, Bessa R, Bessa L, Zorky 4, Fed 2, Konica Big Mini, Konica Auto S2, K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
morpheus777 Regular Member • Posts: 180
To quote Trump, "It's gonna be Yuuuuuge."
Seriosly though, it's not that bad, and the hood skews the visual comparison.
 morpheus777's gear list:morpheus777's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 35mm F2 R WR Fujifilm 50mm F2 R WR
MiraShootsNikon Senior Member • Posts: 1,068
Where's the Pana-Leica's Hood?
6
This comparison is completely unfair and borderline useless: the Pana-Leica is missing its enormous and non-reversible hood.
If the Pana-Leica were wearing its hood, it'd be just about the same length and functional width--the hood basically doubles that lens's size. You'd know this if you had one or had ever seen one.
That the Pana-Leica hood can't be reversed for storage is pretty meaningful information for this sort of comparison. If you're using the hood, there's no compacting the rig in your bag. If you do reverse your hoods, it'd possible for the Sigma (hood reversed) to be shorter or smaller in your bag.
Anyone else remember similarly unfair comparisons when the Olympus 25mm f/1.8 came out? I do. Lots of pictures of m4/3 rigs wearing the Olympus without its hood vs. those with the Pana-Leica, hooded-up and huge. Sure, the Olympus is still a lot smaller even with its (reversible) hood deployed--but why not just post an honest, useful comparison rather than jerking around with misleading half-truths and emotional rhetoric?
Now watch: someone will chime in about not needing or never using her Pana-Leica hood, and the otherwise relentless lenshood police--who've shot themselves in the foot by declaring this comparison legit--will be mysteriously quiet . . . .
Ugh.
 MiraShootsNikon's gear list:MiraShootsNikon's gear list
Nikon D850 Sony a7R III Sony a9 II Carl Zeiss Distagon T* 2,8/21 Carl Zeiss Makro-Planar T* 2/100 +11 more
007peter
OP 007peter Forum Pro • Posts: 12,933
Mira, I didnt make the photo.
No, it's a FAIR comparison. If you visually Cut Away the hood. Sigma is still almost 2x taller than Olympus 25mm F1.8.
Go ahead crying fauls & make all the excuses you want. You CANNOT TWIST THE REALITY THIS IS A BIG LENS.
I get it, you like the lens, and so DID I before I saw the comparison photo. You should take the Complain to CameraSize.com, for putting up a photo of a Sigma with a hood on.
Also, I am one of those people who shoot with it a hood. I never have any flare unless light it Shrining directly onto my lens, which I rarely do.
Nonetheless, you can visually removed the hood and the Sigma is still unnecessary big.
More importantly, the lens appear to be similar if not bigger than old Sigma 30/1.4 DC for the DSLR. This us rather disappointing to me.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
(unknown member) Senior Member • Posts: 1,001
Re: Where's the Pana-Leica's Hood?
5
Ugh.
There, there... Especially for you I'm posting this hoodless version, so you too can see it is a lot bigger. Now isn't that unfair, or what?
Let's try this again.
9
It's not like my point is hard to understand. Three facts:
(1) The Pana Leica's hood doubles the lens's size. It can't be reversed.
(2) If you shoot both lenses with hoods, the Pana Leica + hood is just as big as the Sigma + hood.
(3) If you shoot both lenses with hoods, you can reverse the Sigma's hood in your bag and the rig is shorter. Again, you can't reverse the Pana-Leica's hood.
That's it. Three facts. The comparison photograph you posted hides them. Your response attempts to marginalize them.
When we talk about lens size, what else matters but deployed shooting and rig space in your bag? Your comparison doesn't address either. Ergo, it's useless. Or worse if it creates misleading impressions. I think it does.
Make all the emotional accusations you like, but what's really happening, here, is that you're just refusing to acknowledge a pretty useful fact (and, to your argument, an inconvenient truth) about the Pana-Leica.
You didn't make the picture? It sure isn't stopping you from making a crap argument based on it.
I don't really understand (or care) what your rhetorical agenda is, but the net result is that you're creating false impressions and advancing a lie.
And then there's this:
Have you not compared the MTF data for these two lenses? The old Sigma 30/1.4 for DSLR doesn't do nearly as well. It's not even close.
TheClueless
TheClueless Senior Member • Posts: 2,140
Eh, you do know what a lens hood is, right?
It's not hugely bigger than the 25 - which is, admittedly, about as big as it should be on m4/3.
 TheClueless's gear list:TheClueless's gear list
Leica Q2 Leica M10 Panasonic Lumix DC-G9 Sony a7R IV Sony Cyber-shot DSC-V1 +71 more
FrankS009
FrankS009 Veteran Member • Posts: 6,557
Apparently the smaller PL 45mm 2.8 hood also fits the 25mm 1.4.
F.
"We shoot the things that move us in ways that will move others." David duChemin
 FrankS009's gear list:FrankS009's gear list
Henry Richardson Forum Pro • Posts: 21,959
Surely, everyone can see the size of the lens
Wait, is the Sigma with hood ON? Seems that way to me. The hood itself is 1/3 the total length. In any case, if I have a Canon dSLR, I'd double-duty a Canon-mount Sigma 1.4 with a smart adapter to the m43 and 'justify' the size issue.
I am guessing that just about everyone can see that there is a hood and no one is being fooled.  I suspect most people can compare the sizes of the actual lenses in these photos.  Am I over-estimating the intelligence of the people here?
It is strange that they put the hood on for the photo of this lens though.  I think I have never seen them do that for any other lens.  They really should take a new photo without the lens.
Henry Richardson
http://www.bakubo.com
About size of Panasonic 14-140mm II
Henry Richardson wrote:
Yep, I posted about the lens and its size a few days ago:
http://www.dpreview.com/forums/post/57490460
http://www.dpreview.com/forums/post/57480227
The lens is rather large, but not huge, IMO.  About the size of the Panasonic 14-140mm II.  For someone who wants 30mm and who also wants f1.4 then there is no other choice.  For someone who wants 30mm, but is willing to have f2.8 then there is also the smaller Sigma 30mm f2.8.
Henry Richardson
Re: Surely, everyone can see the size of the lens
Unless the hood is fixed?
