Re: Any advice and help rigging twin cameras for 3d stereo?
Hi,
I have been doing digital 3d for many years and before that, spent years shooting film 3d. So, the best rig I have for stills is a Stereo Data Maker rig. That is basically software you can download that lets you replace the cameras internal firmware to do 3d. Its not a permanent change, it forces the camera to boot off the SD card with different software. The camera basically gets an added set of commands that allow you to get sync between two cameras. Its perfect really.
This works with canon cameras, and there are many that it is compatible with. It takes a little fiddling, but you basically get your hands on 2 compatible canon cameras, download the stereo data maker software, it was free last time I checked, get a usb trigger, then you can shoot perfectly synced 3d stills. You cant easily do synced 3d video, that is much more fiddley to get sorted out.
For the SDM rig I have, the canon s95 works really well. The cameras as pretty small, good quality, and work very well in 3d. The link below is for that software. Not sure if its going commercial or what.
http://stereo.jpn.org/eng/sdm/index.htm
I have the gopro 3d "Dual Hero" rig too. The factory gopro 3d thing, I am not thrilled about only due to the lack of space between the lenses. Here is a link to my gopro 3d rig below. Its the best thing going for 3d video right now as far as easy, fairly cheap, and good quality. I have many 3d videos shot with it on youtube.
https://www.youtube.com/watch?v=h7Qj3Gafo2A
You can also do 3d stills with the gopro rig. My rig is spaced wider, so I am able to do pretty much anything and get really good results and its pretty easy to use. If I had 1 3d rig, that is the one. You need to build it though and the factory spacing isn't enough to get a good 3d effect unless you are shooting objects around 3 feet. The quality blows everything away in 3d. The best 3d video camera in the consumer end is the Sony Dev-30. The gopro rig I have blows it away completely. The sony is easy, and has a stabilizer, allow zoom, and I do use it often.
I have heard some people have made little sync devices for the Panasonic GH cameras. I have seen some excellent video using that rig. That would get you into the bigger type cameras.
http://www.personal-view.com/talks/discussion/2821/gh12-3d-sync-controller/p1
I own the Fuji W3 and also had the Panasonic 3d1. The Fuji is the easiest 3d still camera overall. It has massive contrast issues. You need to fix every single image in post in a big way to make it look normal, but it is a good camera. If Fuji updated that camera, it would be great, but I guess the 3d wave sort of died down. Nobody makes 3d any more. I guess nobody buys it. I hope the oculus rift changes that, but its focus is more on gaming, so it may have no affect at all.
Lots of options. I can attest that they all work very well. You just need to put a little effort into it since there aren't really any good consumer grade options other than the Fuji w3.
Steve
