Nikon D5 Photographic Dynamic Range (PDR) ... The New Low Light Champ
Started Mar 21, 2016 | Discussions
bclaff Forum Pro • Posts: 13,713
31
I have now measured measured the Photographic Dynamic Range (PDR) of the Nikon D5 (shown here compared to the Nikon D4) (thanks to AndresE for the raw data)
This curve looks more Sony-like than any previous Nikon.
Some low ISO dynamic range has been traded off against extraordinary high ISO performance.
My Low Light ISO for the Nikon D5 is 6982 which beats the previous high of 6400 for the Phase One IQ250 by 0.13 stops.
You can see these values in the sort-able table below the PDR chart.
This type of design is not ISO-invariant at all. Note the Shadow Improvement (again compared to the D4) :
More measurements are required to better understand what's "under the hood" but it looks like a remarkable achievement.
Bill ( Your trusted source for independent sensor data at http://www.PhotonsToPhotos.net )
Nikon D5
jvigano Forum Member • Posts: 74
Re: Nikon D5 Photographic Dynamic Range (PDR) ... The New Low Light Champ
Bill, how does that compare with the D3?
www.josevigano.com
OP bclaff Forum Pro • Posts: 13,713
I encourage people to follow the link to the interactive chart and play with it themselves.
In the case of the D5 and D3 you will see this:
logatom Regular Member • Posts: 258
Bill,
That's a great reading. Thanks for your quick and amazing (as always) effort.
Looks fantastic for high ISOs, but people caring more for a landscape performance will be a bit disappointed.
Greg
Bill,
I guess you're fine-tuning the measurements since I do not find the D5 on your interactive charts at this point.
thanks
Greg
logatom wrote:
Bill,
Thanks for the "heads up"
I'm having trouble uploading to my site right now and didn't know the update had failed.
logatom wrote:
Bill,
All set now. Thanks again for the "heads up".
OK, having a look.
StanyBuyle
StanyBuyle Senior Member • Posts: 1,654
Hi Bill. Thanks for your work.
D5, do I see a crippled DR? +Back to 2007 D3 standards...
If so, I hope it isn't the case with D500(but I fear it will...)...
I like better one decent picture in a day than 10 bad ones in a second.
Registered on Dpreview since 2003.
 StanyBuyle's gear list:StanyBuyle's gear list
Nikon D1H Nikon D1X Nikon D2H Nikon D2X Nikon D1 +1 more
You are welcome.
That depends on your point of view.
Personally I think low ISO Dynamic Range (DR) is too high for many photographers and that this is a welcome trade-off between a very respectable low ISO DR and extraordinary high ISO performance.
Look how close we're getting to the "Ideal FX" performance:
If the D500 follows this same pattern then some may be disappointed but personally I may have to rethink holding on to my D7200.
syberman7 Senior Member • Posts: 1,508
bclaff wrote:
You are welcome.
According to your own chart, the Sony A7RII is the 'low light champ', and it has two more stops of DR at base ISO. In fact it even exceeds the ideal FX at higher ISOs. Of course it won't do 12-14 fps.
 syberman7's gear list:syberman7's gear list
Nikon Z6 Nikon Z7 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon Z 24-70mm F4 Nikon AP-F 70-300mm F4.5-5.6E +6 more
JasonED Contributing Member • Posts: 946
The high iso look impressive but I can't help but wonder if the low iso performance has been hampered by the need to support 4K...   Seems the read-out electronics have gotten noisier?
The sky is blue and there is nothing we can do..
You seem confused by what is meant by "Low Light Champ", this is high ISO performance, not low ISO performance.
In terms of the charts, how far to the right a PDR of 6.5 is rather than how high the curve at it's maximum height.
(Like DxOMark Sports ISO Score rather than DxOMark Landscape Score)
steras Senior Member • Posts: 1,198
So my initial impressions were right
http://www.dpreview.com/forums/post/57123902
Great work Bill. It is always very interesting to read about your analysis, thanks a lot!
 steras's gear list:steras's gear list
Canon PowerShot G10 Nikon 1 V1 Nikon D2H Nikon D5300 Panasonic Lumix DMC-G1 +10 more
Slugsworth
Slugsworth Regular Member • Posts: 332
logatom wrote:
Bill,
Greg
They ideal workaround is, (for those that can afford it)
would be to have both the D5 and the D810 for low ISO & landscape work.
Going one step further would be the triple crown of the D5, D810 and the D500 for ALL your needs.
 Slugsworth's gear list:Slugsworth's gear list
Nikon D810 Nikon D5 Nikon D500 Nikon D850 Nikon Z9 +23 more
Sharlin
Sharlin Contributing Member • Posts: 745
Pretty sure the D5 (just like Canon's 1D(X) series) is meant to be a landscape shooter's camera. It's all about speed: ISO speed, burst speed, AF speed.
 Sharlin's gear list:Sharlin's gear list
Canon EOS 80D Canon EF 85mm F1.8 USM Sigma 18-35mm F1.8 DC HSM Art Canon EF 50mm F1.4 USM Sigma 10-20mm F4-5.6 EX DC HSM +3 more
Slugsworth
I think you mean "isn't"and yes, totally agree, having the D810 to fill that gap nicely
Sharlin
Oops, thanks. Changed the phrasing and forgot to negate the verb
Maybe I worded that clumsily. The A7II has both better base ISO DR AND better high ISO DR according to your chart:
http://www.photonstophotos.net/Charts/PDR.htm#Ideal%20FX,Nikon%20D5,Sony%20ILCE-7RII
Thanks very much for the data by the way. All I'm debating is the interpretation.
FDD5 Regular Member • Posts: 204
I think with low light champ he means ; 'My Low Light ISO for the Nikon D5 is 6982 which beats the previous high of 6400 for the Phase One IQ250 by 0.13 stops.'
Whereas the a7RII has 5846
 FDD5's gear list:FDD5's gear list
Canon EOS-1D Mark IV Canon EOS 7D Olympus E-M1 Olympus 40-150mm F2.8 Pro Sigma 150-600mm F5-6.3 DG OS HSM | S +1 more
