Canon EF 24-70mm f/2.8L USM - Fungus or not?
Started Mar 19, 2016 | Discussions
ernest204
ernest204 New Member • Posts: 2
Hello,
Yesterday I Purchased a second hand Canon EF 24-70mm f/2.8L USM lens, which seemed to be in a great condition while i was purchasing it.
However, today i took it out to test it in daylight conditions, and i noticed something strange on the front element, as shown on the image below:
These 2 dots appeared from nowhere, since they were not visible while i was purchasing it. I tried to remove them with a lens pen, a dry and wet cloth, but it didn't want to come out at all.
Later i tried the same procedure at home, and it got removed somehow, but only the inner part, the contours (outlines) remained:
So my question is, shall i be worried about this? Is this lens fungus or not? I have searched on multiple websites and Youtube videos for answers, but i wasn't able to find anything.
  • What shall i do about it?
  • Should i contact Canon for this issue, or leave it as it is?
  • Is this lens fungus or something else?
Thank you in advance for your help.
Ernest.
 ernest204's gear list:ernest204's gear list
Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 24-70mm f/2.8L USM Adobe Photoshop CS6 Adobe Photoshop Lightroom 5 +1 more
larry Contributing Member • Posts: 889
Re: Canon EF 24-70mm f/2.8L USM - Fungus or not?
Dried residue from water/lens cleaner, on the outside of the lens.  Try soaking in some lens cleaning liquid to disolve them.
hotdog321
hotdog321 Forum Pro • Posts: 21,141
I think larry is right. I've had similar circular marks appear on lenses and they buffed off.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
ernest204
OP ernest204 New Member • Posts: 2
I did exactly as you said, and it turned out great, i used a lens cleaning liquid and the front element is now perfectly clean
Thank you very much guys for your support and good advice
