Pen F Problem Autofocus with the Zuiko 12-40mm f2.8
Started Mar 18, 2016 | Discussions
OP zikman Junior Member • Posts: 47
Re: Pen F Problem Autofocus with the Zuiko 12-40mm f2.8
i know about the difference in mf and s-af and how i can switch between the two with the ring...
i now use the mode s-af with the mf feature together  so i can adjust the focus with the shutter half pressed to make the focus sharp if needed...and i am waiting for the official answer from Olympus..
thx
 zikman's gear list:zikman's gear list
Olympus PEN-F Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
Capture the Moment Regular Member • Posts: 305
Just tested mine with the 12-40 and no issues. Seems to work fine with all my lenses.
 Capture the Moment's gear list:Capture the Moment's gear list
Fujifilm FinePix X100 Fujifilm X100V Olympus PEN-F Olympus E-M1 II Nikon Z50 +2 more
Also from the manual of the E-P5 it says about the autofocus that uses
Imager contrast detection system ...
and for the Pen -F it says Hi-Speed Imager AF..
I don't know the exact difference between the two but maybe this difference makes the experience about the autofocus different between the two bodies...I remember myself the fastest af with the E-P5 3 years now and i have never experienced a problem with that...it have never crossed my mind outdoors or indoors...
Now with the shift to the Pen-F it behaves much different indoors...Maybe its normal ...however because of the fact that i was used 3 years now to the focus of the P5 i should get used to the Pen-F now...
Thx guys!
inlight Junior Member • Posts: 48
Thx guys!
Hi,
Have you received a reply from Olympus or sorted the issue?
I am finding PEN F struggling in focussing indoor with Olympus 12-50mm.
NowHearThis
NowHearThis Veteran Member • Posts: 4,616
Thx guys!
Hi,
I bought a PEN-F a week ago tomorrow along with the PL12-60/2.8-4 and I've noticed that in very low light with not much contrast that the AF hunts, my EM10 did the same thing, but for me that's the only time it does, my AF keeper rate is still as good as my EM10.
NHT
//life motto
if (sad() == true) {
sad().stop();
beAwesome();
 NowHearThis's gear list:NowHearThis's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Olympus E-M1 III Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 42.5mm F1.7
Olympus told me that there is nothing wrong with the hardware of the camera or the lens...however it still haunts at indoor lighting (specially when indoor lighting is LED) ...while other Olympus bodies or the Panasonic gx85 behave normally...so I think that we should try to live with that...However it is weird for me that the issue isn't mentioned in any  pen f review I came across at the net ...
hope that I helped ...its not the lens or the firmware ...its the way that pen f focus...as I told the older pen ep5 is behaving way better in this ...!
Rome A Senior Member • Posts: 1,076
+1 here, too!
rome
 Rome A's gear list:Rome A's gear list
Leica X2 Leica D-Lux 7 Olympus PEN-F Leica CL Sony a7C +14 more
