Pen F Problem Autofocus with the Zuiko 12-40mm f2.8
Started Mar 18, 2016 | Discussions
zikman Junior Member • Posts: 47
The problem with the new Pen F is there with the Zuiko 12-40 f2.8...It struggles to autofocus and 70% of the times just doesn't autofocus...
So there is definitely a compatibility issue with the lens...Maybe they will fix it with firmware..When using the primes 17mm f1.8 and 45mm f1.8 it just autofocus fast and snap...
I am definitely frustrated because i have tried everything and it just doesn't work...My old E-P5 plays nicely with the 12-40 f2.8
Any ideas to try?
 zikman's gear list:zikman's gear list
Olympus PEN-F Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
Olympus PEN E-P5 Olympus PEN-F Tamron SP 45mm F1.8 Di VC USD
Alfred Molon Senior Member • Posts: 1,134
Re: Pen F Problem Autofocus with the Zuiko 12-40mm f2.8
I saw that you found my other thread at http://www.dpreview.com/forums/post/57461815
In the meantime I have returned the Pen-F and got a refund.
If you look at the camerastore review
https://www.youtube.com/watch?v=sdPhwpmo5O8
The guy complains of erratic performance of the AF of the Pen-F. He says that the E-M5 focuses much better.
Maybe the current version of the Pen-F really has some AF issues. Perhaps Oly will fix the issues in a few months.
But I'm surprised that you get these problems with the Zuiko 12-40, an Oly lens.
Alfred
Karld70 Veteran Member • Posts: 3,553
Any ideas to try?
well it's probably not a camera setting if it works fine with the 17 and 45,  I'm guessing Oly will be doing a firmware update at some point to try and fix it
goodbokeh
goodbokeh Senior Member • Posts: 1,535
My 12-40mm AF works fine with my Pen-F, maybe you have dirty lens contacts?
 goodbokeh's gear list:goodbokeh's gear list
Leica Q2 Leica M10 Monochrom Leica M10-R Fujifilm GFX 100S Sony a1 +2 more
PentaxNick Senior Member • Posts: 1,831
Mine seems fine too.
 PentaxNick's gear list:PentaxNick's gear list
Ricoh GR Fujifilm X100T Olympus Tough TG-4 Ricoh GR III Olympus PEN-F +12 more
agray88 Regular Member • Posts: 309
No problems here.
 agray88's gear list:agray88's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +4 more
OP zikman Junior Member • Posts: 47
its weird because the lens works ok at the E-P5...
The problem is magnified indoors at lower light conditions...At the same lighting conditions the P-5 behaves much much better at autofocus...Indoors the pen -F cannot autofocus easily and 60-70% is getting confused..!!
the settings that i am using when cannot autofocus is at 1/20 f2.8 and ISO 400...The exposure metering at Manual Mode shows +0.3 and the thing cannot autofocus!
Big Ga Forum Pro • Posts: 18,627
Any ideas to try?
Buy a different body or lens for now and just wait.
Then in 6 months time, if you're lucky, Olympus will issue a firmware update, and silently fix what wasn't admitted was broken in the first place! then all will work fine
I experience exactly the same issues with the Panny 12-32 and 45-150 lenses. If others do not have these problems, perhaps your Pen-F is faulty.
Alfred
Today i was outdoors with the Pen -F and the 12-40mm..The day was sunny and the autofocus was fast and snap..I just got indoors with a normal lighting from the bulbs and again the lens cannot autofocus at 70% of the times...
Trying with the E-P5 the focus is snap..!Also trying with the primes with the Pen-F the focus is snap...Again everything seems a compatibility issue...If it was because of a faulty body it could not focus right outdoors or with the primes...
So..Olympus ..come on....Waiting for an official answer...I have also contacted with Olympus Service and send them some videos that showing the problem and waiting for their response....
Thx everyone here!
goodbokeh
My 12-40 is not doing what your 12-40 is doing on the Pen-F in low light, so another possibility is your lens is faulty. Also, is your lens firmware up to date?
The firmware is the latest..
Can anyone else confirm that at low lighting the 12-40mm on a Pen F can autofocus accurate and fast?
In the OP he said the 12-40 works fine indoors with his E-P5.  So he is doing a side by side comparison with another camera body.
Maybe someone else with a Pen F might have a 12-40 they can also test to see how the camera does.
I just uploaded the two videos showing the difference....
the one from 12-42mm f.2.8 and the other of 17mm f1.8 (i chose f2.8)
Sorry for the kid's yelling
https://dl.dropboxusercontent.com/u/53219731/Pen%20F%2012-40mm%20f2.8.MOV
and
https://dl.dropboxusercontent.com/u/53219731/Pen%20F%2017mm%20f1.8.MOV
If the Pen F was faulty then autofocus would be problematic at the 17mm as well ...am i right or not?
The problem is that i just sold the E-P5 this morning and i cannot upload a video from 12-40 at E- P5 anymore...! Also once again...today outdoors the autofocus at 12-40 was perfect...
Thx for all guys!
I've just done a totally unscientific test comparing the EM-1 and the Pen-F with the 1-40 Pro indoors. I agree that the Pen-F doesn't focus as well, failing to lock focus more often. When it does work it is snappy though.
When fitted with the 12mm f/2 it does much better. Of course this could be due to double the light reaching the AF system.
Nick
Joe Sesto Veteran Member • Posts: 3,084
I just pulled my Pen F out mounted the M.Zuiko 12-40/2.8 for the first time and AF was all over the place...except in focus.  Then I went back into the Menu settings and made a couple of minor changes and from that point it was spot on.  Inside fairly low light...ISO 2500 shooting around f/4 @ 1/50.
Then I took my new 60/macro out of the box and it went bonkers for a few seconds on the Pen F then settled down and AF was right on target.
These were the first shots I had taken with the Pen F, but I had messed with the menu settings a couple of days ago and must have got one wrong.  But with the macro I had left the Menu untouched...it almost seemed like the body and lens took a few seconds to get acquainted with one another.
I probably had spent 20 minutes with the camera turned on, setting Menu items, mounting different lenses and taking shots...maybe 30 min. at the outside.  I was surprised how warm the right side of the body got. I had not shut it off except when I changed the lens.   I noticed that it got warm a couple of days ago when I was running thru the Menu settings.
Is that slight heat build up normal??  I haven't rec'd the grip yet, haven't even attached the neck strap. Just a bare camera.
That 12-40 is a lot more comfortable on the E M1 than on the Pen F...I don't have large hands and it was torquing my right hand quite a bit.  Hope I get used to it, or the grip will help, but it will probably be used most with the f1.8 primes and macro.
Don't know if this helps...
Any ideas to try?
One last note...the green AF box was flying all over the LCD as I got acquainted with the controls.  In a few instances I didn't even know where it was on the LCD...but I finally figured it out.
Is your Pen F Menu set to take the shot even if focus is not confirmed?  Might be a factor.  I'm just guessing at answers
Joe Sesto
Oly E-M1 - Pen F
 Joe Sesto's gear list:Joe Sesto's gear list
Canon PowerShot Pro1 Canon EOS 5D Olympus PEN-F Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +6 more
i can't find a setting that fixes the autofocus yet...
I just took the first shots with it today.  The AF settings should be similar to the settings in your other Olympus, if you have one.  Though it will not have a PDAF setting and I only set minefor single frame to start.  I think my mistake was setting it to an HDR setting when I was ffirst playing in the Menu.  If you have done somethng ike that just do a full reset.  You can't lose anything but te date.
Joe Sesto
Oly E-M1 - Pen F
DrWu
DrWu Contributing Member • Posts: 658
No problems here: Pen F Problem Autofocus with the Zuiko 12-40mm f2.8
Mine works and focuses normally so far with Zuiko 12-40 as well as with other lenses that I have tested that  isLeica DG Summilux 25mm F1.4, Zuiko 17mm F1.8, Zuiko 75mm F1.8.
Pekka
 DrWu's gear list:DrWu's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Olympus E-M1 II OM-1 Voigtlander Nokton 25mm F0.95 +5 more
I just checked your profile, which I should have done before replying.  I did not realize that you just signed up on DPR and may not own another Olympus, as there is no gear listed.
if this is you first Olympus experience, I must tell you that the menu is not the most intuitive you will ever run into.
What mystifies me is how it worked outside and not inside.  One explanation is that you turned the 12-40 into Manual Focus mode by sliding the front lens barrel ring backwards.  That turns off AF and the lens must be manually focused.
If you see the apertures on the top of the lens...it is in MF...just slide the front ring forward and you will be back in AF mode.
Happened to me...just always make sure that ring is forward.  It is common to most M.Zuiko lenses.  They don't have AF/MF switches on the side ofbthe lens barrels.
Joe Sesto
Oly E-M1 - Pen F
