Panasonic CM1 android updates
Started Mar 17, 2016 | Discussions
Øyvin Eikeland Regular Member • Posts: 173
Hi,
I have just ordered a CM1 at a big discount:
http://www.cyberphoto.no/info.php?article=dmc-cm1
After ordering I read a rather unfavorable review suggesting that some firmware update was badly implemented (Link below to review in norwegian...sorry).
http://www.tek.no/artikler/slik-er-panasonics-svindyre-kameramobil/191723
I am now waiting for the packet to arrive and I have found the following updates available:
11.0761 (Apr. 13, 2015) Android 4.4
12.0274 (May 27, 2015) Android ?
12.0300 (Feb. 15, 2016) Android ?
I have also found that there is something called Camera2 API used by apps like ProShot for instance.
Are there any CM1 users here that can recommend which firmware version to run? Is it a good idea to just jump to the latest and greatest or do you regret updating?
Do you know if any of them supports the Camera2 API?
Do you know which Android version hides behind the different versions?
Any experience at all with the latest update?
Best regards,
Øyvin Eikeland
 Øyvin Eikeland's gear list:Øyvin Eikeland's gear list
Sony Cyber-shot DSC-W300 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +6 more
shanttu New Member • Posts: 1
Re: Panasonic CM1 android updates
I catched the same deal and received my device yesterday. Updated everything and rooted the device.
I see no reason not to update.
I like the device. Still wondering what protection to get. Cotta cases looks awesome but I'm not going to pay 75% of the price of my device for a case.
There are some discussions on Flick and here as well.
 shanttu's gear list:shanttu's gear list
Sony a6000 Panasonic Lumix DMC-CM1
edee1337 New Member • Posts: 21
Hi! I'm actually the developer of ProShot
While I don't have a CM1, I can explain the Camera2 API. This API was added in Android 5.0, and is a set of tools developers can use to manually adjust camera settings (shutter, ISO, focus, etc). This wasn't possible in any official capacity before Android 5.0.
The part that's confusing is not all phones with Android 5.0 can do manual control. The manufacturer actually has to enable that on the hardware level via Android's HAL. All devices that don't have FULL or LIMITED Camera2 API support run in LEGACY mode, which is to say the most you can manually adjust would be exposure compensation and white balance. I've done all I can to add fun things for devices of all capabilities though (histogram, customizable access aspect ratios, separate focus / exposure points, etc).
When you first load ProShot the intro screen will inform you of your device's capabilities. If manual shutter / ISO / focus is possible it will appear there. Hope that clears a few things up!
limesoft New Member • Posts: 5
The Cotta case is incredibly overpriced. I'm using a pouch called  "shocksock" from galaxy note which is ok in the interim..
I'm trying to find out how to protect the lens (i don't want the cotta hood), so been trying some DIY solutions but no luck so far.. Next I will try a 54mm push on cap
vv50
vv50 Contributing Member • Posts: 904
many cm1 owners try to protect the lens, but from what? if it's protection from the surface of the table, i don't see any difference if i place it face down or up, the lens doesn't touch the table when the lens is facing down. if it's protection from a drop to the floor, i just use a strap around my wrist just like any regular camera.
OP Øyvin Eikeland Regular Member • Posts: 173
CM1 does not support the API :(
Hi,
I have now received the CM1 and purchased proshot but the phone does not support the functions you are describing I am also not able to assign any other app to the camera button.
Best regards,
Øyvin Eikeland
vv50
the latest firmware is 5.0.2
I can help. what do you need?
Update aready done, now how do I get the most from this device?
Thanks, but I have already received the phone now and have updated it to 5.0.2. I was contemplating leaving it at 4.4.4 after reading the review. They suggested that the updates may caused the slow response they were experiencing. So far I am happy with the speed of operation. What I am struggling with at the moment is:
- How do I keep the camera from turning on in my pocket? Do I have to carry it in a pouch or something?
- There seems to be some sort of plastic film on top of the screen. It is quite firmly glued on. Is it supposed to stay on? It scratches quite easily. Do you keep yours on?
- As many reviewers have pointed out JPEG quality is not the best. I am trying to shoot raw but I could use some help to find the quickest way to shoot-develop-share(facebook or  private gallery or blog or instagram). Unfortunately my favourite tuning app = snapseed does not currently support rw2 it seems
I am going full in trying to use this as my main phone
Øyvin
vv50
Re: Update aready done, now how do I get the most from this device?
the camera functions by themselves don't feel any slower with the latest version.  it is the android interface that has become more sluggish in version 5.  i would still stick with the latest version since you're protected from stagefright.  i get around the "slow response" feeling by switching on developer options and turning off all UI transitions and animations.
none that i know of. the lens will extend and retract at random events like getting wifi/gps signal, or if you activate the led flashlight.
yes, ideally in something loose and non-insulating, since heating up the battery will reduce its lifespan.
it is the factory-installed screen protector, and yes i keep it on.
can you elaborate what particular characteristic of your jpeg is not the best? there are many photo styles, have you tried them all? each style can be customized in contrast, saturation, sharpness and noise reduction.
if you are planning to edit raw files, you can best do this on a computer since the screen on the cm1 is too small and uncalibrated to make proper color and exposure judgment calls.
vv50
i also find that many online reviewers of the CM1 don't even get the basic facts correct. some claim that it has a "2x optical zoom" (it doesn't) and some claim that the lens is "fixed and doesn't extend" (it does) so i would take their opinions with a grain of salt.
Re: CM1 does not support the API :(
Hi,
Best regards,
Øyvin Eikeland
Ah, then it looks like Panasonic didn't add Camera2 API support to the CM1, what a shame
Blown highlights and detail loss
Sorry for taking so long to reply. I just felt the need to gain some more experience before claiming this or that. The main problem with the jpegs is blown highlights. Theres an incredible dynamic range in this sensor. I have done a couple of head to head comparisons between raw and jpeg on difficult subjects. The difference in highlight recovery is rather big and shooting raw can be useful even for snaps that are meant for instagram. The workflow is almost there with rawdroid for browsing and ratings plus raw support in snapseed for editing. Rawdroid is phenomenally snappy and useful but lacks the ability to convert to dng or tif when sending the pictures to snapseed (snapseed does not read rw2). I have contacted the author asking for this feature and he sounds very positive. Please support this guy/app so that rawdroid can become all it can be. It's almost like having photo mechanics in my pocket! Also: do register as a beta tester. The beta is much improved compared to the latest official version.
The other complaint I have regarding jpegs is detail loss in low light. This can probably be tuned in the settings. I have not played around much with this I must confess.
BR
Øyvin Eikeland
Random lens extension?
After updating and starting to use a pouch around the camera I have had zero incidents of lens extensions in my pocket so far. Are you sure this problem is there (still)? I find the speed of the phone pretty good even without turning off this or that in the menus. It blows my old galaxy s3 out of the waters
BR
Øyvin
vv50
Re: Random lens extension?
for me yes, whenever my phone frequently connects to, and disconnects from, wifi networks. also happens when it switches from 2G to 3G to LTE.
duartix Veteran Member • Posts: 3,613
Re: Blown highlights and detail loss
You are holding it wrong!
Try this instead. It's free and it's one click.
Keep the JPG in the same folder with same name of the DNG (or do a conversion with RAW2DNG if you are shooting just RAW).
Don't ask me why but when you have a sidecar JPG alongside the DNG, Snapseed will not only allow you to open it directly, it will also allow you to export the processed file in background while you are already opening and processing the next file.
It does open RAW but just the DNG format.
Second that. As a manager it's very valuable. Portfolio is also OK and very fast.
Duarte Bruno
 duartix's gear list:duartix's gear list
Fujifilm FinePix F40fd Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +4 more
