Modding NX500 and NX1 - silent shooting
Started Mar 16, 2016 | Discussions
Pavel Masek Regular Member • Posts: 119
Re: Modding NX500 and NX1 - silent shooting
I did and and there are only options for shooting speed in continuous mode (eg. 8 fps,..., 15 fps), timer and setting for bracketting (AE, WB,...). There is no option for "burst mode" (there is no info about it in NX1 manual either). Thank you for patience...
 Pavel Masek's gear list:Pavel Masek's gear list
Canon EOS R6 Canon EF 135mm F2L USM Canon EF 24-105mm f/4L IS USM Canon RF 50mm F1.8 STM
Ralph McIntosh Regular Member • Posts: 301
The 30 fps burst mode of the NX30 got removed from the NX1
 Ralph McIntosh's gear list:Ralph McIntosh's gear list
Canon EOS 10D Canon EOS 300D Canon EOS Rebel T4i Samsung NX1 Canon EF 50mm F1.8 II +8 more
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Ouch, I didn't even care to check, assuming it were still there! So, nx1 could be incapable of silent shooting at all
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
That is really pitty. However - there is "burst" option in ST menu (beside "continuous") so it is clearly something which is not present in NX1 menu. So maybe someone could activate this "burst" mode somehow and it could help to find way to silent shooting in NX1 (maybe I am dreaming now)
https://github.com/ottokiksmaler/nx500_nx1_modding/blob/c05a707fe540a086877cb1c1d103c466f25b2ed2/ST%20Commands.md
(unknown member) Contributing Member • Posts: 715
Did you try: st cap capdtm setusr ADJUSTSHUTTERTYPE 0x750001
(I know the ID number is not declared there, but you can set user values the the type-name too.)
for the 30fps burst rate, try:
[root@drime5 ~]# st cap capdtm setusr BURSTRATE 0xb0000 4
UserData is set
[root@drime5 ~]# st cap capdtm getusr BURSTRATE
UserData is BURSTRATE_RATE30FPS (0xb0000)
(it it doesn't commit, try opening the menu, and looking the the burst mode, not changing anything, and closing the menu - in some cases, some dance is needed before commuting)
I can try it in the evening (or someone else with NX1 and better IT knowledge). So basically I will connect camera via telnet and try these commands?
BTW - have you tried command for "nrmenable 0 - 1 (0:off/1:on)" on your NX500? Could it be noise reduction?
yes, telnet or script - the usual
haven't tried "nrmenable", thanks for the idea
Hirsti Contributing Member • Posts: 660
UserData is set
There is an internal setting on the NX1 for burst but it hasn't been implemented.
If you look at the drive options using st cap capdtm then you can set it to burst but it gets reset back to single drive when you take a shot.
Here is an extract from my telnet session:
UserData is DRIVE_CONTILOW (0x90004)
[root@drime5 ~]# st cap capdtm setusr DRIVE 0x00090005
UserData is set
[root@drime5 ~]# st cap capdtm getusr 9
UserData is DRIVE_BURST (0x90005)
I pressed the shuter key and checked the alue
UserData is DRIVE_SINGLE (0x90001)
I tried saving the parameter with orefman save but this just reverted back to single drive.
You can also set the burst rate this way as you described but to be able to use the burst mode you somehow need to get the camera to keep the Burst drive mode change
 Hirsti's gear list:Hirsti's gear list
Sony RX10 III Sony a7R II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +1 more
vasile Contributing Member • Posts: 575
Or not to actively set it to single shot when you press shutter button.
 vasile's gear list:vasile's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 16mm F2.4 Pancake Samsung NX 85mm F1.4 ED SSA +1 more
Vaga Forum Member • Posts: 66
perhaps write a script to have it take a picture with pressing a different button that the shutter?
SawStory New Member • Posts: 23
after all the progress happen in the last few weeks , dose the hope for nx1 silent shutter increased?
 SawStory's gear list:SawStory's gear list
Samsung NX1 Samyang 8mm F2.8 UMC Fisheye Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
leo_dp New Member • Posts: 2
Hirsti wrote:
otto k wrote:
Hi,
Simple "hack" to enable silent shooting in single mode (not CH/CN):
Otto,
the full list of NX1 usr items are:
+ Data ID Name | Param ID Name + ID(Hex) +ID(Dec) +
[ 0]| USERDATA_DIALMODE | DIALMODE_SMARTAUTO |0x00000001| 1|
Otto:
I see you have (had?) the NX1000. Do you know if the electronic shutter may work also on the NX1000?
Hirsti:
How could I get the usr items list for the k1000?
Thanks, Leonardo
OP otto k Senior Member • Posts: 2,252
Hi, I haven't been able to hack the NX1000 in the same way and even NX1 is unable to use full electronic shutter, even though it's very similar to NX500. Sorry.
