Defective Oly 25mm lens
Started Mar 16, 2016 | Discussions
Betarover Senior Member • Posts: 1,049
Today I tested a new lens that I purchased from B&H Photo.  It is an Olympus 25mm f1.8 lens.  It was bought during the recent Olympus sale.  I had great expectations after having researched the lens.  Sadly it is a lemon.  The left side is blurry and the right side is sort of sharp.  I have trouble believing that such a defective lens was allowed to pass the Olympus "quality" control and was sold by a reputable company like B&H.  B&H has agreed to give me a full refund and even sent me a return shipping label.  I think their service is terrific and am not blaming them.
I wonder how many other lenses having this problem are out there with unsuspecting photographers?  For photographers wanting edge to edge sharpness, my experience shows the importance of being able to return a defective lens and of testing it before the return period is up.
Below is the full size image so those interested can zoom in and see what I mean.  It was taken at F4, which should be its sharpest stop.  I took many others and the results are the same, unsharp on the left and sharp on the right.  I took high res and regular res, but am posting this regular res because my internet connection can't handle sending the high res image.
I also took the scene with my Panasonic 14-45mm lens, and these images are normal edge to edge.  They are much sharper on the left edge than the Oly 25mm, but not quite as sharp as the Oly on the right edge.  Some of you may think I am being too particular.  But it makes no sense for me to buy a prime lens that is not as sharp as my zoom lens.
Taken with a defective Olympus 25mm lens, f4.  Unsharp on the left, sharp on the right.
Panasonic Lumix G 14mm F2.5 II ASPH
Martian Flatcat
Martian Flatcat Regular Member • Posts: 457
Re: Defective Oly 25mm lens
What happens if you take a picture, then take it again with the camera upside down? If the problem swaps sides, I would say to return the lens.
--Flatcat
 Martian Flatcat's gear list:Martian Flatcat's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G 14mm F2.5 ASPH +7 more
MayaTlab0 Senior Member • Posts: 2,985
As Martian Flatcar suggested, I'd try to perform the upside down test first with this lens :
http://www.dpreview.com/forums/post/51037446
However, given that you are far from the only one who's noticed a front focusing left side on the Olympus 25mm f1.8, there are very good chances yours is a lemon (and some chances you'll have a hard time finding a decent one :
http://www.dpreview.com/forums/thread/3978582#forum-post-57435654
cptobvious Contributing Member • Posts: 850
I've tried 5 copies of this lens and have given up trying to find an acceptably centered copy for the time being. Such a shame because I like it in every other way, and none of the dozen or so other MFT lenses I've owned have had this issue across repeated copies. This is something that should've been caught in manufacturing, given that these MFT lenses are virtually impossible to be optically adjusted by design and cannot be fixed under warranty by a service center, so your only choice is to return/exchange it and roll the dice again.
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
Looks similar to my 25/1.8 adventure.
I had three 25/1.8 lenses, one good sample in 2014 and two lemons in 2016:
  • Early sample which was tack sharp, better than the 20/1.7 it replaced. Unfortunately I had to sell it but now I decided to buy a 25mm again ...
  • I got a very bad sample, worse than yours but similar: the left 25% were blurry and only stopping down to f5.6 could help. I sent it back as obviously "defect"
  • The replacement was much better but the left corners were still soft, not on par with the 20/1.7 or even the 25/1.8 I owned before. I gave up and returned the lens
    (I have the perfect 12-40 zoom and I don't need a fast prime which is soft)
  • Finally, I bought a Panasonic 15/1.7. Again, soft left corners. I gave it to repair and they replaced the optics. Now, finally, the lens is how it should have been at the beginning...
I am a little bit disappointed, three lemons in a row. I bought and sold many lenses before and did not have any issue.
Buying lenses no longer is big fun for me, I am very careful now ...
OM-D + Sam7.5, O25, O60, O75
O12-40, O40-150, P 14-140
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
That quality control does not exist.
Sadly but there exists no quality control procedure for this category of lenses that includes a test for decentering or "uneven sharpness". A lens will be subjected to a basic control to see that it "functions" but other than that there is only an occasional random sample that is tested to see whether the assembly like is still working properly or is out of whack.
And a vendor cannot do any quality control either as they don't want to touch an item they are selling as new (unopened).
So the reality is you play in a lottery when buying a lens. Even going through 5 bad copies can happen with almost every lens type from every manufacturer.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
CrisPhoto
Re: That quality control does not exist.
What makes me nervous is the impression that while the cameras and sensors get better and better, the average quality of the lenses is getting worse (if you don't count the PRO lenses).
I did not have any issue with the older lenses I have or had. Other people seemed to be happy too. For example there are not many issues with the Panasonic 20/1.7 lens besides the pathetic AF. They really sold many but this forum did not fill with complaints.
But I see a lot of complaints with Olys new PZ kit lenses and the 25/1.8.
Karld70 Veteran Member • Posts: 3,553
I think you are thinking they do a full test on each lens, I doubt that is the case. They probbly do fast test to see it works, focuses.  Then take an occasional random sample and do a full test to test the "batch"
Well, my first "pro" 12-40 was a piece of garbage, so... :D.
Regarding average performances I'm not sure there's been any drop in performances. Some of today's lenses handily outperform a lot of comparable older lenses while having to manage things such as IS or autofocusing and still being quite cheap I think.
Even regarding tolerances, maybe what we're mostly seeing these days is a rapid increase in pixel density that hasn't been matched by a sufficiently rapid increase in lens tolerances, with a bit more pixel peeping to boot, and possibly, at least for example in the art market, an augmentation in print sizes ? Using Lensrentals' measurements, I doubt there is any lens in the history of consumer photo lenses that's as well toleranced as the modern Canon 11-24mm or 28mm IS USM for example (I mean, look at those tight curves !). Perhaps there is also a very strong asymmetry, currently, in the degree of care each lens manufacturer has about tolerances. Canon seems to have recognise earlier than most others the challenges higher density digital sensors could pose in the long term regarding lens design and manufacturing, maybe Olympus hasn't quite yet taken enough steps to make sufficiently significant progresses.
Digital Dick Senior Member • Posts: 2,379
Re: Not mine
So after reading several threads about decentering on the Oly 25 mm f1.8 lens. I did a careful test with mine. Camera on tripod aimed at a sheet of typed text taped to a wall. Checked the images shot at F1.8, 2.8, 3.5 and 4.0. Don't see any sign of decentering.
Guess I got the only good copy from the batch. (bought mine last summer from B&H).
Dick
 Digital Dick's gear list:Digital Dick's gear list
D Knisely Senior Member • Posts: 2,053
I don't see a problem.  If you find subjects on the left and right that are roughly at the same distances, particularly near the distance of focus on the center, they look comparably sharp to me.  I think your expectations might be unrealistic for this lens!  It has never been regarded as one of the outstanding Olympus primes, nor is it priced as such.
 D Knisely's gear list:D Knisely's gear list
Olympus E-M5 II Nikon AF Micro-Nikkor 200mm f/4D ED-IF Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +3 more
addlightness Veteran Member • Posts: 3,641
IMO, that is NOT a good test case - depth of field is too deep.
Try something with a flat plane - a framed picture, a printed A4 paper, etc.  Shoot upright and upside-down as suggested by other posters.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
OP Betarover Senior Member • Posts: 1,049
Additional image
Some here have suggested I test this lens by photographing a sheet of paper.  I do landscapes and for me such a test may not be useful.  Consider the geometry.  If a sheet of paper is photographed, the edges, and especially the corners, would be at a slightly greater distance from the lens than the center.  If the lens is engineered to compensate for this small difference in distance when it is focused near, has it been correctly engineered for a flat plane when focused on infinity?  Are the elements within the lens engineered correctly so that they move relative to each other in a way that allows both near and distant images to be sharp, corner to corner?  How can one be sure, except by photographing a distant landscape where all elements are so distant as to be considered at infinity?
Another posting feels I am expecting too much from this lens.  Not so.  The image below shows that my Panasonic 14-45mm zoom is much sharper on the left.  Clearly the Oly 25mm is a defective lens, and I am "pleased" that others have posted here having had the same experience.
The intent of this thread is to alert others that there are bad lenses out there and if edge to edge sharpness is wanted, one should be afraid to buy from a source not giving a satisfaction guarantee.
The images below show the scene, edge to edge across the middle, for my Panasonic 14-45mm and the defective Olympus 25mm.  Each was taken at their sharpest f stop, and both are taken in the Hi-Res mode.
Images taken with Oly EM5 Mk 2, Hi-Res mode.
baxters Veteran Member • Posts: 5,319
Re: Additional image
That 14-45 sure is sharp on the left, but falls off on the right and the Oly is better there.
It is distressing that the quality of new lenses is so hit or miss,, but your 25mm isn't as bad as some others  I've seen.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Ribbit74 Regular Member • Posts: 428
Yep, my 25mm was decentered (left side blurry) and my 45mm was also decentered (right side blurry). Seems to be common on both lenses. My 12-40 is flawless and has replaced both of my Oly primes (now sold). My only prime now is the 20mm which is also flawless optically, at half the price of the Oly primes.
 Ribbit74's gear list:Ribbit74's gear list
Olympus OM-D E-M10 II Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
Martian Flatcat
Honestly, I find the Pana image soft on the _right_.  (Look at the small words in the "Legend Auto Sales" sign, for instance.) I'm sure you're trying to give comparable images, but I am wondering whether the focus point is the same in these two images?
I think the suggestion of taking a picture of a flat surface both right-side up and upside down is a good test even if it doesn't match your photo style, as it is a reproducible test of the lens and allows ruling out focus variation and camera concerns.
--Flatcat
Compare f/5.6!  Of course there is more DoF for the 14-45 case.  This test is also meaningless.  The left side detail is much closer than your focus point.  It is meaningless to compare sharpness for ANYTHING except at the focus distance.  If you want to compare, zoom in to the left edge and manually focus to optimal sharpness and then compare.  When looking at 100%, there is NO depth of field.  It is all out of focus except for exactly one distance, and that distance varies over the image surface.
I said you are expecting too much because the Olympus 25/1.8 is simply NOT a great lens.  Perhaps every now and then, somebody gets incredibly lucky with a great copy, but I doubt very much that your copy is out of spec.
It does not review well, and it isn't stellar.  That's why it is also cheap.  For that matter, Nikon and Canon 50mm f/1.8 lenses are designed to be cheap and aren't all that great, even in the new Nikon G version or the Mk II version from Canon.  They are OK, but they aren't pro lenses.
I picked up the Panasonic 25mm f/1.7 @$99 (two copies, actually), and they are both OK.  Not great; not terrible, but OK.  For the price, I'm happy.  I wasn't expecting a pro lens.  Don't confuse this lens with the Olympus 45/1.8, 12/2, 75/1.8, etc.  It is not in the same league (as is the case for the 17/1.8).
Wilu Contributing Member • Posts: 522
i have three primes for m43, all of them Olympus. two suffered from decentering - the 45/1.8 and the 60/2.8 macro. the 12/2 seems to be fine (corners aren't particularly sharp, but it's the same for all of them).
i'm not a notorious pixel peeper but in the case of the 60/2.8 the decentering was obvious enough to be "accidentally" noticed. the 45/1.8 had the advantage that it was mainly used for portraits where edge performance isn't critical. the 60/2.8 was particularly affected when focused to infinity (although it's a macro lens i expect useable output at infinity, too. something all my other macro lenses are capable of).
by the way, the replacement lenses aren't perfect either, but good enough. maybe it was just a case of bad luck, but my confidence in Olympus gear has suffered a bit, lately. in the course of time i owned many lenses - mostly Pana zooms for m43 and mostly 20+ years old Minolta glass for FF. apart from the mentioned Oly lenses i only remember one to suffer from decentering, a Sigma 24/1.8. thanks to the Sigma card they repaired it for free (they had to send it to Japan) even though it was out of warranty.
The 'right' way to test a de-centered lens is to shoot a flat scene like a piece of printed paper. And you've a controlled environment which should be invariant to aperture values. In theory, you should be able to test it from f1.8 to f22.
Your point about shooting landscape is valid in everyday use cases but not for testing de-centering. What conclusion can you draw if a shot looks perfect at f22 but not at f8, say?
Edit: the new pic with the 25mm looks fine to me(left hand is not any blur-er than right) and much better than the zoom.  IMO.
I disagree for multiple reasons:
-The 25/1.8 is well-reviewed, especially for its sharpness. Many comment on its large area of central sharpness even wide-open, which I would agree with if not for the decentering to spoil it. Not sure why you ranked this below the Olympus 45/1.8, which is an older, less optically-complex, but identically-priced, lens that is now made in Vietnam. Theoretically, the 25/1.8 outperforms the 45/1.8 in the corners.
-I don't consider the 25/1.8 cheap, either in relative or absolute terms. I've had much greater success finding acceptably centered copies of Oly's cheaper or equivalently priced lenses (e.g., 14-42 II R, 40-150 R, 45/1.8) and even the 17/1.8, which is more expensive but received more mixed reviews. I never had to go through one bad copy of any of them before I found a copy that was excellent, unlike the 25/1.8 where I couldn't after 5 copies. Today I bought a Panasonic 20/1.7 II new for almost half the price of a 25/1.8 retail price, and the first one I tried (and bought) was perfectly centered.
And I've also tried multiple copies of Canon and Nikon's nifty fifties which were 1/2 to 1/4 the price of the 25/1.8 and didn't have such decentering issues. Canon in particular should be applauded for making such remarkably consistent lenses without decentering for their newer STM lenses. I'm guessing their automation technology has a lot to do with it.
Oly is by no means the only offender of producing a number of decentered lenses (still better than Sony in my opinion - at least it seems limited to this lens), but it's not something that I think can be excused anymore simply because a lens 'only' retails for $400.
