HowTo - NX500 and NX1 - disable recording limit
Started Mar 15, 2016 | Discussions
Xaratemplate Junior Member • Posts: 26
Re: HowTo - NX500 and NX1 - disable recording limit
Is their a mod or hack to disable recording limit on nx300? Or is it the same process outlined for nx1 and nx500?
AxelHawk Regular Member • Posts: 217
Same process.
 AxelHawk's gear list:AxelHawk's gear list
Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake +2 more
Kisaha Senior Member • Posts: 2,300
AxelHawk wrote:
Same process.
Does anyone knows if that actually is true for the 3000 as well?
Well, I just did it on NX300M.
simogere New Member • Posts: 2
With my nx500 and 1.12 firmware this trick doesn't work anymore
Any tip?
If you want to hack your camera it's already included in the hack.
If you don't want to hack it I could make you a file that you copy to SD card and it removes the limit.
martweb Contributing Member • Posts: 823
I would also like to have removing the limit without further hack
For people wanting to remove the 30 min recording limit without hacking the camera:
https://github.com/ottokiksmaler/nx500_nx1_modding/blob/master/Removing_Movie_Recording_Limit_Without_Hack.md
NOTE: This only removes 30 min limit. To have unlimited 4k/UHD on NX500 you need to hack your camera as described here https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/nx-on-wake and here https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/video-bitrate-mods/nx-patch
P.S. Ha - this is my 1500th post, nice as I have NX1000 and NX500  - combined together NX1500
ARSPR Regular Member • Posts: 385
I would really like that your 1501st post were important for you...
... although I suppose you would like it even more than me!
 ARSPR's gear list:ARSPR's gear list
Samsung NX1 Samsung NX 50-200mm F4-5.6 OIS Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Thanks so much, worked on my NX1
Twelve9 New Member • Posts: 1
While recording in 60p I only get 53 minutes of recording time, in 4K I get 105 minutes. Is this the limit of this mod?
I have a 64GB SD card in. Is it calculating the amount of time I have left and that is why I only have that much? Like recording in 60p will fill up my SD card to it's full capacity? I would ideally like to have over 100 minutes for 60p.
What bitrate and what free space on the card? The hard limits are ~74 minutes for 4k and 120 minutes for others.
Does this no hack method work with NX300 too?
You should be able to remove the recording limit on nx300 without hacking by using DEV MENU, could someone with nx300 post the key sequence?
Edit, maybe read this https://www.dpreview.com/forums/thread/3197696
Oyrutra
Oyrutra New Member • Posts: 16
otto k wrote:
This should (could?) work on nx300, nx300m, nx30, nx2000 and nx3000.
Developer option access hack not working on my NX3000, latest firmwaew updated (v. 01.11)
Any clues? I really need it to let the lens adapter work.
ttbek Veteran Member • Posts: 4,869
Can always mod the adapter physically to properly push down the lens present pin (if you look inside the mount it is the silver wide pin that is supposed to be pushed down by a flange from the lens or adapter. ... but manufacturing hasn't been precise on many adapters.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Oyrutra
Hey ttibek, thanks for response! Yes, I already fixed the adapter with some tape on flange position to keep the button pressed, but it's not the preferred option - took a good while off trial and errors before catching the right ratio and am pretty sure it won't be great when times will come to switch often with native lenses. If there's any info to hack the nx3000 firmware would be way better for me, but thanks for reply!
Helmar Rudolph New Member • Posts: 7
NX1, 1.41 firmware. No DEV menu following the sequence using a micro-SD card with an SD-adapter. Giving up.
 Helmar Rudolph's gear list:Helmar Rudolph's gear list
Samsung NX1 Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Double checked the file is 12 bytes after saving?  It is important.  It can take some tries to get it right.
I'm not sure that with the last firmware you still can use this trick
