As good as it gets?
Started Mar 15, 2016 | User reviews
(unknown member) Forum Member • Posts: 67
As good as it gets?
Extremely sharp and detailed results
Corner sharpness not too different from centre
Very little light fall off in the corners
Completely usable at f/4
Aberrations and distortion so little as to be no problem
Attractive Bokeh at long focal lengths and wide apertures
Super fast and accurate AF
Internal focussing - no extension, no rotating front element
Beautiful zoom ring (90 degrees of turn, light enough to work with one gentle finger, but no zoom creep
Does not extend on zooming
Results with 1.4x extender as good (for all practical purposes) as with the bare lens [Have not yet tried the 2x]
USM - so can manually focus without messing around with switches and buttons to disable AF
Extremely effective Image Stabilisation
Is not prone to flare
Very tough construction
Sealed against dust and moisture
Considering what you are getting, it is not too big and not so heavy
I never knew lenses could be this good. It is close to perfect ... or a least, as good as it can get.
Canon EF 70-200mm F4L IS USM
Telephoto zoom lens • Canon EF • 1258B002
Announced: Aug 24, 2006
Ktrphoto's score
5.0
Average community score
4.7
Dave
Dave Veteran Member • Posts: 6,231
Re: As good as it gets?
Would you consider the added weight and expense of the EF 70-200mm f/2.8L IS II USM unnecessary?
Thanks for reminding me of a favorite movie.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 70-300mm f/4-5.6L IS USM Canon EF 135mm F2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF-S 24mm F2.8 STM +10 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
For many, the f/4 aperture is all they will ever need and the lighter weight and lower price are big pluses. As a pro, however, the f/2.8 aperture on the 70-200 f/2.8L IS II is absolutely necessary. I cannot count the number of times I've shot speakers at podiums, sporting events, portraits, architectural details, etc. at f/2.8.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 16-35mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 11-24mm F4L +3 more
salamander1 Senior Member • Posts: 1,427
nice shots! although the f/4 is of course good, the f/2.8 is always better.
HarryLally Senior Member • Posts: 2,692
Yes indeed. Lovely lens. I also had the non-IS version which was almost as good, maybe even better up to 120mm or so (creamier colours but just as sharp) but slightly inferior from 140-200mm. It also suffered from flare occasionally if the light sources were in the wrong place. Have never had that problem with the IS version. The main/ only weakness with both lenses is the rather long MFD, which makes close portraits difficult at 70mm or so. I've sometimes been tempted to change to the 70-300L but am glad I haven't done so. Just the right weight and balance on the 6D. The f2.8 version would be too heavy and unbalanced for me.
OP (unknown member) Forum Member • Posts: 67
The wider aperture is unnecessary for me, and now that the latest cameras shoot clean images at ISO 6400+I don't see why anybody needs f/2.8 to freeze subject motion.
So for me the question was "Is slightly better Bokeh wide-open worth double the price and twice the weight"
And the answer is No.
Not that the extra weight would have bothered me much. I already lug a pair of Canon 1-series DSLRs around with me, so I am used to carrying weighty equipment.
I read that the f/2.8 version gives slightly sharper results, but I cannot see the difference.
For a full time sports photographer the slightly better AF in low light and the brighter viewfinder image might be enough to justify the extra weight and price. I'd also expect the f/2.8 version to work better with the 2x Teleconverter.
Abu Mahendra Veteran Member • Posts: 5,312
Moot question for me. I opt to own and keep both lenses.
>> I am already lovin' the Canon EF 35L II lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 16-35mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon EF 70-200mm F4L IS USM Canon EF 100mm F2.8L Macro IS USM +5 more
Steve Balcombe Forum Pro • Posts: 15,582
It's very hard to fault if you want a 70-200 f/4. The long thin shape makes it difficult to fit in many bags - that's about all I can think of.
However I agree with those who are saying that f/4 is its weakness. I know that's a bit like saying the problem with a 1lb bag of sugar is that it doesn't have 2lb of sugar in it, but when you look at the main applications for a 70-200 lens they tend to be things which benefit greatly from an f/2.8 aperture so an f/4 lens will always be second best.
Or if you want it as a general purpose tele zoom, rather than a specialist lens for sports say, or portraits, then 200 mm is often not long enough and the 70-300L starts to look like a more attractive choice.
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
I was with you until you made your wording include others as in..."I don't see why anybody needs..."
You and I may not need it, but others may need or want this....in those cases the f/2.8 version is there and is the best choice.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM Canon RF 35mm F1.8 IS STM Macro +31 more
Batzorig
Batzorig Regular Member • Posts: 135
HarryLally wrote:The main/ only weakness with both lenses is the rather long MFD, which makes close portraits difficult at 70mm or so.
What's Long MFD? Is it Minimum Focus Distance?
I am considering to use 70-200 for Infrared conversion and wondering if 70-200mm f4L IS will be a good choice.
Bat
 Batzorig's gear list:Batzorig's gear list
Canon EOS 5D Mark II Canon EOS 5DS R Canon EF 24-105mm f/4L IS USM Canon EF 50mm F1.8 II Canon EF 70-200mm F4L USM +3 more
Yes. From memory, it's about 12ft/ 4m. So not great for close portraits at 70mm or so FL. Otherwise, it's a wonderful lens...also not too big or heavy. Excellent resolution/ sharpness, contrast and colour.
maiaibing Veteran Member • Posts: 5,139
Bokeh is not better on the f/2.8 IS L II than the f/4.0 IS L
Bokeh is the same - exactly the same in fact (I tested this). You get more blur with the faster lens @f/2.8 which the slower lens cannot match - but that's something else.
For bokeh the two lenses are (as always) best wide open. So bokeh @f/4.0 is somewhat better on the f/4.0 lens than the f/2.8 lens - because its stopped down and you can see the adverse effect of the aperture blades on the bokeh.
After f/4.0 its a tie between the two.
 maiaibing's gear list:maiaibing's gear list
Canon EOS 5DS R Canon EF 300mm f/2.8L IS II USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Canon EF 100-400mm F4.5-5.6L IS II +5 more
High MPIX challanged compared to 70-200mm f/2.8 IS L II?
Its a world class zoom for sure. On the 5DII and 5DIII I could never see the difference to the 70-200mm f/2.8 IS L II. I only got the faster lens because I needed the extra stop.
However, I did notice that DXO ranks its resolving ability somewhat lower on the 5DSR compared to the 70-200mm f/2.8 IS L II.
So maybe it takes a slight hit at very high MPIX. However, since I only have one of them now I have no way of confirming this myself.
pixseal
pixseal Veteran Member • Posts: 4,061
The MFD is 4ft (1.2 m) - quite short IMHO.
 pixseal's gear list:pixseal's gear list
Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 500mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II +14 more
quiquae Senior Member • Posts: 2,265
Well, when you're accustomed to the nimbleness of 55-250 STM, which has an MFD of 0.85m and magnification of 0.29x, 70-200F4LIS's 1.2m MFD /0.21x magnification feels positively Jurassic. One of the few complaints I have about the lens.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
I did not deny that someone else might have a good reason for wanting an f/2.8 version. I merely said that I cannot see why!!
Sidekicker Senior Member • Posts: 1,771
Wow, I guess Roger's comment must have been festering over the past six months...:-D
 Sidekicker's gear list:Sidekicker's gear list
Sony RX100 VI Sony a6600 Sony E 70-350mm F4.5-6.3 G OSS Sony E 35mm F1.8 OSS Sigma 56mm F1.4 DC DN | C (X-mount) +4 more
Dan_168 Forum Pro • Posts: 11,055
it's a pretty nice lens, cheap and small and light, but I like the 70-200 F2.8 IS II much better and after I got the F2.8 version I have never touch that for long time and then I sod it.
