lost epl6 battery and sd card cover
Started Mar 14, 2016 | Discussions
Hgreblo1
Hgreblo1 Senior Member • Posts: 2,737
My bottom cover slipped off my epl6 and was lost.  I ?don't see a replacement on the oly accessories page.  Any suggestions on what I can do to keep this area clean and secure?
HGreblo
Thanks in advance for your help.
 Hgreblo1's gear list:Hgreblo1's gear list
Kodak EasyShare C875 Kodak EasyShare Z712 IS Kodak EasyShare Z885 Olympus C-8080 Wide Zoom Panasonic Lumix DMC-GF1 +6 more
Olympus PEN E-PL6
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: lost epl6 battery and sd card cover
HGreblo
A quick search found this, a more careful search may find the right colour http://www.getolympus.com/us/en/e-pm1-battery-cover-door-white.html
E-PL5 and 6 are basically the same cameras, so the door will fit.
Regards....... Guy
Hgreblo1
OP Hgreblo1 Senior Member • Posts: 2,737
Re: lost epl6 battery and sd card cover Thank you Guy. I ordered 2 n.t.
No text.
baxters Veteran Member • Posts: 5,319
Make sure the notches that hold the pins are intact. A piece of plastic snapped off my EPL5, so the cover often fell out when I would take the SD card out and leave the camera laying with the door open.
I put a tiny drop of epoxy on the end of the broken part, making sure I left plenty of room for the pin. Let it dry and the cover snapped in fine.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Hgreblo1
Thanks for the heads up Baxters,  I'll try a little epoxy because every time it seems that I take the card out the cover comes off.
HGreblo
