Value of EPL5 and EPL6
Started Mar 13, 2016 | Discussions
Gesture Forum Pro • Posts: 10,247
Been very happy with my EPL1.  Great value.  Thinking I would like the 16 MP sensor, but budget is limited.  I was thinking of one of the above. Olympus has so many models now. How do the above rate as improvements in this line.  Thanks.
Olympus PEN E-PL1 Olympus PEN E-PL5 Olympus PEN E-PL6
baxters Veteran Member • Posts: 5,319
Re: Value of EPL5 and EPL6
I still have a working EPL1. I usually take it out at least once a year for a day of shooting. It's a fine camera. I bought mine in 2010 and it actually cost more than twice the price of the refurbished EPL5 that replaced it in 2014.
The EPL5, which I also own, has better handling. The tilt screen really helps when the sun might reflect off the EPL1. You can shoot low without getting down on your knees. It also has touch screen, touch to fire the shutter. A big upgrade is the dial, which makes using the SCP practical.
The 16MP sensor is just better for extremely poor lighting conditions.
The menu is pretty similar. You should be able to pick up an EPL5 or EPL5 and use it. They also use the same battery as the EPL1. The newer cameras have a metal body too, and are smaller. You do lose the built in flash, and you might lose the accessory flash too. I've misplaced two of those flashes.
My recommendation is to upgrade if you can still find either of the EPL5 or EPL6 for sale.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
pterosonus
pterosonus Regular Member • Posts: 282
My advice is to buy a used or refurb E-M10 unless you are determined to stick with the pen style of body. I bought the EPL-6 at blow out price as a second body to my E-M10 and returned it. The ergonomics were terrible, it only has one control wheel, lacks the 3 axis IBIS, has lower resolution LCD and does not have the zero second anti-shock setting. The E-M10 is just a better and more advanced camera. Prices are cheap now that the model II has come out.
 pterosonus's gear list:pterosonus's gear list
Olympus Stylus XZ-10 Olympus OM-D E-M10 II Panasonic GX850 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Rokinon 7.5mm F3.5 UMC Fisheye CS +3 more
Karld70 Veteran Member • Posts: 3,553
I don't know what your budget is, the epl7 seems to be priced reasonable
gary0319
gary0319 Forum Pro • Posts: 10,540
I've not owned an E-PL5 or 6, but do own a PL7 and have owned an E-M10 which can be purchased for about the same price as the earlier PL 5/6 versions, and have the newer firmware, 3 axis IBIS, and 0 sec anti shock.
I did sell the E-M10 to upgrade to the E-M 5 II, but keep the PL 7 as my street/festival camera...wonderful little gem.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
alexisgreat Veteran Member • Posts: 6,459
Isn't the E-M10 $449 or $499? About the same price as the E-PL7. The E-PL6 is $299.
 alexisgreat's gear list:alexisgreat's gear list
Olympus C-7070 Wide Zoom Fujifilm FinePix HS20 EXR Fujifilm FinePix HS50 EXR Olympus E-520 Olympus PEN E-PL6 +3 more
OP Gesture Forum Pro • Posts: 10,247
Thanks for responses.  I'll have to check Olympus store and see if refurbs are offered on any models.
Hgreblo1
Hgreblo1 Senior Member • Posts: 2,737
I have an epl6 that I like very much.  One thing to note though, it is very easy to lose the cover for the battery and sd card spot on the bottom of the camera.  I ordered a couple of extras to have on hand.  You don't want to get dirt into the sd card area on the bottom of the camera.
I like the layout of the pl6.  With the articulated lcd I can keep the flash on the camera at all times and not have the worry of losing it.
I bought the one lens version of the camera for 299,00.  I would recommend buying the 399.00 version with two lenses.  I also have a pl2 with two lenses so I didn't need the upgrade.
I need a camera that will stop movement better as I have many grandchildren and great grandchildren.  I have been thinking about getting the gx8.  That should remove the blur that I get with many images of the grandchildren.
HGreblo
 Hgreblo1's gear list:Hgreblo1's gear list
Kodak EasyShare C875 Kodak EasyShare Z712 IS Kodak EasyShare Z885 Olympus C-8080 Wide Zoom Panasonic Lumix DMC-GF1 +6 more
aliasfox Senior Member • Posts: 1,375
If you're going to Olympus's Refurb store and you're not in a hurry, wait for them to bring out the 20% off sale that they have every so often - the E-M10 goes for $349 normally, the 20% coupon would bring it down to $270.
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
berni29 Veteran Member • Posts: 3,119
Hi
I also agree that you should wait for the right deal on a EM10. It is a great camera, and has some truly useful features over the epl5/6.
Berni29
EM1, EM-10mkII, GM1/5 + Pana 12-32mm, 35-100mm f2.8, 20mm f1.7, Voight 17.5mm f0.95, Oly 12-40mm, 45mm, 50mm F2 macro, (prev EM10, EM5, GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
Nope. GX8 is not going to do any better than the EPL6 with the same lens.  To remove fast-moving-grandchildren blur, there are only two solutions.
The first is to set a higher shutter speed, get a lens with the fastest aperture you can afford,  learn how to focus it properly, and perhaps add a bounce flash,
The second is to have them like you enough that they will pause for a proper portrait.
Dreeke Senior Member • Posts: 1,080
faster lenses for less blur
Hi,
I took a look at your gearlist but you only list your cameras, so I don't know what lenses you own. But I agree that a faster lens is a better buy for less blurred photos.
I would recommend the olympus f/1.8 lenses. You could start with a 45mm f/1.8, a great portrait lens that can usually be found at a reasonable price. But be aware of the ever present danger of GAS! If you like the fast prime more will somehow appear in your camera bag
 Dreeke's gear list:Dreeke's gear list
Olympus PEN E-PL5 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +15 more
Hgreblo1
Re: faster lenses for less blur
Hi,
Thanks for the reply, I only have 2kit lenses withy the camera, but I have some legacy glass that I use with manual focus.   I have a super takamer 50 mm 1.4, and a 135 mm 3 something.
HGreblo
HGreblo
Depends on what the blur is from. If the blur is from kids being out of focus (running around so that the AF has trouble locking onto them before they move again), then yes, a Panasonic with DFD (G7, GX8, GH4) would help.
However, if your blur is from having to use too slow a shutter speed (say, slower than 1/60, maybe slower than 1/80, depending on how hyper those kids are), then a prime lens with an aperture of 1.4-1.8 would do better than your kit lenses. They'd also reduce your need to use the flash.
As a point of comparison, if you're currently using your kit lens at 25mm, f/4.2, ISO1600, and 1/30 sec, the Olympus 25mm f/1.8 lens would allow you to shoot with the same ISO setting, but at about 1/160 sec shutter speed.
Hgreblo1
Thank you aliasfox for the valuable information re:  blur
HGreblo
traveler_101 Senior Member • Posts: 2,203
I had a E-PM2 which shares the same sensor, 2-axis IBIS, and control layout as the E-PL6 but is a lesser camera (no movable LCD, no mode dial, smaller and cramped) and the camera took a lot of good pictures: a lot better than a E-PL1 (which I had at one point), much sharper, more dynamic range, much higher usable ISO. I think you will notice it as a great improvement (though there are those who claim they like the colours on the old 12 mp sensor better). Ok, sometimes shutter shock happened with the E-PM2 - but very infrequently.
Sure if you have the extra cash and like the OMD style, the E-M10 is clearly the better camera. I would say it depends on how much you can pay or want to pay. For example
$399 for the E-PL6 with the twin lens kit! Sell the lenses on e-bay and the camera is like $150 (figuring $100 for the 40-150 and $50 for the 14-42).
http://www.bhphotovideo.com/c/product/1188622-REG/olympus_v205051bu040_pen_e_pl6_mirrorless_micro.html
$499 for the E-M10 with the 14-42. So you are looking at a $450 camera
http://www.bhphotovideo.com/c/product/1026114-REG/olympus_v207021su000_om_d_e_m10_mirrorless_micro.html
Still the E-M10 is clearly better deal than the E-PL7 which comes in at the same the same $499
http://www.bhphotovideo.com/c/search?Ntt=e-pl7&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
gary0319
Since budget was an issue, I checked the Olympus refurbished site and both  bodies were about $359. Prices will vary there, though.
Hgreblo1
Hi baxters,
Thanks for the information on blurring and the gx8.
HGreblo
tkbslc Forum Pro • Posts: 17,527
Much better sensor and AF!
Compared the the E-PL1, you would enjoy much better performance in just about every category.  The sensor has higher resolution, better dynamic range and less noise in higher ISOs.   The responsiveness and performance of the camera is much improved.  The AF is extremely fast in the newer cameras, essentially instantaneous in most conditions.
You will find it to be a great upgrade.
Re: Much better sensor and AF!
Thanks.  Just the kind of info I was looking for.
