Compare panasonic 14-140ll with 35-100 f2.8
Started Mar 13, 2016 | Discussions
tomhongkong Veteran Member • Posts: 4,723
OK I know this should be a no brainer, but can anyone actually show me some comparison shots, taken in good light  ( so the wider aperture of the 35-100 does not carry the day)
it's a lot of money for me to fork out for the faster lens, but I will if I get demonstrably better IQ.
I find it hard to get sample photos attached to reviews which show much....eg that on Photozone, which they say is sharp, does not look very good to me...not that 'sharp' is the whole of IQ.
Of course I get water resistance as well which is valuable to me.  Can anyone comment on how real that is (apart from a rubber  ring round the mount)
Anything else as an advantage/ disadvantage of the upgrade?
tom
Panasonic Lumix G 14mm F2.5 II ASPH
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Re: Compare panasonic 14-140ll with 35-100 f2.8
There are lots of YouTube videos extolling the virtues of the 35-100 2.8.  Watch them and decide if it's worth it.  I might own it one day.  I have no interest in the 14-150 at all.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
robonrome
robonrome Senior Member • Posts: 2,334
6
i don't have samples, but i did have both the pany 14-140ii and the 35-100 2.8 for quite a while together. I was very surprised at how well the 14-140 held up and in good light frankly I could not separate the two. In the end I chose to keep the 14-140 as a lightweight travel solution (combined with 75/1.8 for when I need speed) and sold the 35-100 to fund the 40-150 only pro 2.8 for when I wanted the ultimate combination of IQ and speed and weight wasn't a factor.
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
Fredrik Glckner Veteran Member • Posts: 3,894
The Lumix X 35-100mm f/2.8 is not very sharp wide open at 100mm.
I have compared the two lenses at 100mm here:
http://m43photo.blogspot.com/2015/10/lumix-tele-lenses-compared.html
and here:
http://m43photo.blogspot.com/2014/01/comparison-100mm.html
You can compare for yourself in the above articles.
Moti Veteran Member • Posts: 8,965
5
it'sq a lot of money for me to fork out for the faster lens, but I will if I get demonstrably better IQ.
If the wider aperture and low light performance are of no interest for you, I wouldn't go for the 35-100. The 14-140ll is a very good lens and more versatile. If I'm travelling and limited to take one lens only, it will always be the 14-140.
Moti
photofan1986
photofan1986 Veteran Member • Posts: 3,841
That's what I though too, at first, when I got my 35-100. Actually, it's quite soft at closer focusing distances. The problem disappears at longer distances, or if you close down a little.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
Tom Axford Forum Pro • Posts: 10,100
It may be that you really want the extra range of the 14-140, but if not and you value small size/weight as well, I'd suggest that it is definitely worth looking at the 35-100mm f/4-5.6 which is a superb little lens which is both stunningly small and light but also has IQ that is hard to fault. I use mine a lot.
john isaacs Veteran Member • Posts: 8,444
tom
The reason to get the 35-100 f/2.8 is for the wider aperture.  Not necessarily to shoot at f/2.8 (although that is an option if you want to limit DOF), but also to see and focus at f/2.8.
If you only care about shooting in good light, then most recent m4/3 lenses have good IQ.  And with good light, you can keep the shutter speed up and worry less about shutter shock.
I have both, use the 35-100 f/2.8 almost exclusively for portraits now.  I rarely use the 14-140 because for landscape work I prefer to be able to get down to 12mm, but I'll take it out occasionally if I'm just shooting random.
berni29 Veteran Member • Posts: 3,119
Hi
I have the 35-100 f2.8 and value it for being able to shoot at f2.8 even in good light for greater DOF control. Being weather sealed is not a big deal for me personally, although it is occasionally useful. If that is of no great benefit to you and size matters I would go for the new tiny Pana 35-100. If you don't mind the bulk of the 14-140II then it a no brainer to go for that.
Berni29
EM1, EM-10mkII, GM1/5 + Pana 12-32mm, 35-100mm f2.8, 20mm f1.7, Voight 17.5mm f0.95, Oly 12-40mm, 45mm, 50mm F2 macro, (prev EM10, EM5, GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
davidedric Veteran Member • Posts: 7,339
I do have the 14-140, but not the 35-100, and I'm afraid I don't do comparison shots, so why am I posting?
Well, I do have the 12-35 f2.8, which is said to be similar quality.  I use the 14-140 as my go to travel lens, and I know I can trust it.  I think if you are posting on the web at say 1200 pixels on the long edge, you won't see a noticeable difference.  However, on a decent monitor, I certainly can see the difference in IQ.  For "serious" landscapes (which is what I bought it for) I would definitely use the 12-35.
Dave
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
I don't agree with that.
I have both lenses, and I find the Lumix X 12-35mm f/2.8 to be almost flawless (it could be a tad bit sharper wide open at 35mm), while the Lumix X 35-100mm f/2.8 has problems at max tele, max opening.
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Dave
So, do have experienced shutter shock when using the 14-140 with GX7? How do you get around it?
The reason I ask is maybe replacing my 14-45 with 14-140 II for walk around longer reach travel lens.
You have original 14-140 or MK2?
Lena
Like others here, I suffer from chronic GAS.
Gear Acquisition Syndrome.
a few hundred nautical miles SW : 17º 52S, 149º 56W
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
Fair enough.  Just adding a thought.
Dave
Dave
The reason I ask is maybe replacing my 14-45 with 14-140 II for walk around travel lens.
Lena
I do have the mk 2
I haven't tested for shutter shock on the gx7.  However, I don't generally shoot moving objects where shear would be noticeable, so I rely pretty much exclusively on the e-shutter (except when shooting flash, of course).  However, if I were shooting something moving fast, I would probably be using a ss beyond the shutter shock range anyway.
I did test it quite extensively for shutter shock on the G5 (using tripod, indoors, solid floor and cross stitch tapestry as a target).   I did certainly find it, in the range others have, and so decided on the electronic shutter strategy.
I am literally just back from two weeks in South Africa with the 14-140 ll on most of the time (on my new G7 this time).  I haven't had chance to look at the images yet, but I am confident the lens will have performed well.
Dave
Chippy99 Senior Member • Posts: 2,182
Perhaps consider the 45-175?
I thought long and hard before buying the 30-100 and I have to say u was really impressed with the 45-175. It's a great lens and incredibly good value.
 Chippy99's gear list:Chippy99's gear list
Sony RX100 Leica Q2 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 +4 more
Joe789
Joe789 Regular Member • Posts: 109
Lena
I have the 14-140 MK II and really love it for its quality and versatility when traveling. I had a OMD- EM5 , but sold it to get the GX7 ---- liked the handling and form factor of the GX 7. It handles very well, has more function buttons to use, and feels very well built.
However, it, in combination with some of my lens, suffered much more shutter shock than the Oly did with the same lens. Use of the electronic shutter helps the problem, but I did not know that until after taking a BUNCH of pics on a Norway trip [..was not able to check the pics on a computer until I got home]. I just noticed that many of the pics were not very sharp [and/or blury]. After comparing the two shutter types, I found that up to about 1/360 sec., SS is a real problem between the GX7 and the Pana 14-140 II. You WILL need to use the EFC shutter setting to take care of that problem!
.BTY-- the lens I was using included Oly 9mm, Pana 14-140 II, Pana 12-35 2.8, Oly 45mm 1.8, and the Pans 15mm 1.7. I think Oly does better with Shutterstock than Pana.... just one persons opinion...
 Joe789's gear list:Joe789's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 III Panasonic 20mm F1.7 II Panasonic Leica DG 50-200mm F2.8-4 Olympus 12-45mm F4 Pro +3 more
OP tomhongkong Veteran Member • Posts: 4,723
Thank you all for replying and trying to help me in my choice. Thanks in particular to Frederick Glickner who posted the comparison shots of all the longer Panny lenses.
Based on his selective crops, to me the 35-100 does not do very well in terms of sharpness at 100mm even stopped down, and the 100-300 seems to me to be easily the best of the bunch.
So I have the following conundrum
35-100 is the only water resistant lens
100-300 is sharpest, but starting at 100 is a bit awkward for what I want to use it for (sailing events).....most shots are in the 40-100mm range. I would have to have another body with shorter lens as well (not impossible)
14-140ii is reasonably sharp, very convenient (I can get shots at the start when boats are close to me, as well as when they are further away).
Based on your experience, I am going to stay with 14-140ii for the time being.
I have more comparison to do with Nikon 1 V3 and 30-110 (x2.7) as well. Before everyone laughs and says that the 1" sensor does not cut it, the best shots I have so far are from that combination. However I am still a newbie with GX8 and there may be better things to come.
see here
http://www.dpreview.com/forums/thread/3975489?page=2
tom
see here
tom
Ha ha ha!
jeffharris
jeffharris Forum Pro • Posts: 11,409
In the same vein there's also the 45-150mm. It's slightly smaller and lighter than the 14-140mm II (52mm vs. 58mm filters) and costs quite a bit less… $250 vs. $600. It's slightly sharper over it's range and has a hair more reach, too. I use it with several primes or the 12-40mm with my GX8 (previously GX7). It performs well.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
Here ya go.
I have the 12-35 and 35-100 f2.8 zooms because I'm an event pro and shoot in low light a lot. For my travel and landscape work, though, I recently got a 14-140 II for the convenience of not having to constantly swap lenses as I walk about. Like you, I wanted to know if the 14-140 IQ was good enough, so I did this test with all three lenses at f5.6. The f2.8 zooms are slightly better at some focal lengths, generally at the edges. But, I'm amazed how good the 14-140 is and have no hesitation about using it for images I want to print big.
For each image, I focused on the sign left of center. Shot handheld, OIS on, with e-shutter.
14-140 @ 14mm
12-35 @ 14mm
14-140 @ 24mm
12-35 @ 25mm
14-140 @ 34mm
12-35 @ 35mm
35-100 @ 35mm
14-140 @ 46mm
35-100 @ 50mm
14-140 @ 69mm
35-100 @ 72mm
14-140 @ 97mm
35-100 @ 100mm
14-140 @ 140mm
The way to make a friend is to act like one.
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
