Got to shoot with the K1 today...
Started Mar 9, 2016 | Discussions
Sandyramirez Contributing Member • Posts: 625
18
Got to shoot a wonderful model from Wilhelmina today using the K1 and the new 24-70/2.8. Many thanks to Jim Malcolm of Ricoh Imaging for bringing the K-1 to NYC so I could shoot it. Pics in a bit after I go through it all. Cannot post a full res as the firmware is still not finalized, but I'm sure you folks will like it.
Overall from the two hours I got to spend with it, the K-1 is an incredible camera. It's on par with the top of the line Canons or Nikons. Seriously I now will get myself one, a great companion to my 645Z.
Feel free to ask questions below. Will be happy to talk about camera controls etc
 Sandyramirez's gear list:Sandyramirez's gear list
Fujifilm FinePix X100 Ricoh GR Pentax 645D Pentax Q Sony Alpha NEX-6 +30 more
HD Pentax D FA 24-70mm F2.8 ED SDM WR Pentax 645Z Pentax K-1
JNR
JNR Veteran Member • Posts: 4,652
Re: Got to shoot with the K1 today...
What's your sense of AF responsiveness and accuracy at first blush?
I'm assuming you only got to shoot with the one lens, so observations will be limited to that combo.
JNR
www.jamesrobins.com
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
Winder Senior Member • Posts: 1,546
Can you give us your impressions of the AF?
 Winder's gear list:Winder's gear list
Sony a9 Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM Sony FE 55mm F1.8 Sony FE 35mm F1.4 Sony FE 90mm F2.8 macro +3 more
OP Sandyramirez Contributing Member • Posts: 625
5
Great question! I really wanted to test that today so I did a lot of jumping across the field of view with the model and fast walking testing both the burst and clear of the buffer and the AF tracking. Using the 24-70 I would call it on par and slightly more accurate than the Canon 1DX. Very fast and accurate tracking, zero hunting even when the model was wearing an all black dress and a hit rate based on what I am seeing in the DNG files of about 97-98%.
The AF responsiveness is in a new league as far as Pentax DSLRs are concerned.
Just replied above to that
JNR
Oh my, even if you're embellishing a bit, that practically qualifies as a new universe...
JNR
www.jamesrobins.com
Thank you.  Today all modern cameras have amazing IQ.  The big question that will determine if I continue to use Pentax is the AF.  Sounds like good news.
zakaria
zakaria Veteran Member • Posts: 6,556
Sounds great!
What about handling noise at 6400 and up?
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
No embellishment. The AF with the new 24-70 is amazing. I tested the 70-200 last year on the K-3 and thought it was good, I'm sure on the new K-1 that lens will perfom just as well as the 24-70
ozdean
ozdean Forum Pro • Posts: 28,665
Really up with a 1Dx? WOW
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Sounds great!
Unfortunately I didn't really shoot above ISO 320 as we were doing a lot of street style fashion today and I had no need to go that high. If you go to Instagram, Jim Malcolm (@view360) has been doing a lot of high ISO work and can better answer that for you
Having used the 1Dx extensively in the past, yes on par with it as far as tracking and response with the 24-70/2.8
I agree. Where the K-3 can frustrating at times in the same applications as what I did today, the K1 was a total breeze.
robbo d Veteran Member • Posts: 3,884
Im not far from going to FF and the D750 beckons, but your take on the AF is very interesting.
What apertures do you shoot your work in mainly ?
I completed a first swimwear shoot on the weekend for a local designer known to me and at my weddings so far,I avoid shooting wide because its often a disaster with my apsc gear.
Using focus points more is slightly better than focus and reposition. I too dislike the k3, its going to be one of the first items leaving to fund a FF  purchase.....
For me the K1 would fill the spot my K3 currently occupies as a "responsive" camera to shoot certain things that the 645Z is not suited well for. I usually shoot between f/4 to f/5.6 on the 645Z and usually do the same with my other gear. Today I did however to test the limits shot a lot wide open at 2.8 with the 24-70 and was amazed how many shots the tracking focus nailed perfectly. My old 1Dx was no where as accurate at 2.8
Oh damn, that throws the cat amongst the pigeons. ......
Didnt think it would be quite so good.
shutter2013 Regular Member • Posts: 115
I can also say that I got to try the K1 with Ricoh canada last week. I'm not a pentaxian. I shoot Sony and in the past Canon. Side by side with a D810 in ISO3200 lighting and with the 24-70 2.8 the K1 was at least as fast as the D810. I cannot speak to the 1dx as I didn't have one side by side.
Younes B Senior Member • Posts: 1,257
Sounds interesteing re : AF improvements.
Out of curiosity, what king of tracking did you do ? Walking model or faster action ?
Thanks!
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +6 more
MightyMike Forum Pro • Posts: 41,691
If its as good as people say, what are Pentaxians going to have to complain about, it would be like the end of the world!
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
asahi man Senior Member • Posts: 1,060
5
Sounds great!
You can use the 10.000 ISO like the 2500 ISO in the K-3 😉
Best regards
