Lense for canon 80d
Started Mar 8, 2016 | Discussions
curiosity123 New Member • Posts: 1
Lense for canon 80d
Hey guys,
I need suggestions, I am planning to buy canon 80d (my first DSLR). But i don't know which lenses to buy. Should i get:
either 18-135 mm
http://www.amazon.com/Canon-18-135mm-3-5-5-6-Standard-Digital/dp/B002NEGTT2
or both 50mm f1.8  and 55-250mm IS STM
http://www.amazon.com/Canon-50mm-1-8-STM-Lens/dp/B00X8MRBCW/ref=sr_1_1?s=photo&ie=UTF8&qid=1457462108&sr=1-1&keywords=canon+50mm
http://www.amazon.com/Canon-EF-S-55-250mm-F4-5-6-Cameras/dp/B00EFILVQU/ref=sr_1_3?s=photo&ie=UTF8&qid=1457462159&sr=1-3&keywords=55-250mm+canon
I will probably will do mostly family photos, landscapes, portrait and a little sports photography.
Thank you.
Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EOS 80D
Michael EOS5D Regular Member • Posts: 342
Re: Lense for canon 80d
Remember that the actual focal length will be ×1.6 whatever lenses you choose.
crashpc Veteran Member • Posts: 7,237
For landscapes, cheap solution is Canon 10-18mm, or Tokina 11-whatever(that one has larger aperture, tinny hair sharper image to the corners and is more expensive).
For portraits 50mm f/1.8 STM is good cheap choice.
For reach and sports, 55-250mm is good cheap choice.
Of course there are way better lenses, but I don't see you going for these to pay big $$$$.
18-135mm IS STM is good vide range lens, and If you want a one lens situation for little money, it would be it, but if it was my decision, I would not buy 80D at first place, but T6i/T6s, and I'd go with those lenses mentioned before, if not better. Good new body without adequate lenses will not help your situation.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
Spotted Cow Senior Member • Posts: 1,586
Also, remember that there is the new 18-135mm IS USM lens coming out.
jp4 Senior Member • Posts: 1,202
I think that's you best choice.
 jp4's gear list:jp4's gear list
Canon PowerShot G5 X Canon EOS 80D Tokina AT-X Pro 11-16mm f/2.8 DX II Canon EF 100-400mm F4.5-5.6L IS II Canon EF-S 18-135mm F3.5-5.6 IS USM
Dave
Dave Veteran Member • Posts: 6,231
Re: Lense for Canon 80D
What about the 15-85?  Less reach but wider at the short end.
My daughter loves her 10-18.  While not the fastest lens, it represents a good value.  It's also nice and light.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
Dave
My son rarely uses his 50mm f/1.8 but loves his 55-250mm.  He rented a 100-400mm in Africa and found it an easy transition.
Why do you prefer the T6i/T6s over the 80D?  I prefer pentaprism to pentamirror and anticipate the 80D's autofocus will be superior.  I do wish the 80D had DIGIC 7 and 4K video.
I don´t prefer T6i over 80D. Never did. But I would prefer that choice in the "name of" buying better lenses, because of money savings on that cheaper body, which is also good.
BAK Forum Pro • Posts: 26,019
18 - 135 is best bet.
See the headline.
BAK
Re:Engraver kknows focal length
The actual focal length will be the focal length that Canon engraved on the lens.
BAK
Re: 18 - 135 is best bet.
BAK wrote:
See the headline.
BAK
And the new 18-135 USM seems to focus faster than the 18 -135 STM.
https://www.youtube.com/watch?v=SPj5NxH7WWU
j-p
