Whats up with Panasonic 14mm and 20mm on Olympus
Started Mar 5, 2016 | Discussions
Egregius V
Egregius V Contributing Member • Posts: 538
Re: A case of overblown worries that no longer apply to newer cams...
Chas2 wrote:
The 20 has a great reputation for sharpness, but is an older design, focuses slowly because the whole lens barrel moves in and out as opposed to internally focusing like newer lenses, and its motor is kind of slow. It also had a reputation for hunting, and on the Sony sensor of the EM5 vintage, including the Pens, there is the potential for banding, some sort of interference. That has since been fixed with newer sensors and newer bodies with low light capable CDAF abilities.
The 20 on my GX7, with its -4EV focus ability, is now quite acceptable in its speed, though it can still be noisy. It rarely hunts anymore. The newer Oly cams have similar fast focus ability, and so banding and hunting should no longer be an issue, but it is still physically slower.
Just to be clear... which newer Oly. cams are you referring to, Chas2? I've only read that there is no banding with the new PEN-F. All existing OM-Ds are still susceptible to banding because of that Sony sensor you mentioned. As for faster focusing, I don't know about that. Thanks.
 Egregius V's gear list:Egregius V's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +17 more
EarthQuake Veteran Member • Posts: 3,240
Actually, the EM1 has a 16MP Panasonic sensor, so it should not show banding, though I have not personally tested this myself. There are also a lot of Pens that use the 16MP Sony sensor (too many to remember which models, all of the 16MP ones). The Pen F is the only Pen that doesn't use the either the Sony 16MP sensor or an older (I think Panasonic) 12MP sensor.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
I found the 14mm to be a very good lens
A great little lens ln both Lly and Penny bodies. Sharp, focused at warp speed in the mostu npromising light. A bit of flare from just outside the frame in certain situations. Never noticed the purple fringing that could appear around the edges when using it with Olympus cameras, which some others reported.
Never used the 20mm -- not my preferred FOV.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Chas2 Veteran Member • Posts: 3,715
As I understand from reading multiple threads on dpreview over the past few months, EM-10 forward for the OM-D range do not appear to have the banding issue for whatever reason.  The older PEN series, prior to the PEN-F seem to continue to use the sensor that bands...so that would mean up through and including the EPL7.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
The EM1 does not have banding with the P20mm.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Egregius V
Oh, right - I forgot about the E-M1 not having a Sony sensor. Thanks!
For further clarification: the E-M10 and E-M5 Mark II are susceptible to banding with the 20mm lens. I've demonstrated this for myself. I presume the E-M10 II can also show banding, since the sensor is the same. But again, it's pretty much avoidable - especially if you have the electronic (silent) shutter feature. Good thing, as I love the 20mm lens!
JoeVC Contributing Member • Posts: 703
So, perhaps one of you technical people can explain to us laypersons how a lens can cause banding in some sensors. Thanks.
~Joe
secretworld Senior Member • Posts: 1,734
~Joe
It is electrical interference from one of the lens components. This has been proven by someone by taking the lens apart and disconnecting either the focus motor or the motor for the aperture blades. I forgot which one caused the interference, but it cured it 100%. So there you go...
Btw the weaker UV filter on Olympus cameras has been proven too (By AnderW). It causes purple flare on the 7-14  and can cause some purple fringes with some lenses. The latter is easily cured in lightroom. And a normal (colourless) UV filter doesnt help at all. It needs to be a wratten 2A or 2E, which are both pale yellow.
I have experience with both subjects. I used a wratten 2A on my PM2 which fixed flare and fringes. And on occasion the 20mm did cause banding. Which I know now is fixable in post with the denoise pluging of the google NIK plugins. (Dfine I think).
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
