Whats up with Panasonic 14mm and 20mm on Olympus
Started Mar 5, 2016 | Discussions
NoTx Senior Member • Posts: 2,071
Hey all,
So I have noticed a lot of negative comments about the Panasonic 14mm a and 20mm lenses on Olympus bodies. So what is up with that, and do the mark 2 versions suffer the same issues?
Thanks all!
Rob aka NoTx...
-Always searching
 NoTx's gear list:NoTx's gear list
Panasonic Lumix DC-G9 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
Panasonic Lumix G 14mm F2.5 II ASPH
bahamot
bahamot Contributing Member • Posts: 670
Re: Whats up with Panasonic 14mm and 20mm on Olympus
Dunno what issue you refer to, but I used P20mm on EM5 just fine.
 bahamot's gear list:bahamot's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic GH5 Panasonic Lumix G 20mm F1.7 ASPH +7 more
OP NoTx Senior Member • Posts: 2,071
Well even today a post on severe hunting in low light. Other days perpole color shifts. Etc.
Rob aka NoTx...
-Always searching
Oleksak Regular Member • Posts: 131
Panasonic 14mm have been working well with EPL1, EPL5, EP5. Little CA. But LR helps to  remove them completely
 Oleksak's gear list:Oleksak's gear list
Olympus PEN E-PL1 Olympus PEN E-P5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +3 more
Mark 1 or mark 2?
Rob aka NoTx...
-Always searching
Alan WF
Alan WF Veteran Member • Posts: 3,818
Some people are bothered by chromatic aberration (with both) and banding (with the 20/1.7). Others are not.
In these respects, I don't think the Mark 1 and Mark 2 versions are different.
Alan
 Alan WF's gear list:Alan WF's gear list
Canon EOS M50 II Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM +21 more
bahamot
All lens will have difficulty focusing in low light,  it's not unique to P20mm. Colour shift? No such thing with my EM5. Banding? Don't find it in any of my shots with EM5.
MatLD Regular Member • Posts: 491
I don't own the 20mm f1.7. Banding at high ISO is a well documented issue with 20mm f1.7 on sony sensors (omd's and gh3). 20mm f1.7 is also not great at AF and my experience (gf3 and em-10) is that olympus AF is a little bit worse than panasonic's.
I haven't heard or had any issue with the 14mm. CA for both lenses might be a little bit higher due to a supposedly lower UV filter on olympus (sony ?) sensors. But I use a simple UV filter most of the time and treat bad CA in PP for both cameras. It might also be due to different in camera CA corrections.
I don't think the mark2 are much different: probably exactly the same for 14mm and maybe negligeable refinements on the 20mm (coatings ?). Sample variation is probably bigger thant the differences between an average Mk1 and Mk2.
bluevellet Veteran Member • Posts: 4,172
Here's the deal
The 14mm is a tiny, fast-focusing albeit optically average lens.
The 20mm is a good optical performer, but it has banding issues at high ISOs on some Olympus bodies and its noisy and slow to focus. C-AF is useless with it.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
108 Senior Member • Posts: 1,353
My copy of 14 mm is tack sharp across the frame on the Em10 , sometimes a bit soft in the bottom left corner, only when the cam is not horizontally level , good colours, good contrast , no low light hunting unless shooting black cat in a coal mine . I just find this little lens excellent for street shots at night . I keep it at f2.8  .
My copy of the 20 f1.7 is so sharp it hurts my eyes, ..no just kidding , gave me awesome results on the Epl2 , excellent on the Em5 , too sharp on the Em10 . AF is a bit slow, but since I shoot stills it doesn't bother me ( a tad faster on the G5 I must say ). AF , like the 14 mm, hunting in low light only if you focus on anything dark, no surprise . When used at 1600 iso on the Em5 , banding only occurs if I have underexposed and I want to ( badly )  lift the exposure in pp, say a full stop . So paying particular attention to get right exposure when shooting is important . i only wish this lens would be 17 mm instead of 20 .
 108's gear list:108's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus OM-D E-M10
ahaslett
ahaslett Forum Pro • Posts: 12,662
Re: Here's the deal
That's it!  If you an instinctive prefocusser with an EM1 and don't mind a bit of noise from the lens, a used P20mm is one hell of a lens for the money.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
TheEye
TheEye Veteran Member • Posts: 4,883
Separation anxiety and and inferiority complex?
7
There are no issues with those lenses. They could be problematic when used for subject matter and/or under conditions that are not these lenses' domain. The only issue I suspect is general anxiety.
EarthQuake Veteran Member • Posts: 3,240
NoTx wrote:
Hey all,
Thanks all!
The 20/1.7 focuses relatively slow in general, and can hunt a lot and fail to lock focus in low light. It also has issues with banding in low light at ISO 3200 and above on cameras with the 16MP Sony sensor, which is many of the Oly bodies from the last 4 years and the GH3.
The 14/2.5 doesn't have any Olympus specific lenses, it's just not a terribly exceptional lens other than its size and how cheap a used copy is. That's not to say it's not a good lens, it's just that if size and price are not absolute priorities I would go with either the 12/2 or 15/1.7 instead, or if versatility is desired, the 12-32/3.5-5.6 which delivers very similar image quality.
NoTx wrote:
Mark 1 or mark 2?
I meant Panasonic 14mm ,  have no idea regarding its version. 4 years old.
Egregius V
Egregius V Contributing Member • Posts: 538
One's mileage may vary. My 14mm/2.5 lens is quite sharp at open apertures and has given me great images indoors as well as outside. Some copies have centering/sharpness problems, though. My 20mm has also been excellent - but low light is a challenge because of the focusing mechanism and because of the possibility of banding on Olympus bodies. (Maybe no banding with the Pen-F, though, and definitely no banding with an Olympus which is using a fully electronic shutter.)
I've never had a significant problem with focusing using either lens on an E-M10 or E-M5 II, though I do think it's worth considering that these lenses will focus faster, if not better, on Panasonic bodies.
I bought the 20mm lens because I believed the comments that banding only occurs at ISOs above 1600. Not true, unfortunately. I found the banding to occur at all ISOs and at all apertures except f/1.7. But exposing well "to the right" on the histogram, blending exposures to preserve blown highlights, or using an electronic shutter avoids banding entirely with Olympus cameras.
Of course, no lens or camera is a jack-of-all-trades, so we must each decide what will meet our needs. I love that this forum can help a lot with that.
EDIT: It seems to me also that there is no non-cosmetic difference between the original and Mark 2 versions of these lenses. Any perceived or reported differences might simply be due to sample variation.
 Egregius V's gear list:Egregius V's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +17 more
baxters Veteran Member • Posts: 5,319
The 20mm is the slowest focusing of the M43 primes, just like the 78's were the slowest of the  Corvette C3's.  Doesn't mean it's an unwanted turtle. The 20mm will hunt in the dark unless you use touch focus to pick a high contrast point, where it will say "yes boss" and be there.
If you underexpose, getting a muddy murky mess, and try to save it in post process, by god you might get some banding along with the noise.
Still, it's the sharpest lens I own. And I will pick it over my Olympus 17mm at night,
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
jsaras Contributing Member • Posts: 610
My used copy of the Panasonic 14mm f2.5 (first edition) works quite well on my EPL6.  It's my least used focal length but that's not a reflection on the quality of the lens.
 jsaras's gear list:jsaras's gear list
Sony RX100 III Olympus PEN E-PL6 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +10 more
berni29 Veteran Member • Posts: 3,119
Hi
I Have used the 20mm Pana on the EM5, EM10, EM1 and EM10 mkII, and have found it great on all of them. I have seen banding, but only rarely, and even then only at high ISO 3200+. CA I have never noticed before.
It's been a great lens for me.
Berni29
EM1, EM-10mkII, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm f1.7, Voight 17.5mm f0.95, Oly 12-40mm, 45mm, 50mm F2 macro, (prev EM10, EM5, GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
Skeeterbytes Forum Pro • Posts: 23,186
Re: Here's the deal
Andrew
Pretty much. The 20 is one of the early m43 lenses and suffers in comparison to newer lenses WRT focusing and a noisy motor. The banding is annoying, given one reaches for a fast prime when shooting in low light, but luckily it seems limited to a few cameras.
Still a useful lens provided one approaches it fully aware of the limitations.
Rick
Chas2 Veteran Member • Posts: 3,715
Re: A case of overblown worries that no longer apply to newer cams...
NoTx wrote:
Hey all,
Thanks all!
Until a couple of years ago, the Oly jpg engines did not compensate for CA information passed from the Panasonic lenses.  The TruePic VII engines, EM-1 forward do this.  So for years, rightly so Panasonic lenses have been accused of more purple fringing on Olympus than Panny bodies.  This applies to the 14 and 20.
The 14 is sharp lens when you get a good copy, but I find mine just mediocre. But it focuses quickly and silently.
The 20 has a great reputation for sharpness, but is an older design, focuses slowly because the whole lens barrel moves in and out as opposed to internally focusing like newer lenses, and its motor is kind of slow.  It also had a reputation for hunting, and on the Sony sensor of the EM5 vintage, including the Pens, there is the potential for banding, some sort of interference.  That has since been fixed with newer sensors and newer bodies with low light capable CDAF abilities.
The 20 on my GX7, with its -4EV focus ability, is now quite acceptable in its speed, though it can still be noisy.  It rarely hunts anymore.  The newer Oly cams have similar fast focus ability, and so banding and hunting should no longer be an issue, but it is still physically slower.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
