used D300 or new D3300?
Started Mar 2, 2016 | Discussions
James Nagy New Member • Posts: 2
Hi Guys,
I need your advice.
Family trip is coming up to Grand Canyon, Zion, Bryce. I have a good old D100 and I guess it’s about time to upgrade it. I used to take lots of pictures always in RAW because the D100’s JPG was not very good. I was always happy with it.
A guy I selling his used D300 body + battery grip for $300 on craigslist , he said that the camera is in good condition with 50k actuations.
A brand new D3300 body is selling on Amazon for the same price.
I’d use it for mostly for landscape and family photography.
D3300 is a bit lighter –better for hiking- and brand new with warranty. But I'm leaning towards the D300.
What would you guys do?
I don’t want to spend more than $300.
I’m going to use my existing Nikkor lenses 50mm 1.4D, 18-35mm (3.5-4.5D), 70-300 (4-5.6D)
Thanks,
James
Leica SL 50mm F1.4 Nikon D100 Nikon D300 Nikon D3300 Sigma 18-35mm F1.8 DC HSM Art
Isaac Fulford
Isaac Fulford Junior Member • Posts: 36
Re: used D300 or new D3300?
Simple, if you want features such as : weather sealing, higher frames per second, and a 100% viewfinder, go for the D300. If the absolute need is small size and image quality get the D3300. Although Af-d lenses won't autofocus on the 3300 ( or anything less than a D7x00 series body).
 Isaac Fulford's gear list:Isaac Fulford's gear list
Nikon D5500 Nikon D7200 Nikon D7500 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +6 more
David Lal Forum Pro • Posts: 13,568
I am biased ....
I have a D300 and would not want anything else. Here is a recent post about the D3300:
http://www.dpreview.com/forums/post/57372559
Robert Cohen
Robert Cohen Veteran Member • Posts: 4,582
As I understand it, the D3300 would not autofocus with D lenses, ones that use the "screwdriver" connection between the lens and an autofocus motor in the body. So you couldn't use your lenses in autofocus mode.  (You could of course manually focus, but I suspect you'd rather not do that with all your present lenses.)  And since the D300 is more similar to the D100 you're used to, that's another reason to go with the D300, old as it is.
I keep using my D300.  The photos I take with it are no less good than when the camera was new. <g>
--Bob
 Robert Cohen's gear list:Robert Cohen's gear list
Nikon D300 Nikon D700 Nikon D500 Nikon D850 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +6 more
OP James Nagy New Member • Posts: 2
Thank you all for your quick response.
I didn’t realize that my lenses were not compatible with the D3300..
I don’t have a choice after all.
Thanks,
James
pda4you Senior Member • Posts: 1,617
Thanks,
James
Nikon just had the D7100 refurbs for $499.  They will focus your lenses and are very capable with higher IQ than the D300.
So there are other choices!
 pda4you's gear list:pda4you's gear list
Nikon 1 V2 Nikon D7100 Sigma 70-200mm F2.8 EX DG OS HSM Sigma 17-50mm F2.8 EX DC OS HSM Nikon 1 Nikkor VR 70-300mm f/4.5-5.6
Chuck Yadmark
Chuck Yadmark Veteran Member • Posts: 5,127
Yeah, I agree with 7100.    I know OP said 300 dollars limit, but the 7100 I truly believe is one of those "last cameras you'll ever need" deals.  I've seen them for 400 used also.
www.sportsshooter.com/cyadmark
Ann Arbor, MI USA
Equipment in profile
 Chuck Yadmark's gear list:Chuck Yadmark's gear list
Nikon D4S Nikon D500 Nikon Z6 Nikon Z50 Sony E 10-18mm F4 OSS +24 more
n057 Veteran Member • Posts: 8,769
James Nagy wrote:
Hi Guys,
I need your advice.
Thanks,
James
I would still go for the D300.
There is a reason I kept my D200 for all that time, resisting the lure of all the cameras that came before the D500, even though less expensive ones came along with more resolution.
JC
Some cameras, some lenses, some computers
 n057's gear list:n057's gear list
Nikon Coolpix 995 Nikon D200 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G +7 more
Drevis Neloren Regular Member • Posts: 266
Just took delivery of a used D300 in great condition from Adorama for $189 the other day. Shutter count is about 20k. Feels great to have a D300 in my hands again, this thing is a beast.
Confound it all. I was quite sure I was invisible, or at least transparent.
 Drevis Neloren's gear list:Drevis Neloren's gear list
Nikon D200 Nikon D300 Canon EOS Rebel SL1
Suntan Veteran Member • Posts: 6,011
The D3300 doesn't have an in body focus motor. So you will lose AF with all of your screwdriver lenses with that camera.
The D300 has a strong AF motor that works well.
 Suntan's gear list:Suntan's gear list
Panasonic LX100 Nikon D300 Nikon D750
puttin
puttin Veteran Member • Posts: 7,958
That's a good price. I got lucky a couple weeks back and got 1 for $218 but it only had 597 clicks on it fro KEH.
 puttin's gear list:puttin's gear list
Nikon Coolpix A Canon G9 X II Nikon D3 Sony Alpha NEX-7 Sony a7 II +25 more
Finding one with under 1,000 actuations on it is amazing luck. I have bought a few used D300's in the past and have never seen one with a low shutter count like that. I believe after a certain number of shots the count rolls over back to 0 and starts over but I'm not 100% sure.
These things are amazing deals now, if you're patient you can grab one for under $200 or not much more. Another one was just on Amazon via Adorama for $179. For what you get it's an absolute steal. If you don't mind getting a camera that's a little dated you can do a lot worse then a D300 for around $200.
puttin
Never heard of that, you might be thinking of the memory card files. I checked it with both photome and nikonshuttercount, both said 597. The camera did not have any marks of use on it so I believe the count. Some people buy stuff and never use it.
John Szeto Senior Member • Posts: 1,921
I still love my D300
puttin
That's a good reason
photoreddi Veteran Member • Posts: 7,973
Shutter actuations vs file numbers
Only the number used to create the photo's filename (JPEG or NEF or whatever) eventually resets to "0001". The number of shutter actuations is saved in the EXIF data. Many forum members have reported actuation counts in the hundreds of thousands. One or more D3/D3s owners have claimed to reach over 600,000 actuations before needing to have their cameras serviced. When shutters are replaced, Nikon resets the actuation count.
If you know what you're doing, you can change the file number and folder number that your DSLR uses/creates for the next photo that it shoots to any 'allowed' number, from 1 to 9999 for the photo file number, for example. But only Nikon's technicians can reset the shutter count (actuations), not camera owners.
PoorTwistedMe New Member • Posts: 3
I have both and grab the 3300 when I need better high ISO performance. For daytime shots, adequate lighting, the 300 is great!!
lmpmd Veteran Member • Posts: 3,085
It's great to have a choice. I have a D300 and a bargain used D3200.  I find myself often reaching for the D3200 for travel now. It's so light with a 35mm prime or 18-55mm lens on it.
Larry
greenmanphoto Veteran Member • Posts: 3,250
Thanks,
James
James,
Just to clarify something here. You're older lenses ARE compatible with a D3300, except for autofocus and possibly a couple of other, more advanced modes. The lenses will still mount, manually focus, and take great photos (assuming they're good lenses in the first place). The biggest, most obvious thing they lack is the ability to autofocus with anything under a D7x00-series camera. And there are a few other issues, things like Matrix Metering (IIRC), and similar technologies that weren't around when those lenses were designed.
That's one of the beauties of the Nikon system, IMHO: the ability to use lenses from as far back as the F-mount has existed, with VERY few exceptions. You won't necessarily have the full, modern functions of the camera with such older lenses, but they WILL mount and work.
Sam
Sam B.
D200, 16-85mm, 35-135mm, Sigma 10-20 f3.5 N8008s, Gitzo 2531, Induro DM-01 ballhead
Certified Texas Master Naturalist
Proud WSSA Member #260!
www.flickr.com/photos/sibeardjr
www.doormouse-editions.com
 greenmanphoto's gear list:greenmanphoto's gear list
Nikon D300 Nikon D700 Nikon D500 Nikon D850 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +14 more
puttin,
597 clicks?! Are you SURE that's all?! I don't mean to question, but that sounds ridiculously low! It's barely getting broken in, at that point! And I thought *I* had done well when I bought my D700 with around 4k clicks on it!
Sam
Sam B.
