Ricoh GR aperture blades won't open at start up
Started Mar 2, 2016 | Discussions
Valentino 67
Valentino 67 Junior Member • Posts: 49
My Ricoh GR and my friend's Ricoh GR have the same problem: when the camera is turn on, the lens extend normally, the cover lens opens, but the aperture blades don't open.
Only after pressing the shutter button and taking a photo in black (with the aperture blades closed) the camera will work normally (the blades will open). This happens any time the camera is turn on.
Did you have this problem? One Ricoh is one year old, the other one two years old... Thanks.
 Valentino 67's gear list:Valentino 67's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Ricoh GR III
rondom Veteran Member • Posts: 3,520
Re: Ricoh GR aperture blades won't open at start up
my GR had exactly the same problem after a year of use, and the workaround you described above didn't last for a long time and in few days the camera died altogether. They had to change the lens unit.
Limburger
Limburger Veteran Member • Posts: 7,841
Some help might be posting the SN so people new to the GR can skip this batch.
Similar happened with the Fuji X100 (blades wouldn't close during exposure).
Cheers Mike
Register and vote.
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
Valentino 67
OP Valentino 67 Junior Member • Posts: 49
Thank you, it looks like this is the fix.
sevresbabylone Regular Member • Posts: 142
The same thing happened to mine Saturday night. Sad to read that it's going to get worse (i.e. the one shot to open the blades won't last for long.)
For what it's worth my shutter count is 14229.
 sevresbabylone's gear list:sevresbabylone's gear list
Sony a7S II
Well, maybe not all get worse...good luck.
Valentino 67
Update: cost of repair more than the cost of a new GR
It will take $840 CAD to replace the whole optical part, more than the cost of a new GR! My GR still works but I don't know for how long... It looks like Ricoh GR has a short life span, no more than 2 years...
Re: Update: cost of repair more than the cost of a new GR
This doesn't sound right...which service center is that? Not long ago, I received a quotation for the same item from the official German service center. I think it was around 250 euros.
it's ridiculous and ricoh should know that
i just checked: 280 euros plus shipping (total lens unit replacement)
so the price you got is ridiculous and ricoh should know that. Out of warranty cost needs to be reasonable...this isn't.
My good luck ran out.  I hadn't used it much since the blades not opening problem started, but thought I would give it a go, and set it on the manual so the initial blank shot wouldn't take so long.  But it's died completely.  Lens extended, then camera shut itself down.  Restarting briefly gets me the black screen with the info (shutter speed, type of focus, etc) displaying, but it dies in a second or so.
Sony a7S II
gr sticky shutters
this is exactly what i experienced. sorry to hear about it. if you send it to service center they will replace the lens unit for you. probably will cost you slightly less than a used GR (which may eventually develop the same or other problems) so it may be worth repairing as the camera will get a new life after it.
This is a very serious but less covered GR problem ( compared to all the dust threads).
Harold66
Harold66 Forum Pro • Posts: 12,002
Re: gr sticky shutters
Yes indeed, this is much worse.do you know what was your shutter count when it died ?
FOLLOW me on IG @haroldglitphotography. one NEW picture EVERY day !
thedemandingtraveler.org
www.haroldglit.com
www.modelmayhem.com/haroldglit
IG :haroldglitphotography
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
Around 15K
About 14200
Sony a7S II
Harold66
Thank you to both of you for sharing that info
i will keep my fingers crossed for both my GR  and Gr2 which are both significantly over this threshold
H
www.haroldglit.com
brintam
brintam New Member • Posts: 8
I am unfortunately also now experiencing the closed shutter problem.   And have had dust on the sensor for 1+ years.  FYI I have taken 14757 exposures so there seems to be a pattern?
Pondering in what direction I should go... I have just taken out my GRD3 from the drawer.
 brintam's gear list:brintam's gear list
Ricoh GR Nikon D800 Fujifilm X-E2 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 50mm F1.8G +2 more
While mulling what to do about mine, I bought a used Fuji X100t, a camera I'd been interested in some time.  But after using it for a few months, I've bought a used GR II (waiting for it to arrive.)  Surprisingly, because I don't consider myself to be a wide shooter, I missed the 28mm.  More than that, I missed snap focus.  I was missing shots while adjusting the autofocus point, or fidgeting with the Fuji's manual focusing.  In fairness, I'd been using Ricohs since the GRD2, so I'm so much more familiar with the camera.  Also, I prefer the size and handling of the Ricoh.  I will say that I liked the Fuji's colour rendition, and especially liked the fact that in Adobe Camera Raw, one can switch between the Fuji's different film simulations.  I shoot a lot of bands in bars and clubs with lowlight and super-saturated LED lighting, and the Fuji is the best of cameras that I used for taming that lighting (compared to M9, Olympus E-M5, and the GRD and GR cameras.).
Sony a7S II
Harold66
That sucks . I guess I have been lucky.. so far. My GR has now 26,000+ shutter count and the GRII 23,000+
did you guys notice any warning signs before the problem appeared ?
H
www.haroldglit.com
H
Yes, there was a warning sign: the blades would fail to open at start up, but turning off and on the camera would work. Then it would get gradually worse, and finally fail for good.
that's probably why I am now concerned with the unresponsive buttons (see my new thread) for all I know it will remain manageable and not get worse, but who knows...
No warning signs before the sticky blades.  One night I was taking pictures of a band, and the problem started -- the first shot would be "blank" and then after that it would be fine until I shut off the camera. Then the problem would repeat.  (Indeed, at first I thought it was a playback problem, but found out it wasn't when I uploaded the files to my computer.  I began to use the camera much less frequently, but started to try to accommodate myself to it.  I would take a shot while raising the camera from my waist pouch, for instance, so that it would be ready.  Because I was usually on auto, and it was taking a long time for the camera to get the "correct" exposure because of he closed aperture blades, I started shooting manual.  I didn't use the camera for a few weeks, missed using it, and thought I would start again; that is when the lens wouldn't retract, and I gave up.
I don't know if you are lucky, or if some of us are unlucky.  Don't know if numbers tell the story, or if there are other variables.
Sony a7S II
