Canon 750d - this function is not available in moving shooting mode
Started Mar 1, 2016 | Discussions
thedozyone New Member • Posts: 5
Hi I've had a 450D for a few years and I fancied an upgrade to one that also did video.
I purchased a second hand Canon 750d and I'm having a few issues.
I get "this function is not available in moving shooting mode" I've tried lots of settings and also defaulted the camera but can't get it to record video. Also I've tried a few different lenses and different memory card (I'm using a Lexar Pro 64GB Class 10 - UHS-II)
Also it has a constant message on the screen "this function is not selectable in the current shooting mode".
I wonder if someone can point me in the right direction
Mark
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2)
Glick1 Regular Member • Posts: 277
Re: Canon 750d - this function is not available in moving shooting mode
Mark
In what mode are you trying to shoot video?
 Glick1's gear list:Glick1's gear list
Canon PowerShot S100 Canon PowerShot ELPH 330 HS Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
I think it says 'movie shooting mode"
The 750D has a lot of features, but it's still a "Rebel" with very simplified options and less capability than the x0D and higher.
With the sole exception of M mode, movie shooting with the 750D is always full auto. You cannot select the shutter speed, aperture, or ISO - note on p. 223: "In Basic modes the shooting result will be the same as in [A+] ... In Av and Tv shooting modes, movies will be taken with the same settings as in the P mode."
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Exit10 Senior Member • Posts: 2,264
Mark
Maybe one of the buttons on top or side of the camera is stuck - like depth of field preview or ISO or Display or AF Area Selection - try pressing each one in turn and see if they seem to move OK.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
OP thedozyone New Member • Posts: 5
Glick1 wrote:
Mark
Hi sorry I've only just seen this.
I have tried in auto and P modes. I just can't seem to get it to work.
I took it into a camera shop and they said it was probably faulty which doesn't bode well as I purchased it second hand
FrankieJ
FrankieJ Senior Member • Posts: 1,685
Mark
What happens when you move the power switch to the video symbol and then try to shoot video?
Mark
I just get that message on the screen, its ok though I ended up sending it back to Canon. I had to suck up the repair cost but hopefully it should be back tomorrow.
Thanks for the reply
FrankieJ
Mark
That's good about you getting it back swiftly I hope all is good.
karl mohr Senior Member • Posts: 1,678
This is kind of a shot in the dark, but by any chance was the wi-fi enabled / disabled?  I was noticing on my 70D that video mode is not available when the camera has wi-fi enabled.  Or maybe a stuck button or switch somewhere?
 karl mohr's gear list:karl mohr's gear list
Canon 6D Mark II Canon EOS 60D Canon EOS 80D Canon EF 17-40mm f/4.0L USM Canon EF-S 55-250mm f/4-5.6 IS +3 more
I would bet it was a stuck button - probably dirt - but too late now - I doubt Canon will give details of what was wrong
RedFox88 Forum Pro • Posts: 30,738
I have a relative that was unable to record video with a lexar video card and some cards labeled class 10 can't record full HD video on rebels. PNY professional cards work.
I think the SD card is your problem not the camera
Mark
Mark
Hi thanks for all the comments, it turns out the camera was at fault. They replaced the flash unit and also as far as I can tell have reloaded the firmware.
I had a little play last night and it seems perfect
Looking forward to shooting some pics and videos at Goodwood this weekend
Mark
Not sure how the camera flash would affect video recording.
Your explanation of what was wrong was extremely vague.
Mark
It wasn't just the video that didn't work. The basic functions weren't working correctly.
This is all I got from the repair but the error messages have all gone so I would guess that the firmware was corrupt. The Flash kept getting err 05 too which they have replaced.
Labour . . . : Replaced faulty/damaged external parts.
Adjusted internal flash system
Replaced internal flash system
Product checked against any reported fault
Fixed Price Repair Function check
Spare parts . :
COVER ASS'Y, FRONT
COVER ASS'Y, TOP
The memory card works fine
