EF vs EF-S
Started Mar 1, 2016 | Questions
MasonHoy New Member • Posts: 21
EF vs EF-S
I have always been taught to account for crop factor on a crop sensor when using a lens not designed specifically for the crop.
I've never questioned this until I tested the 50mm EF 1.8 vs the 55mm-250mm EF-S on my 700D, and the images (although with a difference of 5mm focal length) were roughly the same FOV. That would suggest that the 50mm focal length is true even on an APS-C sensor.
Can anyone provide insight here?
 MasonHoy's gear list:MasonHoy's gear list
Fujifilm X-E1 Fujifilm X-T1 Samyang 85mm F1.4 Aspherical IF Fujifilm XF 35mm F1.4 R Samyang 8mm F2.8 UMC Fisheye +2 more
Canon EF 50mm F1.8 STM Canon EF-S 55-250mm f/4-5.6 IS Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
Richard Butler
Richard Butler dpreview Admin • Posts: 2,911
Re: EF vs EF-S
The crop factor is always present, regardless of what format the lens was designed for. Essentially all lenses list their actual focal length on them. The crop factor tells you which lens would give the same field-of-view on a 135 format ('full frame') camera.
So the 50mm on your camera will give the same field-of-view as an 80mm lens would on full frame.
Richard - dpreview.com
msowsun
msowsun Contributing Member • Posts: 740
Re: EF vs EF-S
Lens focal lengths are rarely exactly what they claim to be. The 50mm may be 53mm rounded down to 50mm and the 55mm may be 53mm rounded up to 55mm.
Focal length also changes with focus distance.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
AlephNull Veteran Member • Posts: 4,690
Re: EF vs EF-S
Both EF and EF-S lenses show their focal length in terms of full-frame 35mm, not "effective" or "crop factor" terms.
 AlephNull's gear list:AlephNull's gear list
Sony a7R IV Sony a1 Sony a7R V Sony FE 85mm F1.4 GM Sony FE 85mm F1.8 +6 more
photonius Veteran Member • Posts: 6,895
Re: EF vs EF-S
not quite. Focal length is a property of the lens. It has nothing to do with the sensor. 50mm simply means an infinity light source will focus at 50mm behind the lens (simplistically speaking - but think magnifying lens, trying to light a piece of paper).  Anyway, the sensor size behind the lens then dictates the field of view/angle of view that you get. For historical reasons, the 35mm FF format is taken to compare field of view/angle of view.   Having said that, lenses are of course designed to cover a certain image circle. The EF-S lenses are designed to cover only APSC, EF cover FF, the TS lenses have an even larger image circle, so probably could be used on medium format (that's why they are TS, so the image circle can be shifted off the optical axis and still cover the sensor).
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
diness Veteran Member • Posts: 3,758
Re: EF vs EF-S
As others have said... all lens markings are the same.  50mm is the same if it's EF or EF-S.  So, you are right on there.  EF-S lenses are desgined for crop sensors, so they will not project light on the entire full frame sensor, but the focal lengths are all the same as EF lenses.
What you need to be aware of is that the focal lengths will mean different things for crop sensors and full frame sensors.  This becomes important as you read reviews and think about purchasing lenses and whatnot.
For example, you may read about people suggesting a 24-70mm lens as a great standard zoom.  Most of the time people suggesting this are doing it for Full frame users where 24mm is wideangle and 70mm is just past standard:  a very nice general photography range.  For crop users however, this lens would not be very wide at the wide end and would be slightly into the telephoto range on the long end.  A very different view through a crop sensor camera in other words.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
OP MasonHoy New Member • Posts: 21
Re: EF vs EF-S
Thanks all!
