Lens for Landscape and Night Photography
Started Mar 1, 2016 | Questions
unefemme
unefemme Forum Member • Posts: 67
Hello All,
I am currently looking to upgrade my lens Canon EF-S 10-22mm f/3.5-4.5 USM to either:
- Canon EF 24-70mm f/2.8L II USM
- Canon EF 16-35mm f/2.8L II USM
- Canon EF 17-40mm f/4.0L USM
Will be using this lens for Landscape and Night Photography, well basically anytime I go out of town, I shall carry this lens. Currently I try to learn more into Night Photography.
I did try those three lenses and must say, am getting really confused as am happy with all the results. Therefore I would appreciate your advices.
Oh by the way, that EF-S 10-22 was sold last week as I need to add my budget for this upgrade.
Thank you and awaiting feedback.
 unefemme's gear list:unefemme's gear list
Canon EOS-1D X Mark II Canon EOS 5D Mark IV Canon EOS R6 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +4 more
Canon EF 16-35mm F2.8L II USM Canon EF 17-40mm f/4.0L USM Canon EF 24-70mm F2.8L II USM
TyphoonTW
TyphoonTW Senior Member • Posts: 1,484
Re: Lens for Landscape and Night Photography
Full frame or APS-C ? You had the 10-22 so I assume APS-C, in that case Tokina 11-16mm f2.8.
For full frame, Tamron 15-30 f2.8.
The 24-70 mkII is the best lens of the lot that you trued, but it's not exactly a common choice for astrophotography. It's also not very wide on APS-C.
Canon 16-35 f2.8 is way overpriced for what it offers, if you need f2.8 then go with Tamron.
Samyang / Rokinon 14mm f2.8 performs amazingly well for nightsky photography and will leave a lot of cash in your wallet, but you may need an extra UWA zoom for convenience. You'll notice on the Flickr group for the Samyang lens that a lot of those images are about night skies.
So, if I had to sum up my reccomendations list:
a) APS-C -> Tokina 11-16mm
b) Full frame, 1 single lens -> Tamron 15-30mm f2.8
c) Full frame, 2 lenses, good value -> Samyang / Rokinon 14mm f2.8 + Canon 17-40mm
The reason why I consider option C as good value is that the 17-40 is a very old lens and it's very easy to find second hand at really low prices. The newer 16-35 f4 is much better optically, but the price is also much higher and you mentioned that you already liked the results from the 17-40. You can use filters on the 17-40 (as well as the 16-35 f4), which is often helpful for landscapes. The Tamron and Samyang lenses don't take filters.
This is where I write stuff: http://randomibis.wordpress.com/
This is where I upload stuff: http://www.flickr.com/photos/107755637@N06/
Canon 6d + 50mm f1.8 STM + 85mm f1.8 + Samyang 14mm F2.8 + 100mm f2.8 Macro
Canon SX 50
 TyphoonTW's gear list:TyphoonTW's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +2 more
ajay0612
ajay0612 Senior Member • Posts: 2,829
unefemme wrote:
Hello All,
It depends on whether you prefer more reach rather than getting a bit wider. If wider than save money and buy 17-40mm f4.0 as for landscapes DOF is a requirement so narrow aperture won't feel like a limitation. 24-70mm is a usual walk around lens giving you an option of shooting some portraits also owing to its reach and wider aperture.
 ajay0612's gear list:ajay0612's gear list
Canon PowerShot TX1 Sony Cyber-shot DSC-R1 Canon EOS 500D Canon EOS 6D Canon EF 135mm F2.8 SF +2 more
Krusty79 Veteran Member • Posts: 3,415
What didn't you like about the 10-22?
https://www.flickr.com/photos/greg79
"You can't be young forever, but you can always be immature" - Larry Andersen
 Krusty79's gear list:Krusty79's gear list
Panasonic Lumix DMC-GM5 Sony a7R IIIA Rokinon 7.5mm F3.5 UMC Fisheye CS Canon EF-S 10-18mm F4.5–5.6 IS STM Sony FE 200-600 F5.6-6.3
unefemme
OP unefemme Forum Member • Posts: 67
Hello,
The 10-22 EF-S does not fit with my 5D.
unefemme
Hello,
I do own both FF and APS-C however I would like to pair the new lens with my FF camera.
Yes Samyang 14mm f2.8 is already in my bag Although up to now I do not have a good chance yet to test it due to ugly weather in our place (grey, foggy, etc..)
Looks like I have to rent the Tamron 15-30mm as you suggested to see if this will go with my need.
Many thanks once again for your feedback.
Canon SX 50
unefemme
Yeah that is indeed true.
I rented the 24-70mm last time and took a picture of a landmark building, which is located across the river. I did shot with 41mm which in this case, the wide angle lens would not be sufficient.
TyphoonTW
No problem!
My Samyang has the same problems as yours: waiting for the end of the rain season!
Canon SX 50
CameraCarl Veteran Member • Posts: 9,204
For night sky photography most experts recommend f2.8 or faster lenses.
unefemme
Yes I do have Samyang 14mm f2.8, however my mistake that I did not further explain earlier. What I am searching for is a lens that enable me to shot the city with lightings.
Many thanks
oscarvdvelde Senior Member • Posts: 1,420
Many thanks
Do you use a tripod or do you shoot hand-held? For tripod+city any lens would do as you will stop down anyway. In such case a lens should be judged by resistance to flare (matters more at night than during the day) and the quality of the star effect as you stop down.
For hand-held shooting a F1.4 lens can give you 4x shorter exposures or 4x more light, compared to f/2.8. Or you may like IS instead.
As you have the 14mm Samyang are you looking for something less wide?
Edit: do you mean lightning? Then you would need a less wide lens and not one with a bulbous front element which catches rain drops. The wider you would shoot the more upward tilted and the more chance of rain. Probably 28mm or 35mm/40mm are better for this use  (I used EF 28mm f/2.8 and 50mm f/1.8 for this, with lens hoods).
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
sssanti Contributing Member • Posts: 727
You may want to look at the Canon 16-35mm f/4L IS. The IS is very useful if you don't use a tripod and want as much DOF as possible. With tripod, the difference between f4 and f2.8 is not that relevant. If you don't mind the price difference, the 16-35mm f/4L IS is better than the 17-40.
unefemme
oscarvdvelde wrote:
Many thanks
Hi, I do use a tripod.
That is the thing, I try to make a backup so basically f1.4mm lens will go with one camera and the zoom one will be with another one. At home I can always compare and decide which one I like more. (I know.. I make things complicated LOL)
No, I mean the lighting. Like this one below, how I love the effect coming out from the lights. This was taken with 24-70mm f2-8
Am wondering if 17-40 and 16-35 give out the same quality? (Perhaps a silly question, but I just start to learn Night Photography)
