I bent my lens mount ring
Started Feb 29, 2016 | Discussions
mepaca Regular Member • Posts: 229
I dropped my k-3 with a lens on. The lens is fine but the lens mount ring on the camera is bent. At least one screw hole on the chassis is stripped. Apparently Precision charges $306 for k-3 repair. I don't know if that includes parts or not. I don't know if it's worth sinking that much into my well worn k-3 when I can get a new one for $629. What should I do?
Pentax K-3
ozdean
ozdean Forum Pro • Posts: 26,788
Re: I bent my lens mount ring
If it's well worn shout yourself a new one.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-50 Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM +14 more
OP mepaca Regular Member • Posts: 229
Good answer Dean. I've heard nightmare stories about Precision. Do you think that the $306 would include the price of the part. They require payment before it is even sent in.
MightyMike Forum Pro • Posts: 40,977
Just in time to upgrade to a K-1... I have to replace my mount ring and was given a new mount ring by someone i know who has done camera repairs for quite some time... mine has the finished scraped off due to trying to remove a ricoh pinned lens the wrong way... i may consider sending you my not so nice looking mount ring for a price but i can't help you with stripped screws
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Ulkesh
Ulkesh Veteran Member • Posts: 3,149
Retire it and buy a new one. You think it's just the lens mount ring, and then a circuit board will break after it comes back from the lens mount replacement, and that will cost, and then something else will turn out to be wrong, and it will never end.
Joseph Tainter Forum Pro • Posts: 11,432
Step 1: Buy a new K-3.
Step 2: Buy a cheap used Pentax DSLR, take the mount ring off it, and put it on your old K-3. Keep that camera as a back-up or sell it.
Joe
kriztian Senior Member • Posts: 1,344
It´s a sign from God that you should purchase a new Pentax K1:)
kriztian
GPGeneralPhoto
GPGeneralPhoto Senior Member • Posts: 2,156
You can buy a broken Pentax camera on ebay for cheap to get the ring. Krazy glue can be used for the stripped screw. JIS screw drivers are available on ebay as well, if you don't have any. If it were me, I'd fix it myself.
I'm thankful to still be able to...
 GPGeneralPhoto's gear list:GPGeneralPhoto's gear list
Canon PowerShot SD400 Pentax K-01 Pentax K-5 IIs
Michael 2012
Michael 2012 Regular Member • Posts: 259
Read this thread from 5 months ago, it should help you sort this out
K3II lens mount bent! Viagra won't help this one
You could also contact Shutterbobby  directly for advice on his fix.
Michael.
 Michael 2012's gear list:Michael 2012's gear list
Pentax K-30 Sigma 50-200mm F4-5.6 DC OS HSM Sigma 120-400mm F4.5-5.6 DG OS HSM HD Pentax DA 55-300mm F4.0-5.8 ED WR
Petroglyph
Petroglyph Veteran Member • Posts: 6,096
Step 1 1/2: Buy set of JIS screw driver.
Joe
 Petroglyph's gear list:Petroglyph's gear list
Sony a7R II Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Samyang 20mm F1.8
DAVID MANZE Veteran Member • Posts: 6,382
How about the Adaptist mount we posted about the other day, then you woud have the ability to mount Nikon lenses, Olympus, Konica etc........
http://adaptist.weebly.com/
TBQH, there's no way I'd give up on a K3 to good a camera!
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 28mm f/2.8D +17 more
KentG Veteran Member • Posts: 4,721
Better still, buy a new Pentax and sell the old one for parts.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 IIs Pentax K-3 II Pentax K-1 Pentax smc DA 16-45mm F4 ED AL Pentax smc D-FA 50mm F2.8 Macro +6 more
Petroglyph
Kent Gittings
Keep the mount ring for himself - never know.
Nicols Contributing Member • Posts: 865
Same happened to me time ago with my old K10D. But screw-holes were still ok in my case.
If you don't want to spend money, you can do as I did: unscrew the ring (take care of springs below), blend it back into a perfect plane shape (a wrench with some leather protection is very useful for this), and screw it onto the camera again.
Some epoxy glue may help to fix screw in defective screw holes.
And afterwards try out if the alignment of the lenses is ok. Make shots with open diafragma to the horizon and far away vertical stuff, and see if there are differences in focus between left and right, and upper and lower border.
But any case, a new camera is always a worthwhile experience
Best regards
Klaus
 Nicols's gear list:Nicols's gear list
Pentax K10D Pentax K-5 Pentax K-3 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA* 300mm F4.0 ED (IF) SDM +16 more
