[DIY] EF-NX AF Adapter - EF Lens Control Test
Started Feb 29, 2016 | Discussions
ihkim Regular Member • Posts: 451
19
Over last weekend, I started working on EF-NX AF adapter. I am not sure if I can do this and how long it will take to complete.
Anyway, I began to research EF mount and its protocol.
I found a web site which contains good enough EF mount protocol info. to start.
https://pickandplace.wordpress.com/2011/10/05/canon-ef-s-protocol-and-electronic-follow-focus/
The basic pin-out as below.
You can see detail info about the pins in the above link.
Motor power is 6V, and Logic power is 5.5V. Logic communication uses SPI protocol. Camera body is a master and lens is a slave.
In order to try to control a EF lens, I needed to reverse-engineer to get mount/pins dimensions.
Below screen shot is from my CAD screen after getting initial dimensions.
For controlling a EF lens, I used Arduino to understand the protocol. I 3D-printed for contacts holder and made contact extension cable for the test.
I took video clip for a EF lens control. It shows moving focus from MIN to MAX position and back and forth the focus position with rotary encoder.
https://www.youtube.com/watch?v=7fM5RKraDdA
 ihkim's gear list:ihkim's gear list
Samsung NX10 Canon EOS 550D Samsung NX100 Samsung NX20 Samsung NX300 +5 more
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: [DIY] EF-NX AF Adapter - EF Lens Control Test
great to see that you "accepted my challenge":
http://www.dpreview.com/forums/post/57301534
Please keep us posted. You are great, btw.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
ocphotodad Regular Member • Posts: 116
Just a thought, Kickstarter?
I would be one of the first supporters if the price was reasonable.
 ocphotodad's gear list:ocphotodad's gear list
Sony RX10 III Nikon 1 S1 Sony a7R III Sony a7 IV Samsung NX 30mm F2 Pancake +9 more
OP ihkim Regular Member • Posts: 451
5
I just merely saw a rabbit in a hole, but I have no idea how the hole is deep and long. I am going down, but not sure I can catch the rabbit or am stuck in the middle of hole with bare hands.
We will see.
ILHYOUNG.
I haven't done it before, and I guess it is too early to tell about it.
ILHYOUNG.
I looked at doing this once I realized that both use spi (unlike Nikon) and that voltages are not exotic. I tried reading your excellent site with Google translate but... Then I realized that I actually don't have any decent canon glass and that I'm more of a software guy anyway
I think even enabling ois and aperture control (which I think could even work independently of camera) would be great - AF of any kind would be fantastic for people looking for long lenses (and ultra wide ones).
TLDR Great work, best of luck!
Kisaha Senior Member • Posts: 2,300
Actually, the success of this, and the progress of Otto's(your) project, will add a lot of value to the NX system. Everyone has their new APS-C cameras out, and none has 28megapixels BSI, if we can add a couple of features (already the NX500 had 120/1080p!) and have an active EF adapter, the NX system will stay definitely at the top for the next few years. Actually the NX500 seems like the best buy ever, if we can activate non crop 4K.
Congrats, gentlemen, you are putting your knowledge in very good use.
Thank you for your kind comments.
I am a SW guy, too. I learned CAD and EE by myself. So, almost everything is new to me.
As you mentioned, Canon EF mount SPI uses 5 or 5.5V and NX uses 3.3V. I need to convert this 2 voltages when it talks to EF lens.
I found below product to do its work.
https://www.sparkfun.com/products/12009
We will see how that will work.
BTW, your findings for NX500 shell script are amazing!!! Please keep up!!
ILHYOUNG.
TillmanB
TillmanB Contributing Member • Posts: 501
I am very interested to see the result of this, I see these sort of adapters for the Sony Nex mount all the time, and have thought many times that it would really great if this was available for NX but I lack the necessary skills to even really know where to start!  Something that controlled the Canon lens as though it was mounted on a Canon body would be ideal, but I would be really satisfied with aperture control and OIS myself.
noflashplease Senior Member • Posts: 2,497
Unless Samsung restarts development and production, wouldn't you be better off devising a NX adapter for extant lens mounts?  An NX-E mount AF adapter would be an obvious choice.  In the coming year, it will become clear if Canon will produce a full frame mirrorless body, and whether there's a future for the EF-M mount, or if Canon goes with new mirrorless mount or just the EF mount?
If Samsung has truly ended production, that means that there will be clearances on NX-mount lenses.  Moreover, lenses typically outlast camera bodies, although modern internal AF motor lenses aren't as robust as the MF lenses of yesteryear, let alone the early screw drive AF lenses.  In any case, there will be lots of orphaned NX lenses and ever fewer operable NX bodies.  There might be an opportunity there.
Of course, unless you have the ability to productionize and market your concept, it might not be a financially viable effort.  Keep in mind that there are plenty of $75+ Chinese EF-E mount adapters already out there, and the future of the E-mount looks secure for the foreseeable future.
tecnoworld
Nx1 and nx500 are probably better than anything apsc canon will produce in the next 2-3 years, at least.
May I suggest that at least initially you could use external power for lens? IIRC some (Nikon though) lenses can draw a lot of power and there is a real risk of overloading nx side. 5x1.2V NiMH would do for 6V and a diode would decrease it to ~5.5V. You could then measure the current used by the lens and compare it to current provided for native NX lens.
cookedraw
cookedraw Senior Member • Posts: 1,970
don't do it, it will only push up the prices on second hand market when the canon people wake up.
Just kidding, do what you want man, nice to see people hack NX-system.
Thank you. It will be an interesting try.
The problem with that statement is that Canon is still in the camera business. In 2 or 3 years, will you still be able to get a NX1 or NX500 repaired. Canon supports cameras for up to 10 years. In 10 years, how many of the last Samsung NX bodies will still be operable and in use?
The greatest advantage of a short flange mirrorless body is that with an adapter you can use it to bring life to a lens from a dead system. To give an example, Contax G and N mount lenses can be mounted and autofocused on Sony A7 bodies with an adapter.
6
I am a NX1 owner and I agree a good number of people want to use EF lens on their NX body. So, I decided to work on EF-NX adapter.
At this moment, I am not interested in E-mount system.
As you mentioned, E-mount system might have a bright future. So more chance might be that someone who is interested in both NX and E-mount will work on the adapter.
ILHYOUNG.
ILHYOUNG.
Ihkim, you are my hero!
andre2you Regular Member • Posts: 175
Yes, I'd sign up for kickstarter, if you get it working.
 andre2you's gear list:andre2you's gear list
Samsung NX1 Sony a7 II Samsung NX 50-200mm F4-5.6 OIS Samsung NX 10mm F3.5 Fisheye Sony FE 28-70mm F3.5-5.6 OSS +3 more
Oguzhan Forum Member • Posts: 62
I'd support on kickstarter as well. I can find at least 50 people who might wanna participate
Thank you for trying to achieve such a project.
mordor_74 Contributing Member • Posts: 622
I'm in for the kickstarter!
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
