rethinking Micro Four Thirds in 2016
Started Feb 25, 2016 | Discussions
Alex Notpro
Alex Notpro Senior Member • Posts: 1,013
When I got into MFT in 2012 the following cameras did not exist:
- Sony A6000, A7 series
- Canon EOS M series (M1 had been announced but had no lenses, M3, M10 came later)
- Fuji X-T1 and serious Fuji lenses (56mm f/1.2 came later)
- Samsung NX1
Does MFT still make sense for me in 2016?
These are my requirements for a camera system:
- There should be at least 2 cameras, one pocketable (like E-PM2) and one high-performance ergonomic camera (like E-M1)
- All lenses and flashes should work well on both cameras
- Would be nice if both cameras could take the same batteries (Olympus fails here)
- Lenses must include a fast normal prime (50mm AOV), ultra-wide (14mm AOV) zoom, a fast normal zoom, a longish macro (105-120mm), a classic portrait prime (fast 85mm), a super-telephoto zoom, and a 35-50mm fast pancake prime. Nice-to-have a pancake normal zoom and a travel zoom (28-300). (MFT is king here)
- Would be nice-to-have access to 35, 50, and 85mm prime f/1.4-equivalent apertures for special situations (MFT comes short here)
- Must-have precise fast AF with C-AF and face/eye detection. (MFT very good)
- Option to use high shutter speeds when needed (high ISO)
- Option to use low shutter speeds and low ISO when needed (OIS/IBIS)
- AF during video (E-M1 is ok)
In particular, I'm wondering about A7II + A6300 or Canon 5DIII + M10 to replace E-M1 and E-PM2 respectively.
Thoughts?
 Alex Notpro's gear list:Alex Notpro's gear list
Sony FE 35mm F1.4 Sony a5100 Sony a7 II Sony FE 24-240mm F3.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +7 more
Canon EOS 5D Mark III Canon EOS M10 Canon EOS M3 Fujifilm X-T1 Olympus E-M1 Olympus PEN E-PM2 Sony a6300 Sony a7
Bob657 Veteran Member • Posts: 3,486
Re: rethinking Micro Four Thirds in 2016
17
- Samsung NX1
Thoughts?
As no system is perfect, what do you want to improve over your current m4/3?  You've listed hardware reqirements that are mostly met by m4/3, what photographic advantages do you want from making a change?  What shooting situations are you not able to handle now?
Bob G
Visit my website at:
http://bobgreenberg9918.zenfolio.com
 Bob657's gear list:Bob657's gear list
Sony a6400 Sony a7R IV Sony FE 100-400mm F4.5-5.6 Tamron 18-300mm F3.5-6.3 Di III-A VC VXD
Mistajolly Regular Member • Posts: 352
28
Let your own photography inform you. If mft is limiting your ability to take the pictures you desire then it's time to move on.
It's easy to do the analysis on paper and see the weakness in mft but I think it is over stated.
The camera business is tech, there will always be better equipment, take a deep breath, relax and focus on your photography.
 Mistajolly's gear list:Mistajolly's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Olympus PEN E-PL5 Olympus OM-D E-M10 II
Skeeterbytes Forum Pro • Posts: 23,186
It seems as though the using lenses cross-brands criterion gives m4/3 an unassailable edge, but regardless the process is always 1. establish need 2. find tool that best meets need.
Rick
jeffharris
jeffharris Forum Pro • Posts: 11,409
What about GM5, GX8, GH4?
Don't they? I never use a flash.
Few do and it is a shame.
14mm is NOT ultra-wide. 12mm isn't either. 10.5mm (21mm) and below is.
If you look most of those lenses are mostly there. There IS a dearth of long primes and a long macro.
When I can't find native lenses to suit me, I adapt. On multiple levels. try it.
P 25mm f1.4 and P 42.5mm f1.2. Then there are the three Voigtländers that hits them all.
You can't? Really?
It depends on what type of video you're doing. Manual focus is more reliable in many situations.
Thoughts?
What about Panasonic. Take a look. It could be enlightening.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Voigtlander Nokton 42.5mm F0.95 Panasonic Lumix DMC-GX8 +26 more
TomFid Veteran Member • Posts: 4,000
5
I have the same urge to look around once in a while. So far other systems come up short.
E-mount: not much of a lens lineup, and little evidence of interest from Sony.
A7/FE-mount: interesting, but only if I wanted to at least double the size and cost of my gear. Even then, nothing practical to rival the new Oly 300mm, it appears.
Almost a joke. What are there, four native lenses?
Interesting, but a small niche, and not enough sensor size gain to differentiate.
- Samsung NX1
Dead end?
It seems like you'd be looking at a huge investment on either of those platforms, for fairly limited gain. Spending it on those forthcoming 1.2 primes might serve you better?
Alex Notpro
OP Alex Notpro Senior Member • Posts: 1,013
Bob657 wrote:
As no system is perfect, what do you want to improve over your current m4/3? You've listed hardware requirements that are mostly met by m4/3, what photographic advantages do you want from making a change? What shooting situations are you not able to handle now?
All those new cameras have larger sensors. So there are not necessarily any shooting situations that I'm not able to handle now, just an expectation of some slightly better results in some of the same shooting situations.
10
Larger sensors can provide better quality, all else being equal.  Some of the systems won't have ibis as capable as what you have (which can offset some of that advantage), or lenses that meet your needs, etc.  Only you can decide what trade offs are acceptable!
For me, the quality in M4/3 more than meets my needs and the smaller size and weight are big advantages.
Bob G
MOD Tom Caldwell Forum Pro • Posts: 46,359
Cost no object?
Your existing M/3 bodies are not going to work on either of your choices.
I came from Canon via Samsung and Sony to M4/3 and am quite happy that I can get premium performance bodies at quite reasonable prices AND I can use my old Canon EF lenses. Undersatndably I only have two NX mount leneses and was smart enough not to buy any Sony ones.
FF sensor - well if you must have one ... but I manage somehow without a few sq mm of sensor coverage.
Tom Caldwell
jalywol
jalywol Forum Pro • Posts: 12,302
- Samsung NX1
I have the A7.  Bought an A6000 for a second body.  Hated it, and REALLY disliked the Sony's APSC lenses.  Now have a GM5 for my portable to complement the A7.
The A7II is nowhere near as fast in AF as the M43, and definitely not as fast in low light.
Native lenses are bigger, more expensive, and there isn't the same kind of assortment available as for M43.  If you are willing to use an adapter, you can use A-mount or Canon lenses with AF and stabilization, which would give you a lot more choices, but you have to be willing to deal with the adapter thing.
IQ on the A7/A7II is exceptional.
Why not look into the A7II as your high performance camera with better shallow DOF options, but keep your EPM2 and some lenses as your small backup?  Some things M43 really still does better than the other mirrorless competition out there....
-J
Aberaeron Forum Pro • Posts: 10,184
Alex Notpro wrote:
Thoughts?
Go with your dreams.
Sergey Borachev Veteran Member • Posts: 5,338
I get itchy feet too because we are stuck with the same level of sensor IQ since 2012, since the E-M5 was released. However, at this time, taking all requirements of yours into consideration, I think you're better off waiting and switching to A7 III. By 2018, there will probably be enough lenses for E mount and the weaknesses/issues in the current A7 cameras should be fixed. This assumes that you don't mind the extras weight and costs of the better quality lenses for that system. Sony is becoming the natural choice as an upgrade system for those who desire higher quality than M43 can provide.
pdelux Senior Member • Posts: 1,113
6
M43s sensors will never ever match larger sensors. This will always be the case forever. You can not escape it.
So if your only determining factor is SENSOR performance, then you are right you should leave M4/3 and go large, to say APSC or FF. But then there is always MF which is larger still and after that, larger still?
When will it end? At some point in time you need to make a decision, compromises. Which one can I afford. Which one can I actually carry, which will provide me the most fun, most usability, results. Ask what is important to you. If IQ trumps all go large as you can.
Everyone wants the best IMAGE possible. But at what cost? a FF camera that you could never take to a dinner party, or carry hiking?
Write of a list of factors which are important to you from most important to least important. Then choose the system that fits those needs. No one on this forum can answer these questions for you.
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
ambercool
ambercool Contributing Member • Posts: 911
The way you shoot and the photos are fine.  I think it's just all in your head, not a bad thing, and your concerns are not real.  Results show that not one person could tell the difference by looking at your photos.
-Viet
http://www.ambercool.com
"Luck comes to those who do"
 ambercool's gear list:ambercool's gear list
Sony a7 Nikon D70 Canon EOS 5D Olympus PEN-F Leica Summilux-M 50mm f/1.4 ASPH +29 more
Joe Sesto Veteran Member • Posts: 3,084
Re: rethinking Micro Four Thirds in 2016...Not if you compare cost, bulk and weight!
Thoughts?
I can only comment on the Canon 5DIII, as I just sold 3 EF 1.4 primes (2 Ls), 4 L zooms and 2 Gold primes...estimated weight 18 lbs. +/-. Check the price of a 24/1.4 II...35/1.4 II and 85/1.2, even used Is.
Mine were mostly the first issue, but they would still work well on a 5DIII. If you look at my MFT gear list everything there is close to within 1/2 stop of the Canon primes...the zooms and macro are identical 2.8s at 1/3rd the cost and 1/3rd the weight.
I haven't rec'd the Pen F, yet...but though it will not be pocketable...I think it will fit in a belt case with the 17/1.8, which I think is the only prime that I could use any where, any time, inside/outside with a little 2-footed zoom.
It's a better backup than the Canon G-11 now in a belt case...and the full range 14~200 (eq) still is available in a camera bag with both Oly bodies that would only carry 1 full frame body and 4 zooms. I have nothing against the other Pen bodies, but I'm not going to adapt to LCD composition and control after half a century of VF. shooting.
What are you going to print above 16 x 20 that requires full frame res? And if you like the 4/3 format you will find that 4/3 (1:1.33) on an APS-C is not that much larger...but 1.5 and 9/16 will cover more sensor real estate on APS-C. How often do you need 1.4 as 1.7-1.8 is too slow? Some of the most famous photographers lived with f/4 or slower with ASA (not a typo) film under 100...none had 4-5 stop IBIS...most used tripods.
There will always be something new that is faster, sharper, better so you will never be satisfied. That gets expensive. It takes time to learn new systems and that is not likely to produce the best results quickly...trust me on that.
There is a lot of conjecture here as to what the next E M1 will be, but I have hunch they are far short and it will not be the 20 MP that's now out. And it's not all about MP.
Joe Sesto
Oly E-M1 - Pen F (ordered)
 Joe Sesto's gear list:Joe Sesto's gear list
Canon PowerShot Pro1 Olympus PEN-F Canon EOS 5D Olympus M.Zuiko Digital 25mm F1.8 Olympus M.Zuiko Digital 45mm F1.8 +6 more
Messier Object Forum Pro • Posts: 12,724
I am definitely re-thinking m.43 in 2016.
I still don't own any m.43 equipment, but I do own 7 Olympus 4/3 DSLRs and over a dozen Olympus 4/3 lenses.
I was disappointed when Oly abandoned their DSLR, and was not at all impressed with the handling of the E-M1, especially with the 300mm F/2.8.  Early PDAF performance was by most accounts not much better than the E-5. So despite being the only m.43 camera with PDAF support I didn't see the merit in adopting the E-M1 just for a bit better low light performance and 4 extra Mp over the E-5.
However subsequent software upgrades to the M1 and a (seeming) commitment by Olympus to hybrid AF (probably) means that PDAF function and performance will continue to evolve with many more AF points, cross-type AF points and better C-AF. Whether any of these developments will flow through to better AF with the legacy 4/3 lenses, or will only benefit the new pro m.43 glass is still a question in my mind.
So YES, I'm rethinking m.43 this year with an eye on the expected new E-M1 Mk II.
Even if the AF improvements are marginal, a new 20Mp sensor will be a big step up from the old E-5 and I'll compromise on handling to get that new sensor.
Peter
 Messier Object's gear list:Messier Object's gear list
Olympus C-5050 Zoom Nikon Coolpix 990 Olympus E-300 Olympus E-30 Olympus E-5 +31 more
DP13Photo Veteran Member • Posts: 6,307
- Samsung NX1
Thoughts?
I got into µ4/3 in 2010 and then got the A7 late 2013. I feel the systems can work well together. Different sized sensors each have their benefits and disadvantages.
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 IV Sony a7C Sony a7 III Sony FE 24mm F1.4 GM Sony FE 50mm F2.5 G +15 more
golfhov Forum Pro • Posts: 11,893
Your not getting a lot of love here.
As you pointed out there are things that a larger sensor is capable of that a mft camera is not. Particularly if you are looking at the wide end of the system where MFT is lacking in choices and legacy lenses cannot be adapted. At the end of the day the MFT is system is generally smaller and cheaper. Your call on what is important to you. The a7 series in particular is an interesting comparison. The ii models have finally opened up a wealth of adapted lenses with reasonable auto focus.
At the end of the day think about your images and your lifestyle. If you are getting everything you want out of your camera than you would be wasting money. As someone pointed out the difference in mft and apsc if you like the 4/3 format is not that large. If you like the 3/2 format it is. If you want to keep your kit as small as possible a larger system would sit at home rendering any image improvements or capabilities moot
To each his own
 golfhov's gear list:golfhov's gear list
Panasonic LX10 Sony a7R II Sony a7 III Sony FE 28mm F2 Tamron SP 70-200mm F/2.8 Di VC USD +11 more
Franka T.L.
Franka T.L. Veteran Member • Posts: 8,161
All the other Q, pls refer to the camera spec sheets .. do your research, but here's this bit about your lens requirements so to speak
  • Fast normal , OK everybody got one at least
  • Ultra Wide Zoom , same, everyone got it
  • Fast normal zoom , well what's normal, 24-70 typical to me is not normal at all, it does not cover long focal for real .. so I give this to M4/3 , the 12-40 just edge into the long focal with that 40mm but I am not too keen on the optics and 40 is only really edging into long focal technically, its not long enough, but that's just me , yours may differ. To me a true standard zoom need to go straight from wide to long focal minimal , OK that's not too hard , we have all the 24-120 or similar, but fast, probably none of them qualify. I guess Fujfilm's 16-55/2.8 qualify but Fujifilm not on the listed.
  • Long Focal Macro .. M4/3 solely fail, the longest macro is just 60mm and that simply do not provide the working distance allowed , in fact the long focal and tele macro is what all mirrorless fails, There is reason why the Nikkor 200mm and the Canon 180mm Macro remain popular despite their age.
  • Fast 85 , well everyone had one , no issue here
  • 35-50 fast pancake prime , sorry the only pancake prime that I can satisfactorily called fast do not belong here. Samsung got a 30mm/2.0 for their NX so everyone fails this one
  • pancake normal zoom, well I have yet to ever seen one .. if I am wrong, please enlighten me
  • Travel zoom, well again everybody got that covered
  • all the 35,50,85  at f/1.4 or better, well, Canon beat every others ... and you have the option to go with Sigma on EOS EF mount too
- Franka -
SirPalomid
SirPalomid Contributing Member • Posts: 938
There are few things that stopping me to go only m4/3 route - sensor DR/color depth (not so good highlights recovery and shadow noise also), and lack of really good wide-angle options (9-18 is so-so, Pana 7-14 gives purple blobs on EM1, and Oly 7-14 has wild and heavily corrected distortion).
I'm Ok with not so thin DOF, focusing speed and accuracy is more than acceptable for me.
At the same time, when thinking about going full Fuji... Fuji excels where EM1 fails, and vice versa: slow AF, f2.8 lenses are much larger and heavier, but better DR and color gradations... and no significant improvements in sensor performance too since 2011
 SirPalomid's gear list:SirPalomid's gear list
Fujifilm X100F Nikon Z5 Nikon Z 24-50mm F4-6.3 Tamron 17-35mm F2.8-4 Tamron 35-150mm F2.8-4 +2 more
