Focus stacking of a snowflake
Started Feb 23, 2016 | Discussions
James A Rinner
James A Rinner Senior Member • Posts: 1,611
46
Olympus Focus Stacking Example, Snowflake 2016-013
Now I have been focus stacking for a while using a pair of film lenses mounted face to face (which resulted in 3.6:1 macro so I understand it pretty well.  I recently purchased a used E-M1 and 60mm macro lens to make my life easier when shooting extreme macro.  The snowflake above is about the same macro magnification as my manual setup because I added two extension tubes (16mm and 21mm, Movo brand, with M4/3 electrical contacts) to the 60mm Olympus macro lens.  Here is what I have found out so far:
  1. It is not as easy as you think!
  2. Because, at this high of a magnification, the area in focus is just a sliver and any movement can ruin the whole series of shots.
  3. I delete way more than I keep.
  4. A tripod is a waste of effort when doing snowflakes because by the time you finally get it set the snowflake either blows away or melts.
  5. I have been getting the same amount of keepers whether I used the camera's autofocus or found the start point by manual focus with a dedicated FN button to switch to manual.
  6. Using the camera's autofocus is a bit tricky because it could focus on the background, while the snowflake is a millimeter above it (held in position by the fibers of the background) and the whole series is out of focus.
  7. The photo above is a series of 12 exposures but I started with 30.  18 were so far out of focus that I just deleted them.  I try to start at a spot that is in front of the subject and hopefully by the end of the series I have traveled past the last bit of flake.
  8. Still took over 6 hours of Photoshop for the final image.
I think I will be able to eventually get the hang of this.  For my old manual film lens setup (see below) I machined a clear acrylic tube (lens shade?, not really!) to mount on the back of the Olympus 50mm 1.4.  The other lens is a Minolta Md 85mm 1.9.  The length of the tube set me at a sweet spot for focusing with the manual setup.  I hope to do the same soon with the 60mm macro.
Sincerely,
James A. Rinner
 James A Rinner's gear list:James A Rinner's gear list
Olympus E-10 Olympus E-20 Olympus OM-D E-M10 Olympus PEN-F Olympus E-M1 II +15 more
Olympus E-M1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro
Giiba
Giiba Regular Member • Posts: 414
Re: Focus stacking of a snowflake
Simply amazing. How many snowflakes were melted in the making of this picture?
 Giiba's gear list:Giiba's gear list
Olympus E-M1 Olympus 40-150mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 8mm F1.8 Fisheye Pro Panasonic 8-18mm F2.8-4 +1 more
doccy Regular Member • Posts: 359
Very clever - looks awesome.
WGHalvorsen
WGHalvorsen Contributing Member • Posts: 633
The result of your monumental effort is beautiful. I look forward to hearing more about this.
/Bill
 WGHalvorsen's gear list:WGHalvorsen's gear list
Fujifilm X100V Nikon D300 Olympus E-M1 Nikon D850 Olympus OM-D E-M1X +38 more
Jim Salvas
Jim Salvas Veteran Member • Posts: 5,671
Marvelous! I admire both the result and your dedication in achieving it.
Jim Salvas
"You miss 100% of the shots you never take." - Wayne Gretzky
 Jim Salvas's gear list:Jim Salvas's gear list
Olympus PEN E-PM2 Olympus E-M1 Olympus PEN-F Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +11 more
James A Rinner
OP James A Rinner Senior Member • Posts: 1,611
10
The shot below was with the manual lens setup.  It was a stackup of 50 shots!  This was a very big snowflake.  It was shot with the E-M5 and had to kept in my jacket between shots to keep the camera warm.  The E-M1 performed flawlessly out in the cold.
Sincerely,
James A. Rinner
dontfret
dontfret Senior Member • Posts: 2,340
I applaud your technique, dedication and stunning final result.  Not tpo mention the quarts of hot chocolate/coffee it must have taken to thaw the photographer out!!
Rich
Take many pictures - a few are keepers, the rest are are lessons.
 dontfret's gear list:dontfret's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-G5 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +12 more
KTClown
KTClown Senior Member • Posts: 1,461
Does the Snow Flake Union know about this?
You done a very good job on this, nice photo.
Gary
Pueblo, CO
 KTClown's gear list:KTClown's gear list
Olympus XZ-1 Olympus PEN E-PL5 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +2 more
Mister Roboto
Mister Roboto Senior Member • Posts: 1,887
Excellent, thanks for sharing!
 Mister Roboto's gear list:Mister Roboto's gear list
Olympus OM-D E-M10 Panasonic Lumix DMC-GF7 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus 9mm F8 Fish-Eye Body Cap Lens
James A Rinner
Funny...
Usually at least two hours standing outside, but with warm boots, flannel lined jeans, warm jacket and gloves!
Sincerely,
James A. Rinner
James A Rinner
Thanks.  Not the best year for snowflakes though.  It has been plenty cold enough but the snow has been fragile.
Sincerely,
James A. Rinner
James A Rinner
Thanks,
I have pretty busy this last year.  I think this is the first thread I have started in quite a while.
Sincerely,
James A. Rinner
James A Rinner
I like your Wayne Gretzky quote!
Sincerely,
James A. Rinner
19andrew47
19andrew47 Forum Pro • Posts: 45,408
A lot of work but the end result is gorgeous!!!  Bonus is that you could do this hundreds of times and up with different images, all beautiful.
Andrew
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
very impressive
My Galleries are at
my albums are at https://picasaweb.google.com/115423645123114525430
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
James A Rinner
Thanks Gary
Sincerely,
James A. Rinner
WNeuetc Regular Member • Posts: 378
Wow.  The (most welcome) technical details aside, this is indeed an amazing photo. Wow.
Sincerely,
James A. Rinner
Wes Neuenschwander
Seattle, WA USA
 WNeuetc's gear list:WNeuetc's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +2 more
James A Rinner
My pleasure!
Sincerely,
James A. Rinner
kitsap2
kitsap2 Senior Member • Posts: 1,375
Simply exquisite!
 kitsap2's gear list:kitsap2's gear list
Olympus E-M5 II Panasonic Lumix DMC-LX3 Ricoh GR II Panasonic Lumix DMC-GX85
Ian Stuart Forsyth
Ian Stuart Forsyth Veteran Member • Posts: 4,095
I feel your pain
5
Very nice work I know what you are going through
I went a little different rout and built a bench similar to what you would think of as a microscope.
More info can be found here
http://www.dpreview.com/forums/post/56974730
The deck design allows me to level the flake to sensor to maximise DOF and easier to handle flake.
I would first capture the flake on a old lens filter and place it on the deck and use LV to level the flake ( a helpful hint is to use sugar or salt to pre level the deck in a warm house before hand)
My reward in finding the perfect snow flake
Insearch of the perfect flake
The Camera is only a tool, photography is deciding how to use it.
The hardest part about capturing wildlife is not the photographing portion; it’s getting them to sign a model release
 Ian Stuart Forsyth's gear list:Ian Stuart Forsyth's gear list
Nikon PC-E Nikkor 45mm f/2.8D ED Pentax *ist DS Pentax K10D Pentax K20D Pentax K-7 +27 more
