Canon 35mm 1.4 Blue Lens and 1DX
Started Feb 22, 2016 | Discussions
tvstaff
tvstaff Veteran Member • Posts: 3,264
Can anyone post some shots with the NEW Canon 35mm 1.4 with the blue lenses?
Thank you!
Tony
Feel Always Humble - "FAH" - You'll Learn More
http://www.KissMyKite.com
 tvstaff's gear list:tvstaff's gear list
Canon EOS-1D X Canon EOS-1D X Mark II Canon EOS-1D X Mark III Fujifilm GFX 100S Canon EF 35mm F1.4L USM +28 more
Canon EF 35mm F1.4L II USM Canon EOS-1D Canon EOS-1D X Fujifilm XF 35mm F2 R WR
msowsun
msowsun Contributing Member • Posts: 740
Re: Canon 35mm 1.4 Blue Lens and 1DX
Thank you!
Tony
Here is a link: Canon EF 35mm f/1.4 L II USM samples
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
J A C S
J A C S Forum Pro • Posts: 20,544
tvstaff
OP tvstaff Veteran Member • Posts: 3,264
msowsun wrote:
Thank you!
Tony
I guess I was expecting more....
I can't see the $1,700 difference. Is it me???
J A C S
tvstaff wrote:
msowsun wrote:
Thank you!
Tony
Yes, I paid $1,550 for it. How did you get a $1,700 difference?
LaszloBencze
LaszloBencze Contributing Member • Posts: 828
There is a distinct difference at the widest apertures (1.4 and 2.0). The new II version has no chromatic aberration and is distinctly sharper. By f2.8 the difference is slight and at f4.0 there is no difference.
However, in practice the differences are quite subtle. There are various comparisons between the two lenses on this site that are worth looking at. I think you will agree that comparing them requires a lot of back and forth.
Because the differences are subtle and because I already own the older version and would have to take a huge hit selling it used, I decided to keep it. Here are a few pictures shot with the original 35mm f1.4 wide open. You can decide whether the results are noticeably inferior.
tvstaff
Ok... I think I'll wait until the difference is substantial and up until 4.0.  Thank you VERY much for posting these. Best regards, Tony
J A C S
How substantial? The I has soft corners at f/2.8, and the II is sharper there even at f/1.4. Also, the II shows better flare resistance in some situations so far, see the test in the other thread.
LaszloBencze
You don't need it!
Just looked at your website. Your pictures are wonderful! But just about everything I saw was taken with a substantial telephoto. I saw maybe one wide angle shot taken in full sunlight with the aperture set to at least f8. Based on what I saw, the advantages of the 35 f1.4 II would never be realized in your style of photography. You just wouldn't see a difference. Save your money and continue on as you are.
tvstaff
Re: You don't need it!
Thank you for your kind words. Yes it's just not for me. If they ever make a 70-200 I'll be the first in line
Jason Stoller
Jason Stoller Veteran Member • Posts: 6,641
tvstaff wrote:
msowsun wrote:
Thank you!
Tony
Tony you ought to know by now you cannot just what you are going to get by looking at the final result on a Monitor.  You have to look at the end result on the final print.  That end result will vary on the size of the final print too.  You need to get you some samples images shot under different lighting conditions and makes some Larger Prints and then you will get a good idea of what results you are getting and if its worth it.
Jason
Jason S
We are just Beta Testers who pay the Camera Companies to test their new products!
 Jason Stoller's gear list:Jason Stoller's gear list
Canon PowerShot D10 Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 70-200mm F2.8L IS II USM +11 more
tvstaff
Jason Stoller wrote:
tvstaff wrote:
msowsun wrote:
Thank you!
Tony
Jason
Well said Jason. I will try first
paure1 Regular Member • Posts: 230
Hi,
For pictures of and with the 35mm L and 1DX see the review by Bryan Carnathan at
http://www.the-digital-picture.com/Reviews/Canon-EF-35mm-f-1.4-L-II-USM-Lens.aspx
Allan
 paure1's gear list:paure1's gear list
Canon PowerShot G12 Canon G7 X II Canon EOS-1D Mark III Canon EOS 5D Mark III Canon EOS R +10 more
