Adjust both aperture and shutter speed on X-E2 with XC lens
Started Feb 22, 2016 | Discussions
urjeans New Member • Posts: 2
Hi all. I'm just sold my Canons and joined the Fujifilm last month. Recently when I was using my X-E2 with XC 50-230mm, I found it a big problem when I was trying to adjust both aperture and shutter speed. Say, I configure my command dial for aperture control. Thus the most straightforward way to adjust the shutter speed is to use the shutter speed dial. However, the shutter speed dial can only change by a full step, which lose so much flexibility. To make matter worse, when using T-Shutter, I cannot change my exposure time directly with my shutter speed dial.
The major causes are that 1. XC lens do not have aperture ring and that 2. X-E2 has only one command dial. It took me quite a wile to find that the command dial can be configured for aperture control or shutter speed control but it is just too much trouble to change the setting over and over......
I'm not sure if I missed anything, but I believe that there is something fuji can do to make it less troublesome. For example, if I can configure "Press command dial" as "Change command dial functionality" I can adjust aperture speed with command dial first, then simply press command dial to change its functionality, and then I can adjust shutter speed with command dial right away.
I just wrote a letter to fuji, hope that we can see some change in future firmware update (hopefully)
any comment?
P.S. Sorry for my terrible English expression.....it's not my first language
Fujifilm 50-230mm II Fujifilm X-E2
Myki2000 Forum Member • Posts: 97
Re: Adjust both aperture and shutter speed on X-E2 with XC lens
Hello,
Assign to a button: "command dial setting" and you have what you want
 Myki2000's gear list:Myki2000's gear list
Fujifilm X-T2 Sony a7 III Fujifilm XF 18-55mm F2.8-4 R LM OIS Sony FE 70-200 F4 Fujifilm XF 50-140mm F2.8 +14 more
DarnGoodPhotos Forum Pro • Posts: 11,881
The rear d-pad adjusts shutter speed in 1/3 stop increments.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Not anymore with the firmware 4.0. You have to assign a fn button to switch from Aperture to Speed.
Ah, forgot about 4.0. If you assign it to the left and right d-pad buttons, doesn't it do what I said?
Ric Cheng Regular Member • Posts: 338
Command Dial Setting
Choose whether the command dial controls shutter speed (S.S, the default option) or aperture (F).
This option only takes effect with lenes that are not equipped with an aperture ring.
Assign this to one the of function button Fn
a_c_skinner Forum Pro • Posts: 13,047
Just use whole stops for shutter speed.  It will be within half a stop of ideal, you won't see the difference.  Honestly.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
OP urjeans New Member • Posts: 2
got it. Just assigned my Fn to "Command Dial Setting" and it works great for me! Thanks guys
ictiosapiens Junior Member • Posts: 26
Just got this lens! This thread just solved a problem. Again, these forums continue to prove invaluable.
