Canon 10-18 vs Tokina 11-16, which one is better?
Started Feb 22, 2016 | Questions
EricJung New Member • Posts: 15
Canon 10-18 must be a good qualified ultra wide lense for crop, but there is another critical review about "poor" sharpness of this lense.
On the other hand, it seems tokina 11-16 has a good reputation of image quality, but it also has flaws like flare.
So i'm slightly confused which one is better choice about image quality, color rendering, low distortion, overall sharpness, etc, regardless of price and weight.
And does tokina 116 has too much contrast or deep color? I'm also care about this, because I don't like too much contrast and unnatural color rendering.
Great Bustard Forum Pro • Posts: 45,641
Re: Canon 10-18 vs Tokina 11-16, which one is better?
The Tokina has less range, more distortion, less vignetting (up to f/8), and more CA than the Canon.  Both are about the same sharpness.  And while the Canon has IS, the Tokina is two stops faster, but weighs twice as much, and takes a 77mm filter while the Canon takes a 67mm filter.   Lastly, if you are patient and willing, you can get the Canon for around $200 used or as a refurb (don't know about the Tokina).
So, there you have it -- choose your weapon.
OP EricJung New Member • Posts: 15
Thanks for your reply
Are you sure both lenses are about same sharpness? If then, I'll pick the cannon without hesitation.
But someone says there is remarkably different sharpness between two lenses, especially at the corners. So I can't decide easily.
Check the links I gave in the reply -- they give the resolution measurements.  That said, I don't know how close to the corners the "extreme edge" measurement is on the Photozone tests.
p5freak Senior Member • Posts: 2,998
My copy of the 10-18 is corner sharp, even wide open. You can download some sample pics here : www.p5freak.de/10-18.zip Amazing lens, if you dont mind the slow aperture.
Stupid is as stupid does - Forrest Gump
Thank you for your advice.
I'll check the link you noticed.
Actually I doubt if I use UWA lense frequently under the common circumstances, so it can be wiser to use budget lense in this case.
Thank you for your help. I'll check the sample.
Don't you feel 10-18 is inconvenient at night or lightless condition?
TigTillinghast Contributing Member • Posts: 528
I had the opportunity to test these two lenses together at the same time. My father in law got the Canon, and I already owned the Tokina (be sure you're dealing with the version II of that lens, as it's much sharper).
I found the 11-16 to be noticeably sharper with my copies. I MFA'd two cameras to both lenses in these tests, and it was pretty consistent. Edges were the issue most times. That said, it was a bit pixel-peepish to find the differences. I often care about this, as I shoot wildlife, and I'm frequently cropping to a 1:1 ratio. But with the ultra-wides, I suppose this'll matter much less, as you're not generally cropping in with those sorts of shots.
Tokina has a reputation for flare, but I didn't find that it flared any more than the Canon, and I was specifically looking for this stated weakness.
The big difference between the lenses was the trade-off between aperture and IS. If you are going to do hand-held shots of static subjects, the Canon is for probably you. The IS was quite good, although don't expect to see the dramatic difference that you do with new Canon IS at the end of a super telephoto lens. The wider field of view makes IS a little less important. I perceive 2 stops of real difference, which is pretty much countered by the ability of the Tokina to give you those two stops back via a wider aperture. I should not that it is unusually sharp wide open for a f/2.8 lens.
If, on the other hand, you are going to shoot in light-challenged places (like wide angle close-in landscapes under canopy), then the Tokina is for you. If you are a pixel peeper and hold sharpness above all else, the Tokina would make you happier.
The Tokina, by the way, has been superseded by a new 11-20 model that I haven't had a chance to test. That's about $500.
On cost, the Tokina can be found for about $350 new occasionally. I think someone is offering that right now, or at least they were last week. A quick look at Amazon shows it available for $400. The Canon at $325.
The only disadvantage to choosing the Tokina, other than lacking IS, is its slightly wider size (weight is still pretty insignificant), slightly higher cost.
Other notes:
- I use my 11-16 on full frame at the 16mm setting, and I don't get too much vignetting. I did not test the Canon on that, as I didn't have full frame when I had access to it.
- I don't use the 11-16 much at all any more because on crop I use the 18-35 Art lens, and on full frame, I use the Tamron 15-30. It only gets rolled out, as a result, when I need the super wide range on crop. Which is seldom, as 15mm on the Tamron full frame is equivalent to about 10mm, and the full frame image is superior for those wider shots where I'm not reach limited.
- The lens is one tough piece of glass. I threw a log into a vehicle and managed to hit the 11-16 and an SL-1 camera body hard enough that they came apart. After cleaning it up, it mounted back on the camera and has worked perfectly, even having checked its centering, etc. I did break the ring that holds the hood (glued it right back on), and there is a rattle inside, but it has been functioning for more than a year perfectly since. I was impressed by both body and lens's ability to take such a wildly hard hit and shrug it off. I suspect getting it properly fixed would cost more than a pristine used version, so it's now a permanent part of my collection.
 TigTillinghast's gear list:TigTillinghast's gear list
Panasonic Lumix DC-S1R Sony a7R IV Canon EOS R5 +1 more
jp4 Senior Member • Posts: 1,202
I like my Tokina for shooting the night sky.
 jp4's gear list:jp4's gear list
Canon PowerShot G5 X Canon EOS 80D Tokina AT-X Pro 11-16mm f/2.8 DX II Canon EF 100-400mm F4.5-5.6L IS II Canon EF-S 18-135mm F3.5-5.6 IS USM
Thank you for your experiential advice. I use sigma 18-35 art lense like you
Anyway, my main subject is my child who is moving and running constantly, so it's more important to me to control motion-blur of the subject by getting fast shutter speed.
If then, is the tokina more suitable for me?
DannH Contributing Member • Posts: 642
I own the Tokina 11-16 DX II. Yes the Canon is suppose to be better flare resistant, less CA and distortion but after a few thousand shots I have never encountered any real problems. If your shooting foliage wide open in daytime light then you may encounter CA, if your stopping the lens down then it really is a non issue. Any small amounts of CA can easily be taken care of in lightroom.
The Canon 10-18 is by no means poor in regards to sharpness, but the Tokina is marginally sharper. Colour rendering is a personal choice, many prefer the Canon, personally I prefer those of the Tokina which is why I picked it. Your best bet is to look through the groups on flickr and see which you prefer the look of.
The Tokina has the advantage of being a 2.8 lens, which is a big benefit if your in to astro photography, the 10-18 has IS if you like handheld shooting in low light (a tripod will make much more difference to the sharpness) otherwise you can't go far wrong with either. Below are a few shots from the Tokina.
Spotted Cow Senior Member • Posts: 1,586
TigTillinghast wrote:
Other notes:
FYI, since the Canon is an EF-S mount lens, it will not mount on a FF Canon body. I know that someone here on dpreview did modify the mount of the lens to fit it to use on FF but I forget the end result. I do remember he was able to use it on FF for at least part of the FL.
brightcolours Forum Pro • Posts: 15,885
Other notes:
The 10-18mm can be used without any vignetting on FF after modification, from 14mm or so to 18mm.. It will, however, always have soft corners, also stopped down and at 18mm. I suspect it will work fine with Soligor's 1.7x TC or a 1.4x TC from Kenko. Can't test that, because my 10-18mm is with a friend of mine at the moment.
Thak you for your advice.
No, it has IS, which compensates its slower aperture.
The Tokina would be better in this regard as it will allow you to use a faster shutter speed. But i'm curious why you want a UWA for your child? Isn't your 18-35 wide enough? Portraits can be taken at any focal length, but the wider the lens the more distortion and less flattering the portrait will be.
Below is a good example:
http://gizmodo.com/5857279/this-is-how-lenses-beautify-or-uglify-your-pretty-face
Yes, I already know the distortion of WA and the sigma 18-35mm does a good job in most situations. After I used the sigma 30mm for quite a while, I traded it off to add versatility and convenience of slightly wide angle at F1.8. And so far so good. I thnk it's the unique part of this lense for the crop users. It covers standard & slightly wide angle fast.
But sometimes I feel lack of ultra wide angle especially during my trips, actually not very often. So I want to add UWA lense for the trip and landscape photo, and I also wonder the feature of UWA lenses.
Well, I thnk I'll use UWA lense sometimes, but not very often, so I think it'll be wiser to use budget lenses like the canon 10-18mm.
But if the 10-18 has a really poor image quality, then I think I should go with another lense, so I asked about the comparison
