SMC Pentax DA 50-200mm F4-5.6 ED review
Started Feb 21, 2016 | User reviews
Turion
Turion New Member • Posts: 1
I found this lens to be very handy to have. It has a nice range at a very small size... and weight. It's slightly bigger than the Pentax kit lens (without a hood). At 50mm it's a little soft, however I found that stepping down to f8.0 helps a lot and also the contrast is really nice. I have nothing to compare it with unfortunately, but this lens is good, especially if you can get it cheap. Mine cost me 20.000 HUF, which is about ~$73 at the time of this writing.
Comparing it to other cheaper telephoto lens, like the inexpensive Tamron 70-300, it has a smaller zoom range, but keep in mind that the Tamron is about unusable above 200mm anyway, since it's so soft and has a terrible level of chromatic abberations. Yes, CA. I found that this lens doesn't suffer much from aberrations, maybe due to Pentax's super-multi coating.
This lens however is now discontinued and has been replaced by the weather resistant WR version, which is a better choice, if you plan to shoot in the rain or snow.
I could recommend this lens if you're a beginner, need a cheap but good telephoto lens and weather resistance is of no concern to you.
I included a few test shots.
Pentax K10D ; f8.0 ; 1/60s ; ISO100 ; 200mm
Pentax K10D ; f5.6 ; 1/30s ; ISO100 ; 200mm
Pentax K10D ; f8.0 ; 1/320s ; ISO100 ; 88mm
 Turion's gear list:Turion's gear list
Pentax K10D Pentax smc DA 50-200mm F4-5.6 ED Pentax smc DA 18-55mm F3.5-5.6 AL WR +1 more
Telephoto zoom lens • Pentax KAF • 21567
Announced: Feb 18, 2005
Turion's score
4.0
Average community score
3.7
Leica SL 50mm F1.4 Pentax K10D Pentax smc DA 50-200mm F4-5.6 ED
awa355
awa355 Regular Member • Posts: 201
Re: SMC Pentax DA 50-200mm F4-5.6 ED review
Another K10d owner with the 50-200 DA lens. I have the 18-55 DA lens as well but he 50-200 pretty much stays on the camera all the time. I don't go looking for the finer points good or bad out in the corners, I simply look at the overall image and either smile or frown and delete.
A few images from the K10 with the DA 50-200 lens. The horse photos were taken on a dull drizzly day. These are the downsized photos.
The gray sky did not help much.
This is a crop from the full resolution photo.
This kid was having a ball.
I was cropping into the horse,, honest!!
Hard to see the rain falling but it was there
Another crop.
 awa355's gear list:awa355's gear list
Nikon D7500
Tatouzou
Tatouzou Senior Member • Posts: 2,081
I have the early (non WR) version.
It has been my most used telezoom since 2006, until I got the HD DA 55-300 1 year ago.
I fully agree with your review: DA 50-200 has nothing stellar but it does the job and is very light and compact:
 Tatouzou's gear list:Tatouzou's gear list
Panasonic Lumix DMC-LF1 Pentax K-3 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Pentax smc DA 17-70mm F4.0 AL (IF) SDM +24 more
jf_tea Senior Member • Posts: 1,577
Snow Monkeys and SMC Pentax DA 50-200mm F4-5.6 ED WR
The DA 50-200 WR was the lens I choose to go get those pictures of snow monkeys. It was in Winter, with snow, and, the monkeys were playing in the hot spring bath.
Thank you Pentax, for the WR
It's easier to take pictures when not worrying.
The Dentist
Supper Can Wait
3 Small Ones
 jf_tea's gear list:jf_tea's gear list
Panasonic Lumix DMC-GX1 Pentax K-01 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Pentax smc DA 15mm F4 ED AL Limited +6 more
Tatouzou
Re: Snow Monkeys and SMC Pentax DA 50-200mm F4-5.6 ED WR
Nice shots
jamesm007 Veteran Member • Posts: 5,820
It is a nice lens for the price. When Pentax designed this lens more than likely it was to be the classic in 35mm/FF equal of 70-300mm. What they designed is a remarkably small lens that does that range as well as any in the price range.
Its small but has some heft to it, feels well built.
I personally wipe the barrel in down pours of rain before retracting. That's up to you.
It comes with a large thick lens hood, nothing cheap about it.
There is a pretty bad review from Photozone. They probably had a poor sample of the lens. Owning this lens I know its not that bad. The good reviews -
https://www.ephotozine.com/article/pentax-smc-50-200mm-f-4-5-6-da-ed-interchangeable-lens-review-4568
Popular Photo tested the WR version which is optically the same as all others.
http://www.popphoto.com/gear/2010/09/tested-pentax-50-200mm-f4-56-da-wr
Now after reading them, this lens should be a really good performer, better than Average. Well wide open and I will have some issues at certain focal lengths. However at f/11 it does produces a picture that is uniform across the whole 50-200mm frame and detailed enough for good prints 8X10. Pentax keeps it in the catalog.  A good performing and feature rich lens for the money.
A out of K-5 jpeg with minimal PP not cropped, no sharp mask
K-5, 1/500, iso400 200mm equal to 300mm FF. Out of Cam JPEG
 jamesm007's gear list:jamesm007's gear list
Pentax K20D Pentax K-5 Pentax K-3 Sigma 10-20mm F4-5.6 EX DC HSM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +12 more
johnapp Regular Member • Posts: 425
nice shots
