Lenses or body
Started Feb 19, 2016 | Questions
WilbaW
WilbaW Forum Pro • Posts: 11,643
Re: Almost me
Christopher2222 wrote:
WilbaW wrote:
pvicta wrote:
As I'm upgrading due to age, rather than anything esle, and the only contstaint I have found with the 500D is the number of RAW shots in a row before it stumbles, I don't feel like I will be settling for 2nd best with the 760D
Canon say the max. burst of the 500D is 9 at 3.4/s (page 214 of the manual), but the 760D is only 7 at 5/s (page 404), so while the 760D is faster it's buffer is actually shallower.
Just to compare apples to apples, the 500d transfers 599.4 MB shots frames per second and the 760d transfers 927.5 MB shots frames per second.
It's all apples, just different sizes.
Photog 1: "Hey I just got an amazing 927.5MB/s burst!"
Photog 2:"Err, yeah... how many shots?"
Photog 1:"Umm, oh, ah, dunno..."
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Christopher2222 Regular Member • Posts: 234
Re: Almost me
FALSE
Just saying the 760d buffer is not shallower, it's transferring more data per second than the 500d.  The claim that the 760d buffer is slower, is false.
 Christopher2222's gear list:Christopher2222's gear list
Canon EOS 1000D Canon EOS Rebel T6s Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS Canon EF-S 18-135mm F3.5-5.6 IS STM +1 more
WilbaW
Re: Speed RAW 70d and T6s
I know, it's the burst rate that matters. I wasn't disputing that fact. I only mentioned it was just interesting to note.
Sure. That's what fascinates me about what can happen here - you never know when you might learn something Quite Interesting.
Indeed the fast burst rate of capturing the grebe in a dive is certainly needed (nice photos!).
Thanks. You can see how even at 5.3 fps I only got one interesting frame per burst.
Being just an interesting fact I can't currently think of any use, where one would require 85 shots as opposed to 46 shots in 30 seconds anyways.
Yeah, I'm still trying to come up with one myself...
WilbaW
Re: Almost me
FALSE
How is a stack of 9 shallower than a stack of 7? (Think of image files as one pixel thick, so a larger file is wider and longer, not thicker.)
Sure, but the files are bigger and coming faster so it can't capture as many at the high-speed rate.
Good thing Canon's data says the opposite then.
Re: Almost me
FALSE
9 * 15Mb RAW = 135
7 * 22.5Mb RAW = 157.5
9 is shallower than the 7 overall
R2D2 Forum Pro • Posts: 26,551
It is interesting to note that in a speed test that although the 70d does shoot faster bursts it will not capture more frames over 30 sec.
Using the SanDisk extreme pro 95Mb/s 32gb card tests show the 70d capturing only 46 RAW images
while the ......................................................................................T6s capturing ....... 85 RAW images
What this tells us, is that after the buffer is filled there is a longer wait period on the 70d (because of older technology) while it clears it's buffer than there is on the T6s
information found here http://www.cameramemoryspeed.com/canon-70d/fastest-sd-cards/
WilbaW wrote:
R2? Would you do a quick test for us?
Hi guys.
I've been using 64 GB (and 32 GB) SanDisk Extreme Pro 95 MB/s UHS-1 cards since I got the camera.
I always get 20 (full size RAW) frames in 3 seconds before slowdown.
The camera will thereafter shoot at a rate of appx 2 FPS ad infinitum.
It takes just under 9 seconds to clear the buffer.
I've posted my results previously...
http://www.dpreview.com/forums/post/53759795
I just saw your post WilbaW (    ) and tested again (using the same settings as the guy at CMS).
I got:  20 frames at 7 FPS (until buffer full).  ~ 2 FPS thereafter.  Just under 9 seconds to clear the buffer.
I also did the "30 second" test and got 68 frames using both methods:
1. hold shutter for 30 seconds.
2. shoot burst, clear buffer, shoot burst, clear buffer, shoot burst and hold shutter.
68 frames each time.
Personally I like to shoot bursts (rather than just shoot continuously at 2 FPS) for the same reasons as WilbaW.  People and critters move very fast (even when they're not trying to!).  A fast FPS and deep buffer will simply net you more keepers (yeah, wish I had the 1Dx MkII on some occasions!).
R2
WilbaW
Re: Almost me
FALSE
9 * 15Mb RAW = 135
The unit of throughput is the image file, not the MB, so while 7 larger files requires more RAM, 9 smaller files is a larger number of deliverable units.
One camera shoots 7 frames at full speed and the other shoots 9 at full speed - which one can shoot the most at full speed? One pistol can shoot 7 large bullets before it has to be reloaded and the other shoots 9 small bullets before it has to be reloaded - which one can shoot the most bullets before it has to be reloaded? One truck can deliver 7 SUVs and another can deliver 9 compact cars - which one can deliver the greatest number of vehicles in one trip? (Insert your own example here.) That's all there is to it.
WilbaW
So 20/2.9s (7.0/s) plus 48/27.1s (1.8/s) equals 68. Thanks for helping out.
Seems like it all goes through the same bottleneck whichever way you stack 'em up behind it.
Nikon have really kicked a goal with the D500 with a 200 shot buffer, so I've heard. Surely adding that much RAM wouldn't break the bank...?
Exit10 Senior Member • Posts: 2,264
Hi guys.
R2
Interesting numbers thanks - so the 760D has slower burst speed but clears buffer faster and gets overall better throughput.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
OP pvicta Junior Member • Posts: 47
Re: Lenses or body
Hi all
Thanks very much for all your help, and the excellent discussion on speed, bursts and buffer size
I had a bit of a play with a 70D and 760D and decided on the 760D
I also had a bit more $$$ than I thought I'd have so was able to get the 15-85 as well
There's an open day at the airport here next weekend, so will get to take them out in anger then
In the end, it came down to what features could I use vs what could I do without, as well as feel
Ultimately I thought the newer 760D had more to offer me than the 70D
I wasn't able to track down a 60D to try, but I think I probably would have gone the 70D if I was going that way
Again, thanks very much for your help and suggestions
Paul
 pvicta's gear list:pvicta's gear list
Canon EOS 500D Canon EOS Rebel T6s Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 18-135mm F3.5-5.6 IS Canon EF-S 55-250mm f/4-5.6 IS +4 more
