1200d Focus speed question
Started Feb 17, 2016 | Discussions
with lots of gear but no idea Regular Member • Posts: 240
I hope to shortly be getting back into my Birding pastime, after having sold my 500d body some time ago, I don't want to spent too much money at the moment to get going again, so my question is:- has any body go views or experience as to whether or not the 1200d would be as fast as the old 500d or even the 550d Your advise would be much appreciated
 with lots of gear but no idea's gear list:with lots of gear but no idea's gear list
Canon EOS 500D Fujifilm X-E1 Fujifilm X-A2 Fujifilm XF 35mm F1.4 R Fujifilm XC 16-50mm F3.5-5.6 OIS +2 more
mocha123 Senior Member • Posts: 2,497
Re: 1200d Focus speed question
Hi,
Specs. wise I would lean more towards the Canon 100D, I dont know your locality but in the UK the 100D is only £56 pounds more expensive than the 1200D and is better equipped all round, link below for a head to head with 100D v 1200D
FPS the 1200D is slower than the 550D or the 100D 3FPS v 4FPS
http://snapsort.com/compare/Canon-EOS-1200D-vs-Canon-Rebel-SL1/detailed
For more detailed info check out this site for full reviews on both camera's.
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
OP with lots of gear but no idea Regular Member • Posts: 240
Hi Mocha. Thanks for your thought's and yes you have a good point re the 100d That would appear to be a better option although  'used' ones are a bit thin on the ground here,'in the UK' I was hoping someone who may have had one of these bodies would throw their 2p worth in. I know what the 500d could do focus-speed wise, and I just didn't want to get a later model then find I had made a mistake.
WilbaW
WilbaW Forum Pro • Posts: 11,643
I would stay away from the nn00D models on principle (too crippled for not enough saving IMO). If you're thinking second-hand, consider the 60D. Think of it as a 600D (which has the upgraded AF) with a bigger buffer and viewfinder, both of which you'll really appreciate for birding, for not much more than the cost of a new 100D.
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
