Olympus 25mm 1.8 or Panasonic 20mm 1.7?
Started Feb 16, 2016 | Discussions
tehkei
tehkei Regular Member • Posts: 138
Looking for a multipurpose, street/walking around lens. I currently just have the E-PL6 kit lens, the 9mm fisheye body cap lens and the Olympus 45mm 1.8.
I mainly shoot product photography such as toys, figures etc.. 45mm works fine for isolating the figure from the background. but not great when I go out and do tourist type shooting. the 9mm fisheye is way too soft for me and mainly used to play around with filters. Kit lens is ok but I prefer the faster primes.
I bought the 45mm first instead of a normal prime mainly because I thought I was gonna get a 25mm for 99 dollars since that will most likely not happen, now I'm scrambling to look for a normal prime to take on vacation this march.
 tehkei's gear list:tehkei's gear list
Nikon D5100 Olympus OM-D E-M10 Olympus PEN E-PL6 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 50mm F1.8G +7 more
Olympus PEN E-PL6
jsaras Contributing Member • Posts: 610
Re: Olympus 25mm 1.8 or Panasonic 20mm 1.7?
I don't have any experience with the 20mm but I'm delighted with the Olympus 25mm f1.8. I often take close-ups of my pizzas and the results are magazine-worthy. It's also effective for portraits and even landscapes. The bokeh is very nice and its sharp, detailed, etc. It's every bit as good as the 45mm.
 jsaras's gear list:jsaras's gear list
Sony RX100 III Olympus PEN E-PL6 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +10 more
LMNCT Veteran Member • Posts: 4,908
All I can tell you is that the 20 1.7 is very sharp and that it has good contrast.  It seems to have difficulty focusing with some of the Olympus bodies, but I use Panasonic bodies so it has been fine for me.  In fact, I own two 20 1.7 lenses.  I guess that means that I like the 20.  The 25 1.8 Olympus is probably a fine lens.  Your choice is between the Full Frame focal length of 40 or 50.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
generikku Contributing Member • Posts: 864
I have both and like them for different purposes. Also, they are different FOV. The 25mm will be tighter. Good if you want to be further away from a subject. A 17 (the 2.8 is decent enough for street) or 17.5 would also be good but you would need to get closer at times to a subject as they are wider FOVs (I have a 17.5). But it does make for a more intimate and being there type of photo, and can be used for say, landscapes or interiors too. The 20, then, would be a good balance, but on an Oly body, it's a little slower in low light to lock focus. Now that I have a Panny body too, my old Panny 20 stays there and never goes back on my OMD. My 25 stays mostly on my OMD. Things to keep in mind. Oh, and I would suggest you try a zoom and then see what feels best for you at all those focal length and then buy the one that fits your street subject comfort distance.
 generikku's gear list:generikku's gear list
Olympus PEN E-PL1 Olympus PEN E-PL3 Olympus PEN E-P5 Sony a7 Olympus OM-D E-M10 +2 more
Karld70 Veteran Member • Posts: 3,553
I would pick by what focal length is better for your needs. Set you zoom at 20, (keep it fixed at that focal length) and do a day of walk around testing. Then do the same at 25. See what worked more times for you.
BruceRH Veteran Member • Posts: 3,087
I tried both and kept the Panasonic 20mm. For me, I liked the images better. Yes, the focus is a little bit slower but really not an issue, at least for me. The Pannasonic is also more compact than the Olympus, a nice plus. The Panasonic feels cheaper(more plastic) than the Olympus but all in all, the Panasonic 20mm is a great lens, especially for the price.
 BruceRH's gear list:BruceRH's gear list
Sony RX100 III Ricoh GR III Leica Q2 Olympus TG-6 Olympus PEN-F +44 more
tehkei
OP tehkei Regular Member • Posts: 138
good to know that the 20mm is slower on Oly bodies. I would love to get the Oly 17mm but its slightly over my price range.
Chippy99 Senior Member • Posts: 2,182
As others have said, go with the focal length you prefer.
I have the 25mm Oly and it is superb - I really cannot fault it. Optically it is outstanding. Mechanically it's plastic but still well put together with metal mount and nice smooth focus action. It focuses instantly and accurately. There is nothing to not like about it.
But... it is imho a tiny bit long for a general purpose walkabout lens. It's decent for portraits though.
The 20mm would be a better general purpose lens imho, and cropping the images to 25mm equivalent FOV is not much of a crop.
 Chippy99's gear list:Chippy99's gear list
Sony RX100 Leica Q2 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 +4 more
tehkei
Good to know. I'm loving my 45mm it quickly became one of my favorite.
thk0 Regular Member • Posts: 159
I'm think the Oly 9-18mm + 25mm (hope to acquire soon) + 45mm would be a good and very small kit.
T.
tehkei
I'm leaning towards the 20mm, but I might also consider getting a 17mm 2.8. but not sure if I should wait till I can afford the 1.8 version.
tehkei
T.
I haven't bought a zoom lens in a long time. the Oly 9-18mm intrigues me thou.
Astrotripper Veteran Member • Posts: 8,676
20/1.7 might prove more versatile
Oly 25/1.8 is an excellent lens by all accounts. But having experience with Panasonic's 25/1.7, I'm thinking that a 20mm would be more versatile for general use. I find that 25mm is often a bit too tight in-doors, for example. My Sigma 19mm fits those situations better (but I still rarely use it, because I don't like it). It's similar for outdoors, a 20mm lens might be better suited for casual street shooting kind of thing.
It very much depends on your personal preference and shooting style. The big advantage of Panny is it's size. It should be a good match for your E-PL6 and make it kinda pocketable. It's probably gonna be just a few mm thicker than with that fish-eye bodycap.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Skeeterbytes Forum Pro • Posts: 23,184
I have both and prefer the 25, both for the field of view and snappy response. It's a close cousin to the 45 in operation.
Rick
dv312
dv312 Veteran Member • Posts: 9,215
Can't go wrong with either
They're both very sharp
The Oly AF is slightly better (faster) than the Panny
The Panny is slightly wider thus is not as 'normal, and is a tad flatter (but larger in diameter)
Take your pick
I have both and have sold off the Panny since I use these for street photography and the Panny is just too slow of AF
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
tehkei
Take your pick
I use the 35mm and 40mm lens a lot on my Nikon. which is closer to the 25mm on m4/3. I'm starting to wonder if it would benefit me more to save up a bit more and get the 17mm 1.8.
For street, the 17mm 2.8 is an underrated gem
Or so I've read. If I didn't already have my 17.5mm or 20mm, I would gladly get the 17mm 2.8. If street is your thing, that's plenty fast enough. Many old 35mm film lenses were 'only' 2.8. And on M43 you get deeper depth of field so that 17mm will be better than the 20mm if you like to zone focus or prefocus. Sure, the 17mm 1.8 or 20mm 1.7 will be better for bokeeeeh!!! but for street shots I find myself stopping down between 2.8 to 5.6 more often than not as I'd rather have the background for context in street shots. But, if night time street shots are your thing, yeah, then by all means save up for the 17mm 1.8.
jotor
jotor Senior Member • Posts: 1,719
Buy used and sell it when/if you decide to get the 1.8.  Consider any loss as a rental cost and enjoy the lens.
Joe
'Learn everything, forget everything and play'
Jimi Hendrix
tkbslc Forum Pro • Posts: 17,527
17 or 20mm
5
To be honest, I prefer the 25mm to the 20mm on an absolute basis. It's a better lens in most regards and I sold my 20mm and kept the 25mm.
However, as a two lens kit, 25 and 45 is not very versatile. 25mm is not wide at all. It's a stock normal prime. And the 45mm is not a very long telephoto, it's really just a step out of normal territory. So when you own both (as I do) you end up using them for somewhat similar kinds of photos. As a 2 lens kit, I think the classic 35/85 equivalent is quite ideal. And you are right about there with 17/45 or 20/45. I would take a long look at the 17mm f1.8 or the 20mm f1.7. I think the wider focal length and better AF engine of the 17mm is more appealing, but the 20mm has sharper edges and is more compact. Either one would do nicely paired with the 45mm.
Personally, I use 15/45 as a travel pair and use the 25mm as a single lens solution closer to home.  I find 25mm ideal for family snaps and indoor portraits, but I don't find it versatile for travel.  It is not wide enough to take in the scenery, nor long enough to isolate details.  I think you want something a little wide for travel.
addlightness Veteran Member • Posts: 3,641
I have the 25mmf1.8 and the 17mmf2.8. The 25mmf1.8 lives on on EM10 whereas the 17mmf2.8 is on my GM1.
As your EPL6 is compact(like my GM1), I'd consider pancake lenses if you want absolute compactness. I bought the 17mmf2.8 + 14mmf2.5(occasionally coupled to a 0.75x wide converter) to go with my GM1 for smallest possible setup. There were a couple of times I almost bought the 20mm to complete my pancake trio on the GM1 but the 20mm doesn't flush well on the GM1 body and I already have the 25mm for those time when I need the f1.8 aperture. If the GM1 is my only body, I'd go with the 20mm and be happy with the trio.
Edit: My GM1 + 14mm/17mm for street photography mostly.  20mm/25mm would be too narrow IMO.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
