700D setting FEC?
Started Feb 12, 2016 | Questions
AnthonyL Veteran Member • Posts: 3,686
700D setting FEC?
I used to have this readily available on my 450D, now it seems as if even though it is a Menu item that I have to drill down to change it.  Have I missed something?  Flash is 430EXII.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: 700D setting FEC?
Easiest, quickest way to set FEC is directly on the 430EX II.  Press SET, + or - the amount desired, SET again.  p. 14 of the 430EX II instruction manual.  Easy-peasy.
Next would be to use the [Q] Quick Control screen, p. 120 of the 700D instruction manual.
I'd never bother with drilling into the Flash Control Menu to do FEC (pp. 218-222)  IMHO, YMMV.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP AnthonyL Veteran Member • Posts: 3,686
I need to grow fingernails for this one!
I'd missed this one, thanks.
On the 450D I had it added to the Menu, but of course the Quick Control gives me a lot of fine control.  I think I'll get to like it.  Thanks.
