(unknown member)
Re: Buying First Prime(s) Questions - 20mm + Sigma 30mm & 60mm later? Or Conventional 25mm?
brad1242 wrote:
I can definitely see what you're saying about f2.8 potentially not being fast enough, especially on the 30mm which can be used indoors for low light work... I think it might be slightly less important with the 60mm though where you probably would only be using it outside, probably in the daylight anyway... And I've heard those lenses are most known for their sharpness, if not for their speed, but I definitely hear your concerns about that.
I just looked up the 15mm f1.7 and its quite pricey, like most fast wide primes for M4/3 - Between the 20mm and the 25mm, do you feel the 20mm offers a considerably wider view, if I were not going to buy a prime wider than 20mm, at least for a while? Maybe I'm just overthinking it - I had committed to buy a pany 25mm f1.7 used on craigslist 2 days ago and then the seller stopped responding to my texts, otherwise I wouldn't even be asking this question haha.
If I had to choose only 1 (between the 20 & 25) I honestly couldn't say. For certain. The 20 lacks support for CAF, & is a bit slower to focus. The 25 is blindingly fast, supports CAF, & seems very accurate. Could be a tiny bit less sharp, but you really have to look hard, and back to back with the 20, to actually see it. That's not what photography is about. In my world anyway If you plan to shoot more indoors, I'd say the 20. If you have plenty of room to move around, go the 25. If you want to shoot groups of people, 20 mm, single or couples etc, the 25. Really depends on your intended use.
I probably should expand a little on going for faster lenses. I come from full frame -a 6D to be precise, & a few f/1.8-2.8 primes. In low light, the smaller formats require the faster lenses, to get anywhere close to the ff. So far, I'm really happy with what I'm seeing. In good light, I can't see any difference, probably because there is none Other than differing DOF. I also have an EOS M, & have had a few quite vigorous discussions in the past with ff fanbois regarding IQ in good/reasonable light, and have shot the 2 back to back at the same time in the same conditions & compared results. That's why I'm perfectly happy to use m4/3. For my purposes, the faster primes get me close enough in low light, for how I view my pictures, in good light, there is no issue. Just depends what/where/how you view your photos really
