otto k
NX500 - tethered shooting - simple "hack"
Feb 8, 2016
14
Hi. To best of my knowledge NX500 is not supposed to be used tethered by USB to PC, that was left as a domain of NX1 as professional model. When you connect it via USB cable to PC it automatically switches SD card to mass storage mode and disables any camera operation (at least my NX500 does when connected to Linux).
What follows is a very simple "hack" (it's not really a hack) that enables the use of camera via PTP/MTP protocol - enabling use of camera while still having access to all image files (and possibly remote control, see later) in real time.
First of all thanks to tecnoworld for providing old versions of firmware that proved easier to work with when compared to current versions.
Second thanks goes to Samsung engineers that made many nice things in firmware I'm trying to access. You guys rock. Your management guys - not so much.
To use NX500 (might work for other recent-ish models - looking for volunteers - I don't see how this could damage the camera in any way) in PTP/MTP mode:
1. Create text file with just a line break (CR/LF - simple enter in Notepad will do) named info.tgw in the root of the SD card.
2. Insert SD card in camera
3. Connect camera via USB cable to PC
4. Turn on camera
That's it.
You should see a series of green dots on the left side of the camera indicating factory/development/custom mode is active (see picture).
Series of green dots on the left indicates special mode
info.tgw file instructs the camera to start the daemon process in background and wait for PTP/MTP commands from the computer.
Under Linux I can easily access the DCIM folder with any file browser and see how the files are being written to the card in real time (I use a slow class 4 card and shot RAW files - you can see the size increasing). This enables one to automatically copy files off camera (at ~18MB/s for this card) to PC for further editing. Only difference I found was that photo size was grayed out in the menu (it's 28MP) - JPG works, RAW, works, modes work, even video files (BTW, they are written down 4MB at a time - nice for streaming offload to PC).
Unfortunately, I can't trigger shooting or any other setting from command line (neither gphoto nor libptp support Samsung) - maybe Lightroom or other program could also control the camera - volunteers wanted.
Here is output of gphoto:
gphoto2 --port usb: --abilities
Abilities for camera : USB PTP Class Camera
Serial port support : no
USB support : yes
Capture choices :
: Image
: Preview
Configuration support : yes
Delete selected files on camera : yes
Delete all files on camera : no
File preview (thumbnail) support : yes
File upload support : yes
So, it should support full remote control but I lack any software that works with samsung cameras.
That's it for now, I'm still trying to get the camera to CS Mode to remove video limit (and play with other things) but that DOWN-OK-UP-OK-RIGHT-EXP+OK shortcut from service manual does not work at all in any configuration (it's possible it was dropped for production firmwares or that is requires some special software).
I would like to hear:
1. Does this work under windows?
2. Does this work with NX1/NX300/NX2000/NX3000 (Tizen based cameras)?
3. Does remoting work under windows?
Otto
